LØST -ContraVirus klarer ille å fjerne dll fil
Hei!
Etter å ha lett masse på nett for å fjerne dette så må jeg bare si som denne mannen: " I've tried everything to get rid of this nasty malware called Contravirus 2.0 My Ad-Aware scan did not get rid of it. "
Jeg har fått avinnstalert programmet med CCleaner men det ligger igjen enn dll fil som overhode ikke vil vekk.
Jeg forsøker nå å få til følgende:
How to remove ContraVirus DLL files:
Like most any software, spyware, adware, and malware may also use DLL files. DLL is short for “dynamically linked library,” and ContraVirus DLL files, like other DLLs, carryout predetermined tasks. To manually delete ContraVirus DLL files, you’ll use Regsver32, a Windows tool designed to help you remove DLL and other files.
First you’ll locate ContraVirus DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the ContraVirus DLL file is located. If you’re not sure if the ContraVirus DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
When you’ve located the ContraVirus DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore ContraVirus DLL file you removed, enter “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
etter jeg har skrevet run og kommer inn så forstår jeg ikke hvordan jeg skal hente opp filen. Jeg skriver "cd " og legger inn filbanen, men får tilbake at den ikke finner anngitt bane...
Noen her inne som vet en ok måte å fjerne dll filer på?
Takker for all hjelp jeg kan få!
Endret av beachboy
Takk for hjelpen, her er logg filen :)
Klikk for å se/fjerne innholdet nedenfor
Logfile of Trend Micro HijackThis v2.0.0 (BETA)
Scan saved at 20:57:13, on 16.06.2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\csrss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\Norman\Npm\bin\ELOGSVC.EXE
C:\Norman\Npm\Bin\Zanda.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Programfiler\NVIDIA Corporation\NetworkAccessManager\Apache Group\Apache2\bin\apache.exe
C:\Programfiler\MagicTune Premium\MagicTuneEngine.exe
C:\Programfiler\NVIDIA Corporation\NetworkAccessManager\bin\nSvcIp.exe
C:\Programfiler\NVIDIA Corporation\NetworkAccessManager\bin\nSvcLog.exe
C:\WINDOWS\system32\wdfmgr.exe
C:\Programfiler\NVIDIA Corporation\NetworkAccessManager\bin\nSvcAppFlt.exe
C:\Norman\Npm\bin\NJEEVES.EXE
C:\Norman\Nvc\BIN\NVCSCHED.EXE
C:\Norman\Nvc\bin\nvcoas.exe
C:\WINDOWS\System32\alg.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\RUNDLL32.EXE
C:\Programfiler\NVIDIA Corporation\NetworkAccessManager\bin\nTrayFw.exe
C:\WINDOWS\TBPanel.exe
C:\Programfiler\CyberLink\PowerDVD\PDVDServ.exe
C:\Norman\Npm\bin\ZLH.EXE
C:\Programfiler\MagicTune Premium\MagicTune.exe
C:\Norman\Nvc\BIN\NIP.EXE
C:\WINDOWS\RTHDCPL.EXE
C:\Programfiler\Java\jre1.6.0_01\bin\jusched.exe
C:\Norman\Nvc\bin\cclaw.exe
C:\Programfiler\ScanSoft\OmniPageSE2.0\OpwareSE2.exe
C:\Programfiler\Adobe\Photoshop Album Starter Edition\3.0\Apps\apdproxy.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Programfiler\SUPERAntiSpyware\SUPERAntiSpyware.exe
C:\PROGRA~1\MICROS~2\OFFICE11\OUTLOOK.EXE
C:\Programfiler\Internet Explorer\IEXPLORE.EXE
C:\WINDOWS\system32\notepad.exe
C:\Programfiler\WinRAR\WinRAR.exe
C:\DOCUME~1\TRINEO~1\LOKALE~1\Temp\Rar$EX00.562\HiJackThis_v2.exe
C:\WINDOWS\system32\wbem\wmiprvse.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.db.no/
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Koblinger
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Programfiler\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Programfiler\Java\jre1.6.0_01\bin\ssv.dll
O3 - Toolbar: Easy-WebPrint - {327C2873-E90D-4c37-AA9D-10AC9BABA46C} - C:\Programfiler\Canon\Easy-WebPrint\Toolband.dll
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [JMB36X IDE Setup] C:\WINDOWS\JM\JMInsIDE.exe
O4 - HKLM\..\Run: [JMB36X Configure] C:\WINDOWS\system32\JMRaidTool.exe boot
O4 - HKLM\..\Run: [nTrayFw] C:\Programfiler\NVIDIA Corporation\NetworkAccessManager\bin\nTrayFw.exe
O4 - HKLM\..\Run: [skyTel] SkyTel.EXE
O4 - HKLM\..\Run: [Gainward] C:\WINDOWS\TBPanel.exe /A
O4 - HKLM\..\Run: [RemoteControl] C:\Programfiler\CyberLink\PowerDVD\PDVDServ.exe
O4 - HKLM\..\Run: [Norman ZANDA] C:\Norman\Npm\bin\ZLH.EXE /LOAD /SPLASH
O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
O4 - HKLM\..\Run: [Alcmtr] ALCMTR.EXE
O4 - HKLM\..\Run: [sunJavaUpdateSched] "C:\Programfiler\Java\jre1.6.0_01\bin\jusched.exe"
O4 - HKLM\..\Run: [OpwareSE2] "C:\Programfiler\ScanSoft\OmniPageSE2.0\OpwareSE2.exe"
O4 - HKLM\..\Run: [Adobe Photo Downloader] "C:\Programfiler\Adobe\Photoshop Album Starter Edition\3.0\Apps\apdproxy.exe"
O4 - HKLM\..\Run: [Windows Updater Servc] C:\WINDOWS\system32\xpuupdate.exe
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [updateMgr] C:\Programfiler\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe AcRdB7_0_9
O4 - HKCU\..\Run: [sUPERAntiSpyware] C:\Programfiler\SUPERAntiSpyware\SUPERAntiSpyware.exe
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'LOKAL TJENESTE')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'NETTVERKSTJENESTE')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O8 - Extra context menu item: Easy-WebPrint Add To Print List - res://C:\Programfiler\Canon\Easy-WebPrint\Resource.dll/RC_AddToList.html
O8 - Extra context menu item: Easy-WebPrint High Speed Print - res://C:\Programfiler\Canon\Easy-WebPrint\Resource.dll/RC_HSPrint.html
O8 - Extra context menu item: Easy-WebPrint Preview - res://C:\Programfiler\Canon\Easy-WebPrint\Resource.dll/RC_Preview.html
O8 - Extra context menu item: Easy-WebPrint Print - res://C:\Programfiler\Canon\Easy-WebPrint\Resource.dll/RC_Print.html
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Programfiler\Java\jre1.6.0_01\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Programfiler\Java\jre1.6.0_01\bin\ssv.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Programfiler\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Programfiler\Messenger\msmsgs.exe
O16 - DPF: {5F8469B4-B055-49DD-83F7-62B522420ECC} (Facebook Photo Uploader Control) - http://upload.facebook.com/controls/Facebo...otoUploader.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/...b?1138020578359
O16 - DPF: {BFF1950D-B1B4-4AE8-B842-B2CCF06D9A1B} (Zylom Games Player) - http://game01.zylom.com/activex/zylomgamesplayer.cab
O20 - Winlogon Notify: !SASWinLogon - C:\Programfiler\SUPERAntiSpyware\SASWINLO.dll
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\system32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\system32\browseui.dll
O23 - Service: Norman eLogger service 6 (eLoggerSvc6) - Norman ASA - C:\Norman\Npm\bin\ELOGSVC.EXE
O23 - Service: ForceWare Intelligent Application Manager (IAM) - Unknown owner - C:\Programfiler\NVIDIA Corporation\NetworkAccessManager\bin\nSvcAppFlt.exe
O23 - Service: Forceware Web Interface (ForcewareWebInterface) - Apache Software Foundation - C:\Programfiler\NVIDIA Corporation\NetworkAccessManager\Apache Group\Apache2\bin\apache.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Programfiler\Fellesfiler\InstallShield\Driver\1150\Intel 32\IDriverT.exe
O23 - Service: iPod-tjeneste (iPod Service) - Unknown owner - C:\Programfiler\iPod\bin\iPodService.exe (file missing)
O23 - Service: MagicTuneEngine - Unknown owner - C:\Programfiler\MagicTune Premium\MagicTuneEngine.exe
O23 - Service: Norman NJeeves - Unknown owner - C:\Norman\Npm\bin\NJEEVES.EXE
O23 - Service: Norman ZANDA - Norman ASA - C:\Norman\Npm\Bin\Zanda.exe
O23 - Service: ForceWare IP service (nSvcIp) - NVIDIA Corporation - C:\Programfiler\NVIDIA Corporation\NetworkAccessManager\bin\nSvcIp.exe
O23 - Service: ForceWare user log service (nSvcLog) - NVIDIA - C:\Programfiler\NVIDIA Corporation\NetworkAccessManager\bin\nSvcLog.exe
O23 - Service: Norman Virus Control on-access component (nvcoas) - Norman ASA - C:\Norman\Nvc\bin\nvcoas.exe
O23 - Service: Norman Virus Control Scheduler (NVCScheduler) - Norman ASA - C:\Norman\Nvc\BIN\NVCSCHED.EXE
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
End of file - 8174 bytes--
Her erSAS filen:
SUPERAntiSpyware Scan Log
http://www.superantispyware.com
Generated 06/16/2007 at 08:46 PM
Application Version : 3.8.1002
Core Rules Database Version : 3256
Trace Rules Database Version: 1267
Scan type : Complete Scan
Total Scan Time : 00:25:33
Memory items scanned : 442
Memory threats detected : 0
Registry items scanned : 5513
Registry threats detected : 0
File items scanned : 37458
File threats detected : 3
Malware.ContraVirus
C:\SYSTEM VOLUME INFORMATION\_RESTORE{9D38D0F2-C70D-4E6D-8CE9-14BF521B343F}\RP68\A0042272.DLL
C:\SYSTEM VOLUME INFORMATION\_RESTORE{9D38D0F2-C70D-4E6D-8CE9-14BF521B343F}\RP68\A0042273.DLL
C:\SYSTEM VOLUME INFORMATION\_RESTORE{9D38D0F2-C70D-4E6D-8CE9-14BF521B343F}\RP68\A0042274.DLL
Endret av beachboy
ok her kommer loggen: -takk forresten :)
SmitFraudFix v2.195
Scan done at 21:35:48,56, 16.06.2007
Run from C:\Documents and Settings\Trine Og Diana\Skrivebord\SmitfraudFix
OS: Microsoft Windows XP [Versjon 5.1.2600] - Windows_NT
The filesystem type is NTFS
Fix run in normal mode
»»»»»»»»»»»»»»»»»»»»»»»» Process
C:\WINDOWS\system32\NOTEPAD.EXE
C:\WINDOWS\NOTEPAD.EXE
C:\Programfiler\Opera\Opera.exe
C:\WINDOWS\system32\cmd.exe
»»»»»»»»»»»»»»»»»»»»»»»» hosts
»»»»»»»»»»»»»»»»»»»»»»»» C:\
»»»»»»»»»»»»»»»»»»»»»»»» C:\WINDOWS
C:\WINDOWS\wincom27.dll FOUND !
»»»»»»»»»»»»»»»»»»»»»»»» C:\WINDOWS\system
»»»»»»»»»»»»»»»»»»»»»»»» C:\WINDOWS\Web
»»»»»»»»»»»»»»»»»»»»»»»» C:\WINDOWS\system32
»»»»»»»»»»»»»»»»»»»»»»»» C:\Documents and Settings\Trine Og Diana
»»»»»»»»»»»»»»»»»»»»»»»» C:\Documents and Settings\Trine Og Diana\Application Data
»»»»»»»»»»»»»»»»»»»»»»»» Start Menu
»»»»»»»»»»»»»»»»»»»»»»»» C:\DOCUME~1\TRINEO~1\FAVORI~1
»»»»»»»»»»»»»»»»»»»»»»»» Desktop
»»»»»»»»»»»»»»»»»»»»»»»» C:\Programfiler
»»»»»»»»»»»»»»»»»»»»»»»» Corrupted keys
»»»»»»»»»»»»»»»»»»»»»»»» Desktop Components
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Desktop\Components\0]
"Source"="About:Home"
"SubscribedURL"="About:Home"
"FriendlyName"="Min gjeldende hjemmeside"
»»»»»»»»»»»»»»»»»»»»»»»» Sharedtaskscheduler
!Attention, following keys are not inevitably infected!
SrchSTS.exe by S!Ri
Search SharedTaskScheduler's .dll
»»»»»»»»»»»»»»»»»»»»»»»» AppInit_DLLs
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows]
"AppInit_DLLs"=""
»»»»»»»»»»»»»»»»»»»»»»»» Winlogon.System
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"System"=""
»»»»»»»»»»»»»»»»»»»»»»»» Rustock
»»»»»»»»»»»»»»»»»»»»»»»» DNS
Description: NVIDIA nForce Networking Controller - Miniport for pakkeplanlegger
DNS Server Search Order: 84.208.20.110
DNS Server Search Order: 84.208.20.111
DNS Server Search Order: 85.119.136.140
DNS Server Search Order: 85.119.136.158
HKLM\SYSTEM\CCS\Services\Tcpip\..\{C66ABE62-6BD6-4601-A5DB-6A9554BC1392}: DhcpNameServer=84.208.20.110 84.208.20.111 85.119.136.140 85.119.136.158
HKLM\SYSTEM\CS1\Services\Tcpip\..\{C66ABE62-6BD6-4601-A5DB-6A9554BC1392}: DhcpNameServer=84.208.20.110 84.208.20.111 85.119.136.140 85.119.136.158
HKLM\SYSTEM\CS2\Services\Tcpip\..\{C66ABE62-6BD6-4601-A5DB-6A9554BC1392}: DhcpNameServer=84.208.20.110 84.208.20.111 85.119.136.140 85.119.136.158
HKLM\SYSTEM\CCS\Services\Tcpip\Parameters: DhcpNameServer=84.208.20.110 84.208.20.111 85.119.136.140 85.119.136.158
HKLM\SYSTEM\CS1\Services\Tcpip\Parameters: DhcpNameServer=84.208.20.110 84.208.20.111 85.119.136.140 85.119.136.158
HKLM\SYSTEM\CS2\Services\Tcpip\Parameters: DhcpNameServer=84.208.20.110 84.208.20.111 85.119.136.140 85.119.136.158
»»»»»»»»»»»»»»»»»»»»»»»» Scanning for wininet.dll infection
»»»»»»»»»»»»»»»»»»»»»»»» End
tilsynelatende er de filene jeg ville bli kvitt borte nå med hjelp fra SAS. Men maskinen er utrolig treg. Bruker 5-10 sek for å få opp VG. hmmmmm
Kanskje du kan se noen feil på loggene mine?
Tusen takk for at du gidder å bruke tiden din på dette!!
Endret av beachboy
Prøv:
1. Trykk noen ganger til på F8 og se om du får opp oppstartsvalgene med bla. Sikker modus
2. Velg system-harddisken, og fortsett å trykk på F8 for å se om du får oppstartsvalgene.
3. Hvis dette ikke fungerer, lar du bare pc'n starte opp som vanlig. Gå deretter til:
Start -> Kjør
Skriv: msconfig
Under arkfanen Boot.ini, haker du av for \SAFEBOOT
Restart.
Pc'n skal nå boote i sikker modus.
ok... tror jeg fikk det til nå (sliter med bølåskjerm ved oppstart så jeg fikk den ett par ganger... men det skal komplett få fikse. hehe.)
jeg valgte den første disken for safe modus... også sartet den opp. Regner da med at det er rett....
Jeg fikk nå denne loggen:
SmitFraudFix v2.195
Scan done at 22:04:35,90, 16.06.2007
»»»»»»»»»»»»»»»»»»»»»»»» SharedTaskScheduler Before SmitFraudFix
SrchSTS.exe by S!Ri
»»»»»»»»»»»»»»»»»»»»»»»» Killing process
127.0.0.1 localhost
»»»»»»»»»»»»»»»»»»»»»»»» Generic Renos Fix
GenericRenosFix by S!Ri
»»»»»»»»»»»»»»»»»»»»»»»» Deleting infected files
C:\WINDOWS\wincom27.dll Deleted
»»»»»»»»»»»»»»»»»»»»»»»» Deleting Temp Files
"System"=""
»»»»»»»»»»»»»»»»»»»»»»»» Registry Cleaning
Registry Cleaning done.
»»»»»»»»»»»»»»»»»»»»»»»» SharedTaskScheduler After SmitFraudFix
SrchSTS.exe by S!Ri
hehe, den er god:)
Scan saved at 22:17:18, on 16.06.2007
Boot mode: Normal
Running processes:
C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe
C:\WINDOWS\system32\wuauclt.exe
C:\Documents and Settings\Trine Og Diana\Skrivebord\HiJackThis_v2.exe
O4 - HKLM\..\Run: [MSConfig] C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto
End of file - 8127 bytes
Kjør HJT, sett merke framfor følgende linje og klikk 'Fix checked':
Ut over dette er loggen fin :thumbup:
Du bør nullstille gjenopprettingsmappa slik at du ikke blir infisert ved en evt. systemgjenoppretting.
Kontrollpanel->system->systemgjenoppretting .
Sett merke framfor "Slå av Systemgjenopprettingen .....",
restart pc,
fjern merket igjen for å aktivere funksjonen.
Hvordan kjører pc'n?
ok og tusen takk! :)
Den kjører dessverre ikke så bra som den burde. Rett og slett treg. Bruker nå ca 5 sek å få opp dagbladet og 10 sek for å åpne en nyhet. Det er veldig tregt for denne maskinen har vært rask som ett uvær... men for all del. det kan jo være noe annet som er galt.
Hent denne filen, pakk den ut og dobbeltklikk på iereg.bat:
IEreg.bat
Restart, og se om det hjalp.
Ut over dette kan du sjekke om det er noen systemfiler som er i ulage. Du trenger antakelig WinXP-cd'n:
Klikk Start -> Kjør
Skriv: sfc /scannow (mellomrom mellom sfc og / )
IEreg re-registrerer noen filer.
Plages du fortsatt med treghet?
Gjelder dette bare internett eller er det andre program som virker tregt?
Prøv å oppdatere IE til siste versjon (IE 7.0) om du ikke har dette.
Endret av norbat
