LOST Kommer ikke inn pa Ubuntu webserver fra andre
Hvordan sjekke mener du? De virker jo @ localhost, sa jeg har konfigurert dem sapass.
Jeg har endret hjemmemappen
NameVirtualHost *
<VirtualHost *>
ServerAdmin [email protected]
DocumentRoot /home/stale/www/
<Directory />
  Options FollowSymLinks
  AllowOverride None
</Directory>
<Directory /home/stale/www/>
  Options Indexes FollowSymLinks MultiViews
  AllowOverride None
  Order allow,deny
  allow from all
  # This directive allows us to have apache2's default start page
                # in /apache2-default/, but still have / go to the right place
                #RedirectMatch ^/$ /apache2-default/
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
  AllowOverride None
  Options ExecCGI -MultiViews +SymLinksIfOwnerMatch
  Order allow,deny
  Allow from all
</Directory>
ErrorLog /var/log/apache2/error.log
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
CustomLog /var/log/apache2/access.log combined
ServerSignature On
    Alias /doc/ "/usr/share/doc/"
    <Directory "/usr/share/doc/">
        Options Indexes MultiViews FollowSymLinks
        AllowOverride None
        Order deny,allow
        Deny from all
        Allow from 127.0.0.0/255.0.0.0 ::1/128
    </Directory>
</VirtualHost>
Ja selvfolgelig :p
Det er main-PCen min
Webserveren virker fra localhost, men ikke fra noe andre steder.
Det ser vel ut om access denied? Men jeg far ikke loadet adressen engang. Jeg har gjort
$ sudo chmod 777 /home/stale/www
men virker ikke
har ikke noe .htaccess fil i mappen.
  AllowOverride None
  Order allow,deny
  allow from all
</Directory>
Er argumentene til direktivene i httpd.conf case sensitive kanskje?
"allow" -> "Allow", "all"->"All", "deny"->"Deny" *wild guess*
Edit:
Directives in the configuration files are case-insensitive, but arguments to directives are often case sensitive.
Vel, argumentet her er vel egentlig bare katalognavnet og ikke det andre.
Hvilken versjon er det snakk om forresten?
Edit2:
Du har verken brukt Listen- eller Port-direktivet noe sted såvidt jeg kan se (vet ikke om det er nødvendig), men default er sannsynligvis port 80. Kan du bekrefte med netstat -l at du har en (TCP)-forbindelse som lytter til port 80 (sjekk lista på toppen)?
Det funker ikke å telnet'e til webservern heller?
telnet ip.adr.es.se 80
Den bare henger med "Trying ip.adr.es.se..." ?
Endret av kommers
