test fra annen verden
Map Preview Flash V1.01
How to use it
goto http://img233.imageshack.us/my.php?image=m...4.swf&width=800
http://www.freewebs.com/mr0wraith/freerider/freerider.html
Copy the whole code and paste into the program.
he thick dots represent where stars are and the lines are where lines are.
-to enter a new code, just click in the textbox - press ctrl+a then delete.
Then paste the new code into the box and press enter to display
Features Hoping to add soon
-Export map to jpg
-Star location (very easy to do, just haven't had time yet)
Anyone else has comments or concerns?
Also, if someone would like to host this as well please let me know. Or someone would like to help out in the program let me know
::EDIT:: Change site server to imageshack. If this goes down, Please let me know and I will put the orignal back up. I will not be working on updates till late tonight and tomorrow.
Create QuarterPipes, Circles and convert codes to numbers are reverse.
Here is a program designed by crabsdf.
You can add a quarter pipe,wave, circle to your existing design or make one as scratch on a level.
All information should be there that is needed.
Converter-Prefab
Gjest
