DVD-brenner vil ikke brenne
Heisann.
Sitter her å prøver å brenne en Data-DVD med Nero.
Fant fort ut at detta ikke fungerte, men aner ikke hvorfor.
Det kommer 'Invalid field in command' og 'Could not perform end of Disc-at-once' feil.
Nero genererte en logfil ang. feilen, så her er den;
chaser
5C82001080100000000073825114
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Programfiler\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02.11.2004 13:54:32
NT-SPTI used
Nero Version: 7.0.1.4
Internal Version: 7, 0, 1, 4
(Nero Express)
Recorder:             <AOPEN DVRW2412PRO>       Version: 1.72 - HA 1 TA 3 - 7.0.1.4
Adapter driver:      <IDE>                     HA 1
Drive buffer  :      2048kB
Bus Type      :      default (0) -> ATAPI, detected: ?
CD-ROM:               <QB5180M  OVT445A         >Version: 1.0  - HA 1 TA 1 - 7.0.1.4
Adapter driver:      <SCSI>                    HA 1
=== Scsi-Device-Map ===
CdRomPeripheral      : AOPEN DVRW2412PRO             nvatabus Port 0 ID 0  DMA: Off
DiskPeripheral       : Maxtor 6Y080M0                nvatabus Port 2 ID 0  DMA: Off
CdRomPeripheral      : QB5180M OVT445A         1.0     dtscsi Port 3 ID 0  DMA: Off
=== CDRom-Device-Map ===
AOPEN DVRW2412PRO          D:   CDRom3
QB5180M OVT445A            E:   CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE           : 0
Physical memory     : 1023MB (1048048kB)
Free physical memory: 526MB (539168kB)
Memory in use       : 48 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
31.5.2099
UDF compilation
21:04:53	#1 Text 0 File Isodoc.cpp, Line 6411
UDF document burn settings
Determine maximum speed : FALSE
Simulate                : FALSE
Write                   : TRUE
Finalize CD             : TRUE
Multisession            : FALSE
Burning mode            : DAO
Mode                    : 1
UDF Mode                : pure
UDF Revision            : 1.02
UDF Partition Type      : physical
21:04:54	#2 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 81920KB of Memory
21:04:54	#3 Text 0 File Reader.cpp, Line 124
Reader running
21:04:54	#4 Text 0 File Writer.cpp, Line 113
Writer D: AOPEN DVRW2412PRO running
21:05:28	#5 Text 0 File Burncd.cpp, Line 3342
Turn on Disc-At-Once, using DVD media
21:05:28	#6 Text 0 File DlgWaitCD.cpp, Line 279
Last possible write address on media:  2295103 (510:01.28, 4482MB)
Last address to be written:            2239583 (497:41.08, 4374MB)
21:05:28	#7 Text 0 File DlgWaitCD.cpp, Line 291
Write in overburning mode: NO (enabled: CD)
21:05:28	#8 Text 0 File DlgWaitCD.cpp, Line 2578
Recorder: AOPEN DVRW2412PRO, Media type: DVD+R
21:05:28	#9 Text 0 File DlgWaitCD.cpp, Line 458
>>> Protocol of DlgWaitCD activities: <<<
21:05:28	#10 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
 0: TRM_DATA_MODE1 ()
    2 indices, index0 (150) not provided
    original disc pos #0 + 2239584 (2239584) = #2239584/497:41.9
    relocatable, disc pos for caching/writing not required/ required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2239584 blocks [D: AOPEN DVRW2412PRO]
21:05:28	#11 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [D: AOPEN DVRW2412PRO] for write in CUE-sheet-DAO
DAO infos:
 MCN: ""
 TOCType: 0x00; Session Closed, disc fixated
 Tracks 1 to 1:
   1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    4586668032, ISRC ""
DAO layout:
 __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
       0 |  lead-in |   0 |    0x41 | 0x00
       0 |        1 |   0 |    0x41 | 0x00
       0 |        1 |   1 |    0x41 | 0x00
 2239584 | lead-out |   1 |    0x41 | 0x00
21:05:28	#12 Text 0 File SCSIPassThrough.cpp, Line 36
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
21:05:28	#13 Phase 24 File dlgbrnst.cpp, Line 1725
Caching of files started
21:05:28	#14 Text 0 File Burncd.cpp, Line 4176
Cache writing successful.
21:05:28	#15 Phase 25 File dlgbrnst.cpp, Line 1725
Caching of files completed
21:05:28	#16 Phase 36 File dlgbrnst.cpp, Line 1725
Burn process started at 2.4x (3 324 KB/s)
21:05:29	#17 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
21:05:29	#18 SPTI -1066 File SCSIPassThrough.cpp, Line 323
D: CdRom3: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key:  0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data:   0xAD 00 00 00 00 00 00 00 08 04 00 00
Sense Area: 0x70 00 05 00 00 00 00 0C 00 00 00 00 24
Buffer x0b62cc00: Len x804
21:05:29	#19 SPTI -1066 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x24
Sense Qual: 0x00
CDB Data:   0xF9 15 01 FF 00 00 00 00 00 00 00 00
21:05:29	#20 Text 0 File DVDR.cpp, Line 6192
Drive: AOPEN    DVRW2412PRO
Book Type request [gen]: DVD-ROM, write to EEPROM
Changing the Book Type was finished successfully, return code 0
21:05:29	#21 CDR -1207 File DVDR.cpp, Line 5330
Book Type automatically set to: DVD-ROM
21:05:29	#22 Text 0 File DVDPlusRW.cpp, Line 666
Start write address at LBA 0
DVD high compatibility mode: Yes
21:05:48	#23 SPTI -1046 File SCSIPassThrough.cpp, Line 323
D: CdRom3: SCSIStatus(x02) WinError(0) NeroError(-1046)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data:   0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0C 00 00 00 00 30 05
Buffer x04f30000: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
21:05:48	#24 CDR -1046 File Writer.cpp, Line 302
Illegal disc
21:05:48	#25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
21:05:48	#26 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
21:05:48	#27 SPTI -1066 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x24
Sense Qual: 0x00
CDB Data:   0x00 00 00 00 00 00 00 00 00 00 00 00
Sense Area: 0x71 00 05 00 00 00 00 0C 00 00 00 00 24
21:05:48	#28 Phase 127 File dlgbrnst.cpp, Line 1725
Generating DVD high compatibility borders
21:05:48	#29 SPTI -1066 File SCSIPassThrough.cpp, Line 323
Sense Code: 0x24
Sense Qual: 0x00
21:05:48	#30 Text 0 File DVDR.cpp, Line 6192
21:05:48	#31 CDR -1066 File WriterStatus.cpp, Line 167
21:05:48	#32 TRANSFER -24 File WriterStatus.cpp, Line 167
21:05:48	#33 Phase 38 File dlgbrnst.cpp, Line 1725
Burn process failed at 2.4x (3 324 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 13.04.2004 05:39:16 (Prassi/Veritas driver for win 2K)
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 03.08.2004 22:59:42 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
DVD-mediet er en Intenso DVD+R (1x - 8x).
Noen anelse om hva som kan være feil? .. Har prøvd å oppdatere drivere også. :ermm:
Illegal disc
Usikker på hva det betyr, men det høres jo ikke bra ut.
Prøvd å brenne med determine max speed aktivert? Og hvilken hastighet prøver du å brenne på her?
Er det billige DVD-plater?
Illegal disc
8754210[/snapback]
Har ikke prøvd med determine max speed aktivert, men det har mest sannsynlig ikke noe med saken å gjøre.
DVD-platene skal vist ha relativt bra kvalitet.
Kjørte en "analyse"-sak med Nero og den mente at DVD-brennern min ikke kan brenne DVD+R plater, som er virkelig rart siden det er en DVD+RW/+R brenner (står fårran på enheten). Får prøve å finne noen DVD-R plater istede og sjekke om det er dette som er feilen.
Takk for svar uansett :)
