MrJavalava Skrevet 19. august 2007 Rapporter Del Skrevet 19. august 2007 Jeg bare håper at 9800 eller 8900 eller hva som blir mest interessant å kjøpe, ikke blir for dyre (meh). Men så er det bare to produsenter av skjermkort for øyeblikket, der de ikke er i balanse iforhold til ytelse, så prisene blir deretter. Lenke til kommentar
HaxyQ Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 Om jeg kjøper 9800, så er det heller ikek bare for 10.1. Men lurer på om det er verdt pengene siden jeg ikke har PCI-E 2.0. Lenke til kommentar
yokomoko Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 Du mener at hovedkortet må støtte 2.0 pci-e? Lenke til kommentar
Mr_Motsatt Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 G92 will be released in November 2007 timeframe in the form of "GeForce 9800" series. "G92" GeForce 9800 GTX specs. - 65nm process technology at TSMC. - Over one billion transistors. - Second Generation Unified Shader Architecture. - Double precsion support (FP64). - GPGPU native. - Over one TeraFLOPS of shader processing power. - MADD+ADD configuration for the shader untis (2+1 FLOPS=3 FLOPS per ALU) - Fully Scalar design. - 512-bit memory interface. - 1024MB GDDR4 graphics memory. - DirectX 10.1 support. - OpenGL 3.0 Support. - eDRAM die for "FREE 4xAA". - built in Audio Chip. - built in tesselation unit (in the graphics core" - Improved AA and AF quality levels Pros. 65nm process will allow for better yields and better power consumption. power consumption will be lower than that of a GeForce 8800 GTX. GeForce 9800 GTX will be over two times faster than a GeForce 8800 Ultra in real world games and applcations. Release date : November 2007. There will be TWO products at launch: The flagship GeForce 9800 GTX and the second fastest GeForce 9800 GTS. price for the GeForce 9800 GTX will be 549-649 USD. price for the GeForce 9800 GTS will be 399-449 USD. ------------------------------------------------------------------------------------------------ Ett spec rykte som går på diverse forum, og stammer fra en xbitlabs.com tråd.. NB! er ikke offisielt men hvis det er...Wow Lenke til kommentar
MrJavalava Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 Skikkelig interessant med ett 9800 kort da.. da venter jeg hellere. Har ikke hast med å bytte noe ennda. Tenker å gå fra s939 til LGA775. Lenke til kommentar
KimmiK Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 G92 will be released in November 2007 timeframe in the form of "GeForce 9800" series. "G92" GeForce 9800 GTX specs. - 65nm process technology at TSMC. - Over one billion transistors. - Second Generation Unified Shader Architecture. - Double precsion support (FP64). - GPGPU native. - Over one TeraFLOPS of shader processing power. - MADD+ADD configuration for the shader untis (2+1 FLOPS=3 FLOPS per ALU) - Fully Scalar design. - 512-bit memory interface. - 1024MB GDDR4 graphics memory. - DirectX 10.1 support. - OpenGL 3.0 Support. - eDRAM die for "FREE 4xAA". - built in Audio Chip. - built in tesselation unit (in the graphics core" - Improved AA and AF quality levels Pros. 65nm process will allow for better yields and better power consumption. power consumption will be lower than that of a GeForce 8800 GTX. GeForce 9800 GTX will be over two times faster than a GeForce 8800 Ultra in real world games and applcations. Release date : November 2007. There will be TWO products at launch: The flagship GeForce 9800 GTX and the second fastest GeForce 9800 GTS. price for the GeForce 9800 GTX will be 549-649 USD. price for the GeForce 9800 GTS will be 399-449 USD. Old news, ble postet på side 2. Lenke til kommentar
HaxyQ Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 Åhhh. Jeg skulle gjerne kjøpt et slikt kort samt et hovedkort som støtter PCI-E 2.0, men jeg har installert Vista OEM på maskinen, og er det ikke slik at jeg ikke kan installere Vista en gang til (med samme plate/key) hvis hovedkortet er byttet ut? Lenke til kommentar
OverCaffeinatedFightrpilot Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 Åhhh. Jeg skulle gjerne kjøpt et slikt kort samt et hovedkort som støtter PCI-E 2.0, men jeg har installert Vista OEM på maskinen, og er det ikke slik at jeg ikke kan installere Vista en gang til (med samme plate/key) hvis hovedkortet er byttet ut? 9322850[/snapback] er vel hardisken det går på? Lenke til kommentar
MrJavalava Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 Du har poengsystem i Vista OEM så vidt jeg vet.. Og ja, ett 9800 kort ville være fint det =D Lenke til kommentar
yokomoko Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 (endret) Har noen noe eksempel på hvilke hovedkort som har 2.0 PCI-E? Endret 20. august 2007 av yokomoko Lenke til kommentar
OverCaffeinatedFightrpilot Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 (endret) Har noen noe eksempel på hvilke hovedkort som har 2.0 PCI-E? 9322882[/snapback] se på dagens nyheter på hovedsiden... edit: leif Endret 20. august 2007 av twintip Lenke til kommentar
HaxyQ Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 Vista OEM låser seg til hovedkortet, ikke harddisken. Poengsystemet var noe alle trodde, men så ble det kjent at det bare var bullshi*. Lenke til kommentar
yokomoko Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 Så det finnes ingen HK som støtter 2.0 PCI-E per dags dato? Lenke til kommentar
HKS Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 Så det finnes ingen HK som støtter 2.0 PCI-E per dags dato? 9323033[/snapback] Nei, Men PCI Express 2.0 er bakover kompatibel med PCI Express 1.1 Lenke til kommentar
yokomoko Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 Kan du skrive på norske Skjønner meg så mye på data... Lenke til kommentar
HaxyQ Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 Du kan bruke et slikt skjermkort (PCI-E 2.0) på et hovedkort som i utgangspunktet kun kjører PCI-E 1.1. Lenke til kommentar
Zerd Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 Så det finnes ingen HK som støtter 2.0 PCI-E per dags dato? 9323033[/snapback] Nei, Men PCI Express 2.0 er bakover kompatibel med PCI Express 1.1 9323064[/snapback] Har du kilde til det? Vil kjøpe hovedkort nå (P35), og G9x skjermkort senere. Enda litt info: http://www.hartware.de/news_42815.html (kan oversettes via f.eks. babelfish) Lenke til kommentar
smy Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 (endret) synd du ikke kan sett pcie v 1.0 kort i mb med pcie 2.0 men kommer vel hovedkort med begge 2 pcie spec regn jeg med så mer her http://support.asus.com/faq/faq.aspx?no=DE...SLanguage=en-us Endret 20. august 2007 av lordsmygen Lenke til kommentar
yokomoko Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 Raptor,20/08-2007 : 17:50]Så det finnes ingen HK som støtter 2.0 PCI-E per dags dato? 9323033[/snapback] Nei, Men PCI Express 2.0 er bakover kompatibel med PCI Express 1.1 9323064[/snapback] Har du kilde til det? Vil kjøpe hovedkort nå (P35), og G9x skjermkort senere. Enda litt info: http://www.hartware.de/news_42815.html (kan oversettes via f.eks. babelfish) 9323513[/snapback] Vil også kjøpe g9x senere Lenke til kommentar
HKS Skrevet 20. august 2007 Rapporter Del Skrevet 20. august 2007 (endret) Har du kilde til det? Vil kjøpe hovedkort nå (P35), og G9x skjermkort senere. Enda litt info: http://www.hartware.de/news_42815.html (kan oversettes via f.eks. babelfish) 9323513[/snapback] Ja, det jar jeg. PCI-SIG (Gruppen som standardiserer PCI) Yes. The PCIe Base 2.0 specification supports both the 2.5GT/s and 5GT/s signaling technologies. A device designed to the PCIe Base 2.0 specification may support 2.5GT/s, 5GT/s or both. However, a device designed to operate specifically at 5GT/s must also support 2.5GT/s signaling. http://www.pcisig.com/news_room/faqs/pcie2.0_faq/ synd du ikke kan sett pcie v 1.0 kort i mb med pcie 2.0 9323600[/snapback] Jo, du kan ha PCI Express 1.0 kort i hovedkort med PCI Express 2.0. Noe PCI-SIG klart sier i sin FAQ. The PCIe Base 2.0 specification supports both 2.5GT/s and 5GT/s signaling rates, in order to retain backward compatibility with existing PCIe 1.0 and 1.1 systems. http://www.pcisig.com/news_room/faqs/pcie2.0_faq/ Endret 20. august 2007 av [GDI]Raptor Lenke til kommentar
