OpenVPN fungerer, men ikke nettverket
Hei,
Sliter litt med å få OpenVPN til å fungere som det skal på mac'en min. Har satt opp server hjemme, konfigurert denne etter "boka", for deretter å sette opp mac'en etter "boka". Dette har fungert knirkefritt i en lengre periode, men etter at jeg nylig formaterte mac'en, har alt fucka seg. Jeg får koblet meg til VPN-serveren, og i henhold til loggen, legges alle routingtabellene til korrekt. Jeg får allikevel ikkje kontakt med noen av maskinene hjemme, verken gjennom diverse programmer, eller via ping.
#OpenVPN Client conf
tls-client
client
dev tun
proto tcp-client
tun-mtu 1400
remote server.com 443
http-proxy 10.0.0.1 8080
http-proxy-retry
persist-key
persist-tun
pkcs12 Joachim.p12
cipher BF-CBC
verb 3
ns-cert-type server
Thu 06/14/07 05:06 PM: IMPORTANT: OpenVPN's default port number is now 1194
Thu 06/14/07 05:06 PM: WARNING: normally if you use --mssfix and/or --fragment
Thu 06/14/07 05:06 PM: Control Channel MTU parms [ L:1443 D:140 EF:40 EB:0 ET:0 EL:0 ]
Thu 06/14/07 05:06 PM: Data Channel MTU parms [ L:1443 D:1443 EF:43 EB:4 ET:0 EL:0 ]
Thu 06/14/07 05:06 PM: Local Options hash (VER=V4): '7e8b97b9'
Thu 06/14/07 05:06 PM: Expected Remote Options hash (VER=V4): 'f0f90397'
Thu 06/14/07 05:06 PM: Attempting to establish TCP connection with 10.0.0.1:8080
Thu 06/14/07 05:06 PM: TCP connection established with 10.0.0.1:8080
Thu 06/14/07 05:06 PM: Send to HTTP proxy: 'CONNECT server.com:443 HTTP/1.0'
Thu 06/14/07 05:06 PM: HTTP proxy returned: 'HTTP/1.1 200 Connection established'
Thu 06/14/07 05:06 PM: TCPv4_CLIENT link local: [undef]
Thu 06/14/07 05:06 PM: TCPv4_CLIENT link remote: 10.0.0.1:8080
Thu 06/14/07 05:06 PM: TLS: Initial packet from 10.0.0.1:8080
Thu 06/14/07 05:06 PM: VERIFY OK: depth=1
Thu 06/14/07 05:06 PM: VERIFY OK: nsCertType=SERVER
Thu 06/14/07 05:06 PM: VERIFY OK: depth=0
Thu 06/14/07 05:06 PM: Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Thu 06/14/07 05:06 PM: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu 06/14/07 05:06 PM: Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Thu 06/14/07 05:06 PM: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu 06/14/07 05:06 PM: Control Channel: TLSv1
Thu 06/14/07 05:06 PM: [gateway.tingvold.com] Peer Connection Initiated with 10.0.0.1:8080
Thu 06/14/07 05:06 PM: SENT CONTROL [server.com]: 'PUSH_REQUEST' (status=1)
Thu 06/14/07 05:06 PM: PUSH: Received control message: 'PUSH_REPLY
Thu 06/14/07 05:06 PM: OPTIONS IMPORT: timers and/or timeouts modified
Thu 06/14/07 05:06 PM: OPTIONS IMPORT: --ifconfig/up options modified
Thu 06/14/07 05:06 PM: OPTIONS IMPORT: route options modified
Thu 06/14/07 05:06 PM: gw 10.0.0.1
Thu 06/14/07 05:06 PM: TUN/TAP device /dev/tun8 opened
Thu 06/14/07 05:06 PM: /sbin/ifconfig tun8 delete
Thu 06/14/07 05:07 PM: NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
Thu 06/14/07 05:07 PM: /sbin/ifconfig tun8 192.168.2.6 192.168.2.5 mtu 1400 netmask 255.255.255.255 up
Thu 06/14/07 05:07 PM: /sbin/route add -net 192.168.1.0 192.168.2.5 255.255.255.0
Thu 06/14/07 05:07 PM: /sbin/route add -net 192.168.2.1 192.168.2.5 255.255.255.255
Thu 06/14/07 05:07 PM: Initialization Sequence Completed
Hva kan være galt? :o
edit:
Kjørte en ifconfig, og ser at det er hele 8 tun-devices åpne. Kan være dette som krøller det til? I følge loggfila til OpenVPN, bruker den kun tun8... Så, hvordan får man fjernet tun-devices?
jocke:~ joachim$ ifconfig
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
       inet 127.0.0.1 netmask 0xff000000
       inet6 ::1 prefixlen 128
       inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
       ether 00:14:51:12:c1:f0
       media: autoselect (none) status: inactive
       supported media: none autoselect 10baseT/UTP <half-duplex> 10baseT/UTP <full-duplex> 10baseT/UTP <full-duplex,hw-loopback> 100baseTX <half-duplex> 100baseTX <full-duplex> 100baseTX <full-duplex,hw-loopback> 1000baseT <full-duplex> 1000baseT <full-duplex,hw-loopback> 1000baseT <full-duplex,flow-control> 1000baseT <full-duplex,flow-control,hw-loopback>
en1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
       inet6 fe80::211:24ff:fea5:220c%en1 prefixlen 64 scopeid 0x5
       inet 10.0.100.232 netmask 0xff000000 broadcast 10.255.255.255
       ether 00:11:24:a5:22:0c
       media: autoselect status: active
       supported media: autoselect
fw0: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 4078
       lladdr 00:14:51:ff:fe:12:c1:f0
       media: autoselect <full-duplex> status: inactive
       supported media: autoselect <full-duplex>
tun0: flags=8851<UP,POINTOPOINT,RUNNING,SIMPLEX,MULTICAST> mtu 1400
       inet 192.168.2.6 --> 192.168.2.5 netmask 0xffffffff
       open (pid 313)
tun1: flags=8851<UP,POINTOPOINT,RUNNING,SIMPLEX,MULTICAST> mtu 1400
       open (pid 323)
tun2: flags=8851<UP,POINTOPOINT,RUNNING,SIMPLEX,MULTICAST> mtu 1400
       open (pid 345)
tun3: flags=8850<POINTOPOINT,RUNNING,SIMPLEX,MULTICAST> mtu 1500
       open (pid 723)
tun4: flags=8850<POINTOPOINT,RUNNING,SIMPLEX,MULTICAST> mtu 1500
       open (pid 735)
tun5: flags=8850<POINTOPOINT,RUNNING,SIMPLEX,MULTICAST> mtu 1500
       open (pid 862)
tun6: flags=8850<POINTOPOINT,RUNNING,SIMPLEX,MULTICAST> mtu 1500
       open (pid 872)
tun7: flags=8851<UP,POINTOPOINT,RUNNING,SIMPLEX,MULTICAST> mtu 1400
       open (pid 931)
tun8: flags=8851<UP,POINTOPOINT,RUNNING,SIMPLEX,MULTICAST> mtu 1400
       open (pid 950)
edit #2:
Kan det ha noe med at jeg har aktivert følgende option i client-config'en?;
# Downgrade privileges after initialization (non-Windows only)
user nobody
group nobody
Endret av jocke
