Snedige ting du lurer på V.2
Jeg spør igjen; gjør det mer vondt å trekke visdomstenner enn vanlige tenner? Og da selvfølgelig med bedøvelse.
Etter det jeg har hørt har visdomstenner dypere røtter enn vanlige tenner. Vil tro at det da blir vondere, om da bedøvelsen ikke fungerer helt.
Tror det må variere en del fra person til person, for det gjorde ikke vondt i det hele tatt å trekke mine. Å sette bedøvelse var det mest ubehaglige, og det føles litt sært etterpå, men selve trekkinga gjorde ikke vondt i det hele tatt. :)
Dead on arrival antar jeg?
Dead on arrival or DOA is a term used to indicate that a patient was found to be dead upon the arrival of professional medical assistance such as a hospital, often in the form of first responders such as emergency medical technicians, paramedics, or police. In some jurisdictions, first responders must consult with an online physician before officially pronouncing a patient deceased, but once cardiopulmonary resuscitation is initiated, it must be continued until a physician can pronounce the patient dead.
http://en.wikipedia.org/wiki/Dead_on_arrival
Det gir jo ingen mening å blande vannet med en væske som har en høyere saltkonsentrasjon enn blodet. Nyrene fungerer så vidt meg bekjent gjennom diffusjon.
Wikipedia:
Although it is clear that a human cannot survive on seawater alone, some people claim that one can drink up to two cups a day, mixed with fresh water in a 2:3 ratio, without ill effect. The French physician Alain Bombard claimed to have survived an ocean crossing in a small raft using only seawater and other provisions harvested from the ocean, but the veracity of his findings was challenged. In Kon-Tiki, Thor Heyerdahl reported drinking seawater mixed with fresh in a 40/60% ratio. A few years later another adventurer named William Willis claimed to have drunk two cups of seawater and one cup of fresh per day for 70 days without ill effect when he lost his water supply.
Ut i fra dette, og også diverse andre overlevelseshistorier trekker jeg den slutningen at det faktisk er mulig.
Artikkel
Endret av b-real
Fjernet unødvendig bruk av quote
Enkelte innlegg er blitt redigert grunnet overdreven eller feil bruk av quotefunksjon. Vær vennlig å passe på å quote det du svarer på og ikke mer enn det. I utgangspunktet skal man ikke quote mer enn maks to innlegg bakover. Dette for å gjøre det mest mulig oversiktlig. Ved quoting av veldig mye tekst, eller om bruker finner det nødvendig å quote flere innlegg bakover så oppfordres man til å bruke skjul funksjonen.
Dette innlegget skal ikke kommenteres, da det er off-topic. Reaksjon på moderering gjøres eventuelt på pm. Tilbakemelding av generell karakter kan gjøres i Tilbakemeldinger om forumet.
Hva hadde skjedd hvis en elefant hadde hoppet?
Sannsynligvis brukket bena eller fått smertefulle strekk i muskler og sener. Å lande etter et hopp kan lett gi mye større øyeblikksbelastning per ben enn det å stå rimelig i ro på to ben.
Hvordan regner man ut arealet av en eggformet sirkel?
Hvis du først har funnet noe så uvanlig som et sirkelformet egg så er det bare å bruke
A = pi * r2
Da airbaggen kom, tok den masse liv. Folk trodde at de bare trengte airbaggen og ikke trengte å bruke belte.
Folk kan være dumme :D
Omtrent som når folk kjøper firehjulstrekkere og skor de med sommerdekk om vinteren.
"Jeg har jo firehjulstekk så jeg trenger ikke vinterdekk". Eller når folk prøver å få grep på glatt føre ved å tråkke gasspedalen helt inn.
- Kun to ting er uendelige: menneskenes idioti og universet. Jeg er ikke en gang sikker på sistnevnte. - Sitat Albert Einstein. :)
Hadde den skullet klare å hoppe særlig høyt, hadde uansett sener, muskler, ledd og bein måttet være sterkere. Med riktig landeteknikk vil de samme kroppsdelene få mye av den samme belastningen som i hoppet.
Endret av kjaks
Wikipedia:
Artikkel
Hvorfor poster du en link uten å lese den selv? Det som står der er vel akkurat det samme som jeg skrev?
Accidentally consuming small quantities of clean seawater is not harmful, especially if the seawater is consumed along with a larger quantity of fresh water. However, consuming seawater to maintain hydration is counterproductive; in the long run, more water must be expended to eliminate the seawater's salt (through excretion in urine) than the amount of water that is gained from drinking the seawater itself.
A = pi * r2
Sirkelformetm egg? Jeg snakket om en eggformet sirkel :) Altså som drar litt ut på toppen men ikke i bunnen, eller på sidene.
Endret av Applebee
A = pi * r2
Du ble erta fordi du sa sirkel istedet for runding tror jeg :p
