am2 og am2+
joepoe
HyperTransport 3.0 operating at up to 2 GHz
Advanced power features summarized as having split power planes, probably one for CPU Cores, and the other for the Integrated Memory controller (IMC), this will help for more advanced power management control.
AMD confirmed that AM2 processors will work in AM2+ motherboards and AM2+ processors will work on AM2 motherboards. However, due to the lack of support of HyperTransport 3.0 and separated power planes in Socket AM2 motherboards, AM2+ chips will be limited to the specifications of Socket AM2 (HyperTransport 2.0 at the speed of 1 GHz, one power plane for both Cores and IMC). AM2 chips will not benefit from faster HyperTransport and separated power planes on AM2+ motherboards as they do not support them, AM2+ motherboard then fall back to compatibility mode using AM2 specifications.
HT vil ha en datarate som er 50% høyere enn CPU-klokken.
Prosessorene vil få to minnekontrollere med en datakanal hver. Det blir altså to uavhengige lese/skrive-køer istedenfor det gamle systemet hvor en kontroller disponerer to datakanaler.
