Meistari Skrevet 25. juni 2007 Del Skrevet 25. juni 2007 Da jeg skulle skru på PCen i morges, som jeg alltid gjør, forble skjermen svart. Den fungerte helt utmerket i går kveld og jeg TROR ikke det har vært noe torden etc over her i løpet av natta. Det høres ut som om alle vifter etc starter som de skal inni der, men det kommer ikke noe skjermbilde. Hva kan være galt? Maskinen er en Dimension 9200 fra Dell.. paster inn litt info fra Dell sin hjemmeside Processors Intel® CoreTM 2 Duo processor: E6300-E6700 Chipset Intel P965 Express Chipset/ICH8DH The P965 chipset supports PCI Express graphics, SATA II hard drives, 1066 MHz front side bus, DDR2 667MHz Dual Channel SDRAM, and integrated RAID 0 and RAID 1. Memory DDR25 is a memory architecture that enables systems to improve performance and reduce power consumption. The amount of RAM you have determines how many programs can be executed at one time and how much data can be readily available to a program. It also determines how quickly your applications perform and how many applications you can easily toggle between at one time. Simply put, the more RAM you have, the more programs you can run smoothly and simultaneously. Up to 4GB6 Dual-Channel DDR25 SDRAM (667MHz, 2 or 4 DIMMs) Up to 4GB6 Dual-Channel DDR25 SDRAM (533MHz, 2 or 4 DIMMs) Hard Drives The Dimension 9200 supports up to two hard drives, each with up to 500GB6 space - a potential capacity of 1TB2. And with Dell SecureDataTM and RAID 0 options, you can configure your storage to meet your needs, whether it's for storing large quantities of files, backing up system information and files, or improving performance with data striping. Up to 1TB2 Multiple Serial ATA Hard Drives with both hard drives utilized. Up to 500GB with Dell SecureData, exclusively offered by Dell - a safe and simple way to help protect your memories from damage due to accidents, system crashes and other disasters. Up to 500GB Single Serial ATA Hard Drive Optical Drives Multiple DVDRW 7, Combo, DVD-ROM configurations available 3.5" Floppy Drive and 13-in-1 Media Reader Available Graphics 256MB PCI ExpressTM NVIDIA® GeForceTM 7300LE TurboCache ATI X1300 Pro 256MB 256MB nVidia GeForce 7900 GS 512MB nVidia GeForce 7900 GTX Sound Cards Sound Blaster X-FiTM XtremeMusic with Dolby 5.1 Physics Accelerator AGEIA® PhysXTM physics accelerator Chassis 375 Watt DC Power Supply Heat dissipation: 1280 BTU/hr Voltage: 90 to 135 V and 180 to 265 V at 50/60 Hz Backup battery: 3-V CR2032 lithium coin cell Lenke til kommentar
Cubicle Dude Skrevet 25. juni 2007 Del Skrevet 25. juni 2007 Går den igjennom POST? Power On Self Test Om du sjekker linken litt så kan du muligens finne feilen.... Ellers kan du være heldig, sjekk at kablen mellom pc og monitor er ok... Lenke til kommentar
Meistari Skrevet 25. juni 2007 Forfatter Del Skrevet 25. juni 2007 Går den igjennom POST? Power On Self Test Om du sjekker linken litt så kan du muligens finne feilen.... Ellers kan du være heldig, sjekk at kablen mellom pc og monitor er ok... 8938880[/snapback] Vanskelig å si i og med at det ikke kommer noe bilde på skjermen, men det HØRES ikke ut som om den går igjennom POST. Kabelen mellom pc og monitor skal være ok, men jeg skal sjekke det. Lenke til kommentar
Cubicle Dude Skrevet 25. juni 2007 Del Skrevet 25. juni 2007 Beeps Meaning Steady, short beeps Power supply may be bad Long continuous beep tone Power supply bad or not plugged into motherboard correctly Steady, long beeps Power supply bad No beep Power supply bad, system not plugged in, or power not turned on No beep If everything seems to be functioning correctly there may be a problem with the 'beeper' itself. One long, two short beeps Video card failure Mulig denne sier deg noe. Prøv evnt en annen skjerm?? Kan jo være den også. Ellers er det mulig skjermkortet er "på de evige jaktmarker"...Mulig evnt å prøve et annet skjermkort. Lenke til kommentar
Meistari Skrevet 25. juni 2007 Forfatter Del Skrevet 25. juni 2007 Beeps Meaning Steady, short beeps Power supply may be bad Long continuous beep tone Power supply bad or not plugged into motherboard correctly Steady, long beeps Power supply bad No beep Power supply bad, system not plugged in, or power not turned on No beep If everything seems to be functioning correctly there may be a problem with the 'beeper' itself. One long, two short beeps Video card failure Mulig denne sier deg noe. Prøv evnt en annen skjerm?? Kan jo være den også. Ellers er det mulig skjermkortet er "på de evige jaktmarker"...Mulig evnt å prøve et annet skjermkort. 8939922[/snapback] Jepp, jeg så det her på linken du kopierte. Det kommer ingen pip, og det mest sannsynlige jeg kan tenke meg også er at strømforsyninga har tatt kvelden. Skal sjekke med et nytt et og se hva som skjer. Lenke til kommentar
siindre Skrevet 25. juni 2007 Del Skrevet 25. juni 2007 Har du gått over alle kablene og sett at de sitter skikkelig. Evt prøv å slette CMOS. Det gjøres ved å flytte CMOS jumperen en pin til siden i noen sekunder får å så flytte den tilbake. HK batteriet bør være koblet ut mens dette skjer. Lenke til kommentar
Arne Skrevet 25. juni 2007 Del Skrevet 25. juni 2007 Dette skjedde hos meg og. Feilen var at CPU'en ikkje satt skikkeleg i. Lenke til kommentar
Meistari Skrevet 26. juni 2007 Forfatter Del Skrevet 26. juni 2007 Jeg har ikke fikla med CPU inni der. Maskina ble levert ferdig satt sammen fra DELL. (som jeg forøvrig neppe handler mer hos kjenner jeg. hehe..) Fikk bytta PSU i dag, men der hjalp fint lite. Så det er neppe der problemet ligger. Det kommer litt pussige "skrapelyder" fra harddisken når jeg prøver å starte opp. Men om det er harddisken det er noe feil med bør man vel kunne se BIOS i det minste? Lenke til kommentar
Meistari Skrevet 26. juni 2007 Forfatter Del Skrevet 26. juni 2007 Tja... da prøvde jeg å koble ut harddisken. Den var tydeligvis ikke problemet. Sjekka at CPU satt ordentlig og. Høres ut som om den skurrelyden kommer fra et sted i nærheten av CPU. Litt vanskelig å beskrive den lyden, men den minner mest om en harddisk når den leser, bare litt mer høyfrekent liksom. Lenke til kommentar
loddebolten Skrevet 26. juni 2007 Del Skrevet 26. juni 2007 (endret) hvilken PSU prøvde du med ? mulig jeg tar feil men har ikke Dell sine "egne" PSU,er altså ikke vanlig standard slik at du må ha en Dell PSU for at det skal funke.Meget mulig jeg tar feil her men sjekk for sikkerhets skyld.Søkte litt på forumet og fant flere tråder som advarer mot Dell og "vanlige" psu,er så det kan være noe i det ja. Endret 26. juni 2007 av loddebolten Lenke til kommentar
Dimas Skrevet 26. juni 2007 Del Skrevet 26. juni 2007 (endret) Hadde akkurat samme problemet her for ikke lenge siden, alle viftene start o.l. men skjermen forble svart, skjedde også her over natten. Hos meg var det faktisk hovedkortet som hadde tatt kveld, var litt kjipt, tok en del testing for å finne ut hva som var feil Men med nytt hovedkort funka det fint igjen Endret 26. juni 2007 av Dimas Lenke til kommentar
Meistari Skrevet 26. juni 2007 Forfatter Del Skrevet 26. juni 2007 Det stemmer at Dell har mange egne løsninger. PSUen som satt i denne maskina er fysisk større enn hva som er standard, samt at det er laget et lite "søkk" i den ene siden som skal passe inn i et hakk i kabinettet. Så en vanlig PSU vil ikke passe som hånd i hanske inn i dette kabinettet ihvertfall, med mindre man modder en smule på kabinettet. Rent bortsett fra det så ser alt av spenninger etc ut til å stemme overens med de to PSUene jeg har her nå. Lenke til kommentar
Lofferen Skrevet 26. juni 2007 Del Skrevet 26. juni 2007 Hadde det samme problemet. Trodde først at hovedkortet var defekt, men det var skjermkortet som hadde tatt kvelden. Jeg fikk lånt meg et skjermkort av en kamerat og da fungerte alt som det skulle. Har du prøvd med et annet skjermkort?, muligens at det kan være feilen. Det er ivertfall kjedelig å måtte bytte ut den dyreste delen i pcen. Lenke til kommentar
Spartan Skrevet 26. juni 2007 Del Skrevet 26. juni 2007 Enkelte pc'er nekter å starte hvis CMOS batteriet tar kvelden. Lenke til kommentar
Meistari Skrevet 26. juni 2007 Forfatter Del Skrevet 26. juni 2007 Prøvde annet skjermkort og ja. Funka ikke. Ringte til teknisk support hos Dell, og de visste hva skurrelydene var for no. Det er tydeligvis Dell sine superhemmelige feilkoder som erstatter pipesekvensene fra pc-speakeren. :-D Den skurringa betød at det var en RAM feil og at hovedkortet på en eller annen måte ikke oppfatter at RAM brikkene sitter i. Fortsatt pussig at det her skulle skje over natta med PCen av, men Dell mente det var hovedkortet som hadde takka for seg og sunget det siste refrenget. Så nå kommer det en kis fra Dell på døra og henter maskina, så får vi se hva som EGENTLIG var feilen. hehe... Takk for alle tips og råd i tråden! Lenke til kommentar
