Snedige ting du lurer på V.2
Noen som kan forklare hvordan varmepumpe funker?
http://en.wikipedia.org/wiki/Heat_pump
Heat pumps have the ability to move heat energy from one environment to another, and in either direction. This allows the heat pump to both bring heat into an occupied space, and take it out. In the cooling mode a heat pump works the same as an ordinary air conditioner (A/C). A heat pump uses an intermediate fluid called a refrigerant which absorbs heat as it vaporizes and releases the heat when it condenses. It uses an evaporator to absorb heat from inside an occupied space and rejects this heat to the outside through the condenser. The refrigerant flows outside of the space to be conditioned, where the condenser and compressor are located, while the evaporator is inside. The key component that makes a heat pump different from an A/C is the reversing valve. The reversing valve allows for the flow direction of the refrigerant to be changed. This allows the heat to be pumped in either direction.
Since the heat pump or refrigerator uses a certain amount of work to move the refrigerant, the amount of energy deposited on the hot side is greater than taken from the cold side. One common type of heat pump works by exploiting the physical properties of an evaporating and condensing fluid known as a refrigerant.
The working fluid, in its gaseous state, is pressurized and circulated through the system by a compressor. On the discharge side of the compressor, the now hot and highly pressurized vapor is cooled in a heat exchanger, called a condenser, until it condenses into a high pressure, moderate temperature liquid. The condensed refrigerant then passes through a pressure-lowering device also called a metering device like an expansion valve, capillary tube, or possibly a work-extracting device such as a turbine. The low pressure, liquid refrigerant leaving the expansion device enters another heat exchanger, the evaporator, in which the fluid absorbs heat and boils. The refrigerant then returns to the compressor and the cycle is repeated.
Lyshastigheten er alltid konstant, uansett hvor og hva du måler. Det er kjent som relativitet. Om du selv kjører nesten i lyshastigheten, så vil lyset fortsatt gå fra deg med lyshastigheten.
Men hva om man kjører i lyshastigheten? Hvordan ser lys ut da?
Korfor bruker spanjoler både í og ì. hva er forskellen?
De to ulike typene aksent-tegn gir henholdsvis lukket (smal) eller åpen (bred) uttale av vokalen. På norsk har stort sett bare den første typen (akutt aksent) over trykksterk e, som i idé, kafé, André, finér osv. Står aksenttegnet den andre veien (grav aksent) ligner uttalen av e-en mer på en æ, kafè skal altså uttales omtrent kafæ.
Tilsvarende for a: á uttales som en trykksterk a, mens à uttales omtrent som å, f.eks i 2 epler à kr 3 (dette er omtrent den eneste forekomsten av grav-aksent i norsk).
Hvordan ì og í uttales på spansk er jeg dog usikker på, jeg kan ikke spansk.
Apropos lyshastighet og noe som ble diskutert for litt siden; hvorfor det finnes et absolutt nullpunkt, men ingen maks temperatur:
Det forenklede svaret er at atomene beveger seg raskere jo varmere det er, og når de står stille blir det ikke kaldere. Hvorfor er det ikke et «absolutt makspunkt» når de når lysets hastighet?
Fordi temperatur er ikke bare et mål for gjennomsnittshastigheten til molekylene/atomene i en gass, men et mål for gjennomsnittet til den kinetiske energien til molekylene: E=1/2mv^2
Klarer noen å finne ut hvor Rick Astley gikk på (videregående) skole (han sluttet på skolen i 1982), jeg har googlet i evigheter nå, og det ser ikke ut som at svaret finnes på internettet :(
Endret av ;_;
