Readyboost og PCMCIA cf leser til laptop?
Er det mulig å bruke et PCMCIA CF leser kort sammen med feks et sandisk extreme 8gb for å booste vista? usb penn er uinteressant for min del, ser etter noe som kan stå permanent i maskinen og ikke stikker ut (har allerede 2gb minne installert da, men bruker maskinen til 3d, så...) Hva er overføringsgrensen som vista setter for at det aksepterer flash minne? Går det ann å legge swap fila der?
For a device to be compatible and useful it must conform to the following requirements:
    * The capacity of the removable media must be at least 256 MB (250 after formatting)
    * Devices larger than 4 GB will have only 4 GB used for ReadyBoost
    * The device should have an access time of 1ms or less
    * The device must be capable of 2.5 MB/s read speeds for 4 KB random reads spread uniformly across the entire device and 1.75 MB/s write speeds for 512 KB random writes spread uniformly across the device
    * The device must have at least 235 MB of free space
    * NTFS and FAT32 are supported
    * The initial release of ReadyBoost supports one device
Wikipedia: Readyboost
