WC3:TFT: Får ikke hosta på nettet, hjelp å få?
Hei.
Jeg har lest litt rundt på nettet, da spesielt på portforward.com. Der står det at WC3 bruker portene 6112 - 6119. Da er det vel disse jeg må åpne i ruteren for å få hosta online? Det var i hvert fall det jeg trodde, men jeg tok feil virker det som. Da jeg skulle prøve å gjøre dette, går det ikke. Det er ingen som kommer inn på gamen uansett hvor lenge jeg venter.
Jeg har også skrudd av firewall.
Er det noen som vet hva jeg må gjøre? Har jeg kanskje gjort det feil til nå?
dette er sakset rett ut fra blizzard sin hjemmeside. Du kan se om det hjelper.
Other people are not able to join my Warcraft III custom Battle.net games
The main reasons for this problem are:
You are using Internet Connection Sharing.
Your Firewall is blocking the data Warcraft III is trying to send/receive.
Your Router and/or Warcraft III are not configured to forward data, on the port Warcraft III is checking, to the other computers on your network.
Firewalls:
Make sure you have the latest updates installed from your Firewall manufacturer
By default Warcraft III uses port 6112, use the following steps to check the current port your version of Warcraft III is trying to use
Start Warcraft III
Click Options
Click Gameplay
Approximately half way down the screen you will see Game Port, this is the port you will need to make sure your Firewall is not blocking incoming or outgoing
Try playing the game
Routers and Warcraft III:
Make sure you have the latest updates installed from your Router manufacturer.
Configure the Game Port Warcraft III will use on each computer:
Start Warcraft III on each computer
Click Options
Click Gameplay
Approximately half way down the screen you will see Game Port, each of your computers will need to use a different port
Example: Computer #1 can use port 6112, computer #2 can use port 6113, computer #3 can use port 6114, and so on.
Configure your Router to forward the incoming data for port x to the computer where you setup Warcraft III to use that port
For more information on configuring your router, please contact your router manufacturer.
