route nettverk fra eth0 til eth1
Eller en enklere måte:
Hello,
The following will explain how to share your Internet connection:
Note: Type all the following commands in a root terminal, DO NOT use sudo.
1. Start by configuring the network card that interfaces to the other computers on you network:
# ifconfig ethX ip
where ethX is the network card and ip is your desired server ip address (Usually 192.168.0.1 is used)
2. Then configure the NAT as follows:
# iptables -t nat -A POSTROUTING -o ethX -j MASQUERADE
where ethX is the network card that the Internet is coming from
# echo 1 > /proc/sys/net/ipv4/ip_forward
3. Install dnsmasq and ipmasq using apt-get:
# apt-get install dnsmasq ipmasq
4. Restart dnsmasq:
# /etc/init.d/dnsmasq restart
5. Reconfigure ipmasq to start after networking has been started:
# dpkg-reconfigure ipmasq
6. Repeat steps 1 and 2.
7. Add the line "net.ipv4.ip_forward = 1" to /etc/sysctl.conf
# gedit /etc/sysctl.conf
8. Reboot. (Optional)
Fra Ubuntuforums.org.
