Problem med nettverk. Ubuntu 7.04.
Hm, høres ut som et merkelig problem. Hva slags tråløst kort har du? Har du søkt på ubuntuforumet etter folk med lignende problemer (folk har generelt mer kompetanse der på slike problemer).
http://www.ubuntuforums.org
En eventuell workaround kan være å bare sette opp den kommandoen til å kjøre når du starter gnome (kan muligens gjøres ved å legge den til under sesjoner under system-menyem).
Tenkte jeg skulle lime inn det som står når jeg starter.
sudo /etc/init.d/networking restart
Password:
* Reconfiguring network interfaces...                                          There is already a pid file /var/run/dhclient.eth0.pid with pid 3922
killed old client process, removed PID file
Internet Systems Consortium DHCP Client V3.0.4
Copyright 2004-2006 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/sw/dhcp/
Listening on LPF/eth0/00:04:61:53:99:4f
Sending on   LPF/eth0/00:04:61:53:99:4f
Sending on   Socket/fallback
DHCPRELEASE on eth0 to 10.0.0.138 port 67
RTNETLINK answers: No such process
There is already a pid file /var/run/dhclient.eth1.pid with pid 5545
Listening on LPF/eth1/00:c0:ca:11:3d:60
Sending on   LPF/eth1/00:c0:ca:11:3d:60
There is already a pid file /var/run/dhclient.eth0.pid with pid 134993416
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 6
DHCPOFFER from 10.0.0.138
DHCPREQUEST on eth0 to 255.255.255.255 port 67
DHCPACK from 10.0.0.138
bound to 10.0.0.6 -- renewal in 36838 seconds.
There is already a pid file /var/run/dhclient.eth1.pid with pid 134993416
DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 4
DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7
DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 13
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
eth2: ERROR while getting interface flags: No such device
There is already a pid file /var/run/dhclient.eth2.pid with pid 134993416
SIOCSIFADDR: No such device
Bind socket to interface: No such device
Failed to bring up eth2.
ath0: ERROR while getting interface flags: No such device
There is already a pid file /var/run/dhclient.ath0.pid with pid 134993416
Failed to bring up ath0.
wlan0: ERROR while getting interface flags: No such device
There is already a pid file /var/run/dhclient.wlan0.pid with pid 134993416
Failed to bring up wlan0.
