[løst]Får ikke lyd i arch
Har fått ett nytt problem. Får ikke lyd i det hele tatt. Siden jeg har veldig lite peiling på hva dette kommer av og hva som burde pastes her håper jeg noen kan hjelpe meg og si hva de trenger av output.
Klikk for å se/fjerne innholdet nedenfor
Hei. Har ett stort problem med å kjøre gnome i arch. Har installert det på følgende måte:
#pacman -Syu
#pacman -S xorg
#pacman -S x86-video-sis
#xorgconfig
#pacman -S gnome
Så installerte jeg ati driverne ved å kjøre:
#./ati-driver-*
#aticonfig --initial
Etter dette forsøkte jeg å kjøre:
$startx
Da fikk jeg denne feilmeldingen:
(EE)AIGLX error: dlsym for __driCreateNewScreen_20050727 failed (/usr/lib/xorg/modules/dri/fglrx_dri.so: undefined symbol: __driCreateNewScreen_20050727)
(EE)AIGLX: reverting to software rendering
The XKEYBOARD keymap compiler (xkbcomp) reports:
>Warning: Type "ONE_LEVEL" has 1 levels, but <RALT> has 2 symbols
>Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
/etx/X11/xinit/xinitrc: line 28: twm: command not found
Warning: locale not supported by xlib, locale set to C
xterm: fatal IO error 32 (Broken pipe) or KillClient on X server ":0.0"
waiting for X server to shut down FreeFontPath.
FPE "/usr/share/fonts/misc" refcount is 2, should be 1; fixing.
Dette er min xorg.conf
# File generated by xorgconfig.
# Copyright 2004 The X.Org Foundation
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# The X.Org Foundation BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
# WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
# OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
# Except as contained in this notice, the name of The X.Org Foundation shall
# not be used in advertising or otherwise to promote the sale, use or other
# dealings in this Software without prior written authorization from
# The X.Org Foundation.
# Refer to the xorg.conf(5) man page for details about the format of
# this file.
# Module section -- this section is used to specify
# which dynamically loadable modules to load.
# Files section. This allows default font and rgb paths to be set
# Server flags section.
# Input devices
# Core keyboard's InputDevice section
# Core Pointer's InputDevice section
# Other input device sections
# this is optional and is required only if you
# are using extended input devices. This is for example only. Refer
# to the xorg.conf man page for a description of the options.
# Section "InputDevice"
# Identifier "Mouse2"
# Driver "mouse"
# Option "Protocol" "MouseMan"
# Option "Device" "/dev/mouse2"
# EndSection
# Identifier "spaceball"
# Driver "magellan"
# Option "Device" "/dev/cua0"
# EndSection
# Identifier "spaceball2"
# Driver "spaceorb"
# EndSection
# Identifier "touchscreen0"
# Driver "microtouch"
# Option "Device" "/dev/ttyS0"
# Option "MinX" "1412"
# Option "MaxX" "15184"
# Option "MinY" "15372"
# Option "MaxY" "1230"
# Option "ScreenNumber" "0"
# Option "ReportingMode" "Scaled"
# Option "ButtonNumber" "1"
# Option "SendCoreEvents"
# EndSection
# Identifier "touchscreen1"
# Driver "elo2300"
# Option "MinX" "231"
# Option "MaxX" "3868"
# Option "MinY" "3858"
# Option "MaxY" "272"
# Option "ButtonThreshold" "17"
# EndSection
# Monitor section
# Any number of monitor sections may be present
# Graphics device section
# Any number of graphics device sections may be present
# Standard VGA Device:
# Device configured by xorgconfig:
# Screen sections
# Any number of screen sections may be present. Each describes
# the configuration of a single screen. A single specific screen section
# may be specified from the X server command line with the "-screen"
# option.
# ServerLayout sections.
# Any number of ServerLayout sections may be present. Each describes
# the way multiple screens are organised. A specific ServerLayout
# section may be specified from the X server command line with the
# "-layout" option. In the absence of this, the first section is used.
# When now ServerLayout section is present, the first Screen section
# is used alone.
# Section "DRI"
# Mode 0666
# EndSection
Section "ServerLayout"
# The Identifier line must be present
# Each Screen line specifies a Screen section name, and optionally
# the relative position of other screens. The four names after
# primary screen name are the screens to the top, bottom, left and right
# of the primary screen. In this example, screen 2 is located to the
# right of screen 1.
# Each InputDevice line specifies an InputDevice section name and
# optionally some options to specify the way the device is to be
# used. Those options include "CorePointer", "CoreKeyboard" and
# "SendCoreEvents".
Identifier "Simple Layout"
Screen 0 "aticonfig-Screen[0]" 0 0
InputDevice "Mouse1" "CorePointer"
InputDevice "Keyboard1" "CoreKeyboard"
EndSection
Section "Files"
# The location of the RGB database. Note, this is the name of the
# file minus the extension (like ".txt" or ".db"). There is normally
# no need to change the default.
# RgbPath "/usr/share/X11/rgb"
# Multiple FontPath entries are allowed (which are concatenated together),
# as well as specifying multiple comma-separated entries in one FontPath
# command (or a combination of both methods)
# FontPath "/usr/share/fonts/TTF"
# FontPath "/usr/share/fonts/Type1"
# FontPath "/usr/lib/X11/fonts/local/"
# FontPath "/usr/lib/X11/fonts/misc/"
# FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
# FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
# FontPath "/usr/lib/X11/fonts/Speedo/"
# FontPath "/usr/lib/X11/fonts/Type1/"
# FontPath "/usr/lib/X11/fonts/TrueType/"
# FontPath "/usr/lib/X11/fonts/freefont/"
# FontPath "/usr/lib/X11/fonts/75dpi/"
# FontPath "/usr/lib/X11/fonts/100dpi/"
# The module search path. The default path is shown here.
# ModulePath "/usr/lib/modules"
FontPath "/usr/share/fonts/misc"
FontPath "/usr/share/fonts/100dpi:unscaled"
FontPath "/usr/share/fonts/75dpi:unscaled"
EndSection
Section "Module"
# This loads the DBE extension module.
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
# This loads the font modules
# Load "type1"
# This loads the GLX module
# Load "glx"
# This loads the DRI module
# Load "dri"
Load "dbe" # Double buffer extension
SubSection "extmod"
Option "omit xfree86-dga" # don't initialise the DGA extension
EndSubSection
Load "freetype"
# Load "xtt"
EndSection
# For most OSs the protocol can be omitted (it defaults to "Standard").
# When using XQUEUE (only for SVR3 and SVR4, but not Solaris),
# uncomment the following line.
# Option "Protocol" "Xqueue"
# Option "Xleds" "1 2 3"
# Option "LeftAlt" "Meta"
# Option "RightAlt" "ModeShift"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults). For example, for a non-U.S.
# keyboard, you will probably want to use:
# Option "XkbModel" "pc105"
# If you have a US Microsoft Natural keyboard, you can use:
# Option "XkbModel" "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
# Option "XkbLayout" "de"
# or:
# Option "XkbVariant" "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
# Option "XkbOptions" "ctrl:swapcaps"
# These are the default XKB settings for Xorg
# Option "XkbRules" "xorg"
# Option "XkbLayout" "us"
# Option "XkbVariant" ""
# Option "XkbOptions" ""
# Option "XkbDisable"
Identifier "Keyboard1"
Driver "kbd"
Option "AutoRepeat" "500 30"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
Option "XkbModel" "pc102"
Option "XkbLayout" "no"
EndSection
# Identifier and driver
# the following line.
# Mouse-speed setting for PS/2 mouse.
# Option "Resolution" "256"
# Baudrate and SampleRate are only for some Logitech mice. In
# almost every case these lines should be omitted.
# Option "BaudRate" "9600"
# Option "SampleRate" "150"
# Mouse wheel mapping. Default is to map vertical wheel to buttons 4 & 5,
# horizontal wheel to buttons 6 & 7. Change if your mouse has more than
# 3 buttons and you need to map the wheel to different button ids to avoid
# conflicts.
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)
# Option "Emulate3Buttons"
# Option "Emulate3Timeout" "50"
# ChordMiddle is an option for some 3-button Logitech mice
# Option "ChordMiddle"
Identifier "Mouse1"
Driver "mouse"
Option "Protocol" "Auto" # Auto detect
Option "Device" "/dev/input/mice"
# When using XQUEUE, comment out the above two lines, and uncomment
Option "ZAxisMapping" "4 5 6 7"
# Emulate3Buttons is an option for 2-button mice
EndSection
Section "Monitor"
# HorizSync is in kHz unless units are specified.
# HorizSync may be a comma separated list of discrete values, or a
# comma separated list of ranges of values.
# NOTE: THE VALUES HERE ARE EXAMPLES ONLY. REFER TO YOUR MONITOR'S
# USER MANUAL FOR THE CORRECT NUMBERS.
# HorizSync 30-64 # multisync
# HorizSync 31.5, 35.2 # multiple fixed sync frequencies
# HorizSync 15-25, 30-50 # multiple ranges of sync frequencies
# VertRefresh is in Hz unless units are specified.
# VertRefresh may be a comma separated list of discrete values, or a
Identifier "My Monitor"
HorizSync 31.5 - 48.5
VertRefresh 50.0 - 70.0
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Device"
# The chipset line is optional in most cases. It can be used to override
# the driver's chipset detection, and should not normally be specified.
# Chipset "generic"
# The Driver line must be present. When using run-time loadable driver
# modules, this line instructs the server to load the specified driver
# module. Even when not using loadable driver modules, this line
# indicates which driver should interpret the information in this section.
# The BusID line is used to specify which of possibly multiple devices
# this section is intended for. When this line isn't present, a device
# section can only match up with the primary video device. For PCI
# devices a line like the following could be used. This line should not
# normally be included unless there is more than one video device
# intalled.
# BusID "PCI:0:10:0"
# VideoRam 256
# Clocks 25.2 28.3
Identifier "Standard VGA"
Driver "vga"
VendorName "Unknown"
BoardName "Unknown"
EndSection
#Section "Device"
# unsupported card
#VideoRam 256
# Insert Clocks lines here if appropriate
# Identifier "My Video Card"
# Driver "vga"
#EndSection
Section "Device"
Identifier "aticonfig-Device[0]"
Driver "fglrx"
EndSection
Section "Screen"
Identifier "Screen 1"
Device "My Video Card"
Monitor "My Monitor"
DefaultDepth 8
SubSection "Display"
Viewport 0 0
Depth 8
Modes "640x400"
EndSubSection
Viewport 0 0
Depth 16
Modes "640x480"
EndSubSection
Viewport 0 0
Depth 24
Modes "640x480"
EndSubSection
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]"
Device "aticonfig-Device[0]"
Monitor "aticonfig-Monitor[0]"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Måtte installere xterm gjennom pacman, siden jeg fikk en feilmelding om at xterm trengtes, men ikke fantes. Men twm finnes visstnok ikke i repoet til pacman.
Håper noen kan hjelpe meg så jeg får opp metacity.
Endret av NevroMance
Ja det er riktig, legg til hal også hvis du vil at harddisker og cd/dvd rommen din skal mountes automatisk, legg også til alsa for at arch skal huske lyd instillingene.
EDIT: ang. ati drivern, slett ati drivern du installerte, installer pakken "fglrx" og "fglrx-utils" via pacman, ikke rør org.conf, du kan møte på problemer ved å bruke ati pakken lastet ned fra ati.com, fglrx pakken er ati drivern testet på arch.
Endret av roberth1990
Takk. Fikk fikset til ati driverne fra repoet. Men får derimot ikke sjekket om jeg mesa eller ati driverne. fglrxinfo gir meg bare:
[martin@myhost ~]$ fglrxinfo
Xlib: extension "GLX" missing on display ":0.0".
Error: couldn't find RGB GLX visual!
Har heller ikke fått til lyden enda. På system->user->sound får jeg beskjeden:
audiotestsrc wave=sine freq=512 ! audioconvert ! audioresample ! gconfaudiosink: Could not open resource for writing.
uansett om jeg forsøker med alsa eller oss driverne. Kommer vel fort flere spørsmål etterhvert også, men de er vel de to jeg har atm.
Tusen takk for all hjelpen hittil.
