version 1.1 av Insurgency er ute.
First of all we want to thank everybody for their great support and dedication to our mod over the past 2 days and on behalf of all the developers and especially Pongles and Jeremy I can only say that we have just started and a lot of cool things are about to come.
Right now we are working on the first patch that will take care of the following things:
Release 1.0a Changelist
--- code only
* ADDED: command "tkremove" and "tkdetect"
* CHANGED: alltalk is defaulted to "0"
* FIXED: attacking with grenades while sprinting
* FIXED: RPG playing the wrong draw animation when not loaded
* FIXED: the client crash XYZ ^
* FIXED: the server crash XYZ ^
* FIXED: flashpoint and spraypaint in spectator is now disabled
* FIXED: can not longer cook smoke grenades
* FIXED: reloading the M249
* FIXED: small problem for people that do not have SSE support on their CPU
* FIXED: strange behaviour in shotgun reload
* CHANGED: it wont suicide you when you select another class anymore
-- others
* FIXED: Lots of FPS Improvements
Our team is working hard on finishing this first patch and we should be back with you very soon after testing and making sure things work the way they should be.
det er en ting jeg ikke het skjønner, jeg får noen gang minus poeng selv om jeg ikke har TK'ed en eneste gang.
jeg tok over en sted sammen med andre, jeg drepte 2 fiender og vips så hadde jeg minus 10
9002803[/snapback]
Tror det har noe med objectives å gjøre, ikke sikker
spilte samme banen i strekk i 2 timer i går, mapene er Veldig godt laget, med stor v.
en ting som er ganske plagsomt noen ganger er at det kan være 4 stykk mot 10-11 stk. heldigvis har dette kun skjedd på en server som jeg var på.
veldig bra mod syntes jeg
Snufs, jeg vil spiiiiiiiille! :dontgetit:
Hva har jeg gjort feil?
Har Half-Life 2, Counter-Strike: Source, Source SDK, Source SDK Base og Source Dedicated Server innstallert!
Fikk det samme problemet på Digital Paintball! :cry:
Endret av latter17
Jeg hadde blitt med Hawkn, men innimellom har jeg noen saftige laggs som ødelegger litt... :p
Det er spillbart for MEG, men for dere.... =P
9008412[/snapback]
Etter den første eller andre patchen er ute så tenker jeg det blir andre boller:)
