G9x info tråd
Gjest Slettet+6132
De har vel samme festepunkter som G80... (?)
8800gt har ikke samme festepunktene som G80, de deler festepunkter med 7900gt.
Er ihvertfall det jeg skjønner utifra tester.
Stemmer det. :)
Siterer Intern øverst på side 46:
8800GT har ikke IHS, så om dere skal bytte kjøler, pass på å ikke sette den for hardt fast.
In fact, GeForce 8800GT graphics card can use previously coolers applied to ATI X1800/X1900, NVIDIA GeForce 7900/7800 (not 7800 GS) / 7600/6800 graphics third parties coolers. We listed some applicable coolers:
Thermalright HR-03(not Plus)、V2 Thermalright HR-03 (not Plus), V2
Apack GX815、GX810 Apack GX815, GX810
Zalman VF900、ZV9、VF1000 Zalman VF900, ZV9, VF1000
Fant nettopp dette.
This would be mean the additional 16 shader units exist on all GeForce 8800 GT cards, but are disabled for yield or marketing purposes. In addition to the extra shaders, the new G92 will also feature higher core frequencies and support for up to 1GB GDDR3.
The new 65nm G92 has a tentative SKU designation of GeForce 8800 GTS. This might sound confusing as NVIDIA already sports a GeForce 8800 GTS card based on the 90nm G80 silicon. However, since G92 sports a 256-bit memory interface, the new 8800 GTS cards will feature traditional memory blocks of 512MB or 1024MB. The older, G80-based GeForce 8800 GTS features 320-bit memory blocks of 320MB or 640MB.
As the new GeForce 8800 GT generally outpaces the existing GeForce 8800 GTS, the new GeForce 8800 GTS will likely surpass NVIDIA's high-end GeForce 8800 GTX and potentially GeForce 8800 Ultra.
Hvordan kan den egentlig gjøre det?
Er det ikke slik at den får litt lavere frekvenser enn GTX og Ultra da?
Litt ekstra minne tviler jeg på vil utgjøre en særlig forskjell.
Endret av andrull
Oversatt fra kinesisk med Google translate:
Ying Chi 8800 GT and NVIDIA using the same version of the core, memory isolated power supply design, the core of three-phase power supply using rare design, but with a more than solid Sanyo OSCON confined防磁inductance and capacitance, as well as PWM IC. 同时,显卡采用了两个外接电源辅助供电来保证显卡的稳定工作。 At the same time, card uses two external power auxiliary power supply to ensure the stability of graphics work. 这种设计也使得显卡的超频空间更大,超频性能完全超越了NVIDIA公版。 This design also makes cards for overclocking greater overclocking performance NVIDIA completely beyond the public version. 而且,该产品的频率在出厂前就已经被OC过,目前默认的核心/Shader/显存频率为630/1600/1800MHz,比公版有所提高。 Moreover, the frequency of the products manufactured in the former OC had already been at the core of the default / Shader / memory frequency is 630/1600/1800 MHz, than the version has improved.
EVGA's SSC modell av GTen kan vel bli interessant, skal hoppe innom fry's senere i kveld for å ta en titt på hva som egentlig er ute her og ikke.
Forøvrig ser det ikke ut som GT er upopulært akkurat, alle mindre detaljister var utsolgte for kort den 29ende.
Endret av Lilac1
Fant nettopp dette.
Kan virke som at nye GTS vil få noenlunde like frekvenser, om ikke litt høyere kjerne og shader-frekvenser enn GTX/Ultra. :)
Ser ut til at kjøleren fortsatt vil være den samme også.
(Med dagens 8800GTS-kjøler bør den tross alt klare litt høyere frekvenser på 65nm kontra 90nm)
ThermalRight lanserer kjøler spesielt ment til 8800GT:
ThermalRight HR03GT. :)
