kakkle Skrevet 2. juni 2007 Del Skrevet 2. juni 2007 (endret) Hei Jeg har hatt litt problemer nå en stund med å skrive ut lokalt. Det har tidligere fungert uten problemer, men for rundt en måneds tid siden, så får jeg ikke skrevet ut lokalt. Det går helt fint å skrive ut fra en annen pc i nettverket, via cups på maskinen. Litt info om systemet: Dist: Ubuntu 6.06 LTS Printer: Canon i990 Cups versjon: 1.2.2 Bruker drivere fra canon i japan eller no... Har ihvertfall fungert smertefritt tidligere. Har også prøvd med drivere via turboprint (Free Edition), uten at det hjalp. cupsd.conf: # Show troubleshooting information in error_log. LogLevel info SystemGroup lpadmin # Enable printer sharing and shared printers. Browsing On BrowseOrder allow,deny BrowseAllow @LOCAL BrowseAddress @LOCAL DefaultAuthType Basic <Location /> # Allow shared printing and remote administration... Order allow,deny Allow @LOCAL </Location> <Location /admin> # Allow remote administration... Order allow,deny Allow @LOCAL </Location> <Location /admin/conf> AuthType Basic Require user @SYSTEM # Allow remote access to the configuration files... Order allow,deny Allow @LOCAL </Location> <Policy default> <Limit Send-Document Send-URI Hold-Job Release-Job Restart-Job Purge-Jobs Set-Job-Attributes Create-Job-Subscription Renew-Subscription Cancel-Subscription Get-Notifications Reprocess-Job Cancel-Current-Job Suspend-Current-Job Resume-Job CUPS-Move-Job> Require user @OWNER @SYSTEM Order deny,allow </Limit> <Limit Pause-Printer Resume-Printer Set-Printer-Attributes Enable-Printer Disable-Printer Pause-Printer-After-Current-Job Hold-New-Jobs Release-Held-New-Jobs Deactivate-Printer Activate-Printer Restart-Printer Shutdown-Printer Startup-Printer Promote-Job Schedule-Job-After CUPS-Add-Printer CUPS-Delete-Printer CUPS-Add-Class CUPS-Delete-Class CUPS-Accept-Jobs CUPS-Reject-Jobs CUPS-Set-Default> AuthType Basic Require user @SYSTEM Order deny,allow </Limit> <Limit CUPS-Authenticate-Job> Require user @OWNER @SYSTEM Order deny,allow </Limit> <Limit All> Order deny,allow </Limit> </Policy> Include /etc/cups/cups.d/browse.conf # Allow remote access Port 631 Browse.conf: Browsing On /var/log/cups/error_log i info mode ved utskrift lokalt: I [02/Jun/2007:11:04:30 +0200] Full reload complete. I [02/Jun/2007:11:04:30 +0200] Listening to :::631 on fd 0... I [02/Jun/2007:11:04:30 +0200] Listening to 0.0.0.0:631 on fd 2... I [02/Jun/2007:11:04:47 +0200] Started "/usr/lib/cups/cgi-bin/printers.cgi" (pid=21244) I [02/Jun/2007:11:04:49 +0200] Adding start banner page "none" to job 156. I [02/Jun/2007:11:04:49 +0200] Adding end banner page "none" to job 156. I [02/Jun/2007:11:04:49 +0200] Job 156 queued on "Canon_i990_USB_1" by "kakkle". I [02/Jun/2007:11:04:49 +0200] Started filter /usr/lib/cups/filter/pstops (PID 21245) for job 156. I [02/Jun/2007:11:04:49 +0200] Started filter /usr/lib/cups/filter/pstoturboprint (PID 21246) for job 156. I [02/Jun/2007:11:04:49 +0200] Started backend /usr/lib/cups/backend/usb (PID 21250) for job 156. I [02/Jun/2007:11:04:51 +0200] Started "/usr/lib/cups/cgi-bin/printers.cgi" (pid=21272) print jobben forsvinner fra jobb køen, men ingenting kommer ut på skriveren. /var/log/cups/error_log i debug mode ved utskrift lokalt (testside fra cups) (OBS: Veeldig Myyye data): FJERNET Men si fra dersom det trengs noe mer informasjon EDIT: Det viste seg å være driveren som feilet. Etter en oppdatering av ett eller annet så var det vel ett eller annet som ikke var kompatibelt. Uansett... LAstet ned driverne og installerte dem på nytt, så gikk det faktisk veldig greit PS: Den turboprint saken var bare plagsom. Skrev ut en stor truboprint logo en tilfeldig plass på arket... Dette gjelder da den gratis (demo) versjonen. Regner med at det forsvinner dersom man kjøper programvaren Endret 3. juni 2007 av kakkle Lenke til kommentar
