bjaa Skrevet 5. januar 2003 Rapporter Del Skrevet 5. januar 2003 jeg lurte på hva disse turbo 1 og turbo 2 instillingene er for noe? forresten hva netyr de dere cl2.5 osv? Lenke til kommentar
b-real Skrevet 5. januar 2003 Rapporter Del Skrevet 5. januar 2003 Turbo sier vel seg selv, du som har bil-signatur og alt Ram'en stilles til å yte max...hvor bra dette er kan seff diskuteres. CL: The RAS-to-CAS time depends on the technology, and, since it's mostly between five to seven clock cycles, this is the fundamental factor for delays. You could also say that CL2 memory is by far superior to slower models with CL2.5 (DDR) or CL3 (SDRAM). Theoretically, this is true, but other factors put the advantages of fast data transfer in another light - for one thing, modern processors have a high hit rate with cache memory, which means that they seldom have to read directly from the memory. Secondly, the rows are also switched most of the time, so that RAS-to-CAS time is also needed, thus delaying the read process. Finally, the burst reads will occasionally happen -- in this case, many of the memory cells that are directly adjacent to one another are read, but here the CAS latency occurs only once, and is therefore insignificant. Hentet fra Denne THG artikkelen Lenke til kommentar
