Snedige ting du lurer på V.2
Hvor vanlig er det at jenter har promp som lukter egg, og er det gutter som også har eggepromp? Både søsteren min og samboeren min har det, med de prøver å benekte det.
Lukter det noe annet for dem, bortsett fra at de sikkert mener den lukter bedre?
Det kan være det er manipulert, og hvis ikke, så er jo tross alt romfergene og ISS i en bane på under 400 km over jordoverflaten, så det er ikke så rart at det ser litt stort ut. Uansett, så ja, det der var i det største laget. ;)
New Zealand er jo ikkje akkurat det største landet i verden heller :p
In February 2007, the US Mint, under the Presidential $1 Coin Act of 2005,[10] introduced a new $1 US Presidential dollar coin. Based on the success of the "50 State Quarters" series, the new coin features a rotating portrait of deceased presidents in order of their inaugurations, starting with George Washington, on the obverse side. The reverse side features the Statue of Liberty. To allow for larger, more detailed portraits, the traditional inscriptions of "E Pluribus Unum," "In God We Trust," the year of minting or issuance, and the mint mark will be inscribed on the edge of the coin instead of the face. This feature, similar to the edge inscriptions seen on the British £1 coin, is not usually associated with US coin designs. The inscription "Liberty" has been eliminated, with the Statue of Liberty serving as a sufficient replacement. In addition, due to the nature of US coins, this will be the first time there will be circulating US coins of different denominations with the same President featured on the obverse (heads) side. (Lincoln/penny, Jefferson/nickel, Franklin D. Roosevelt/dime, Washington/quarter and Kennedy/half dollar.) Another unusual fact about the new $1 coin is Grover Cleveland will have two coins with his portrait issued due to the fact he was the only US President to be elected to two non-consecutive terms.
http://en.wikipedia.org/wiki/American_dollar
Edit: Det var visst på mynten det.
Endret av Zapticon
På dette bildet ser man en romstasjon eller en ferge. Kan det være ISS? Uansett, spørsmålet er hvorfor bakgrunnen (New Zealand) er så stort? Syns det er veldig merkelig at New Zealand skulle bli så forstørret på et bilde. Kan det ha noe med zoom å gjøre? :)
Bildet: http://spaceflight.nasa.gov/gallery/images.../s116e05983.jpg
Les side 9 i Per-Otto Larsens fotokompendie, så ser du at det har med korleis biletet teknisk er gjennomført :)
Ah takker. Det besvarte en ting jeg har lurt på også, selv om jeg må si jeg antok det.
I filmer er det ofte en slik effekt når f.eks. en person plutselig oppfatter et eller annet og får litt sjokk, så ser man at personen blir zoomet inn, samtidig som bakgrunnen blir "zoomet ut" (mindre). Alltid lurt litt på den der.
Endret av Z_for_Zero
Det kalles Hitchcock-effekten.
Red.: Mer presist Dolly Zoom eller "Hitchcock zoom".
Effekten skjer ved at man zoomer inn mens man kjører kameraet bakover.
Wikipedia - Dolly zoom
Dolly er et kamerastativ med hjul (eller hjul som er festet på kamerastativet).
Når man prøver å utføre effekten kan det gå litt tid i å finne ut riktig hastighet mellom zoom og kjøring.
Endret av BorN
Hva er coca cola lagd av? På baksiden står "naturlige aromaer" nevnt, hva er disse?
Eller for å spørre bedre: Hva er det som gir den særegne cola-smaken? Denne finnes jo også i godteri.
Endret av Bellicus
Hva er inni bleier? Ungen hadde kastet en bleie i mini-bassenget sitt på verandaen, da jeg oppdaget den hadde den blåst seg opp til en diger pølse og når jeg skulle slenge den ut av bassenget raknet den og det rant ut et slags gele-stoff.
Det er et stoff som skal absorbere urin og forhindre lukt. I dette tilfellet prøvde det å absorbere hele bassenget ditt men ga opp før det nådde Stephen King-dimensjoner...
Etter det jeg hører går det svært svært langsomt i oppløsning, og om 2000 år vil fremtidens arkaeologer sikkert lure på hvaslags merkelige guder menneskene i vårt århudrede ofret disse mystiske bleiene til.
Jeg antar de bruker noe liknende i Japan: "There's a product here, a powder, looks like instant soup. Some kind of enzyme. They sell it mainly to mothers with young kids. The kid has to pee, you can't get them to a toilet in time, they pee in a paper cup, an empty juice box. You drop in the contents of a handy, purse-sized sachet of this stuff, zap, it's a solid. Neutral, odorless, completely hygienic. Pop it in the trash, it's landfill." (Fra Idoru, men jeg tror det finnes i virkeligheten).
(forkortet)
Takker! Mulig jeg fikk det litt motsatt, at det er bakgrunn som blir "zoomet inn", mens hovedpersonen er stort sett like stor, men det varierer vel litt fra film til film og med hva man vil oppnå. Uansett, en "highly unsettling effect", som beskrevet i wikipedia-artikkelen.
