Tallyho Skrevet 27. januar 2008 Del Skrevet 27. januar 2008 Det er noe dritt at Tversity ikke klarer å gi fra seg bedre bitrate enn 322kbps. Det er jo ikke akkurat så mye å stille på heller. Jeg regner med at dette problemet kommer litt av at jeg kjører det på et trådløst nett som ikke er av høyeste kvalitet. Noen som vet om det går ann å koble en krysset nettverkskabel direkte fra PC til PS3? Lenke til kommentar
Fenixen Skrevet 27. januar 2008 Del Skrevet 27. januar 2008 Crossover-guide jeg fant Here is a general guide I wrote. For Vista, however, I think you will have to go to the sharing tab instead of the advanced tab when you are browsing the properties of a connection... 1. Get a CAT5 or CAT6 crossover cable. The cable that came with the PS3 is a normal Ethernet cable, therefore it cannot be used for this operation. 2. Make sure you have two sources for network communication. For example, you can have 2 ethernet ports on your computer, or you can have a wireless card and a Ethernet port etc. It helps to draw out a connection blueprint such as this: DSL Modem > CAT5 cable > Network Card 1 > Computer > Network Card 2 > CAT5 Crossover cable > PS3 3. Connect your computer to the modem and verify that you have an Internet connection. Then, click on Start, go to settings, control panel. Double click on Network Connections, and identify the connection to your modem (Network card 1). 4. Right click on the modem connection, and choose properties. Next, click on the advanced tab (Sharing tab for Vista users), and check the “allow other users to connect…” checkbox. After the checkbox is checked, click on the “Home networking connection” drop down box and select the name of the second network connection. Click OK and exit the properties window. 5. Finally, connect the CAT5 crossover cable from the second network adapter of the computer to the PS3, and voila, your Internet connection is now routed to your PS3. Please be aware that your computer must be on in order for your PS3 to stay online. In the long run, a router may be a much better device to use than your computer, since it consumes only a fraction of the electricity than your computer does. Når det gjelder transcoding så testa jeg nettopp en haug med filmer, får 1200kbps og oppover, så kabling er tingen om du streamer.. Lenke til kommentar
Tallyho Skrevet 28. januar 2008 Del Skrevet 28. januar 2008 M'kay. Skal kjøpe en slik kabel og teste det. Lenke til kommentar
lockdog Skrevet 6. mars 2008 Del Skrevet 6. mars 2008 (endret) Unnskyld, men det er da virkelig ikke nødvendig å kjøpe en krysset kabel lengre? Auto-sense opplegge nettverkskort skjønner at det ikke er koblet opp mot en switch og krysser på egenhånd. Jeg har koblet ps3 direkte i en nettverksport uten noe som helst kryssing i kabelen og det funker flott. Behovet for krysset kabel i slik sammenheng forsvant vel for 7-8år siden snart. Så folkens: IKKE gidd å sløs penger på en krysset kabel. 1. Grav opp en nettverkskabel (og om du ikke har, kjøp en) 2. Plugg ps3 direkte til nettverkskortet (ja, windows kommer til å mase om begrenset tilgang) 3. Gå inn på egenskaper for internettilkoblingen din. Velg deling av internettforbindelse, og del denne med nettverkstilkoblingen ps3 er koblet til. Endret 6. mars 2008 av lockdog Lenke til kommentar
thesinner Skrevet 13. mai 2008 Del Skrevet 13. mai 2008 Noen som vet hvordan jeg kan få på undertekster når jeg ser film fra PC-en med ps3'n? Bruker Tversity som media-server. Lenke til kommentar
Sheel Skrevet 13. mai 2008 Del Skrevet 13. mai 2008 (endret) Spurte før jeg brukte Google, dumt av meg, om andre har samme problem kaster det jo et lite lys over saken, om ikke mindre. Midlertidig løsning i alle fall. Pause video ("X" på kontroll) for så å gå tilbake til XMB ("O" på kontroll) deretter velge filen igjen ("X" på kontroll) når du skal se videre, avhenger av at både PS3 og PC er oppegående mens du "pauser" video. Hentet fra forumet til TVersity. I found a simple solution when I pause. When the movie is paused I dont press X to resume playing I just press BACK (O) and then X and it continues playing normaly. "Hei, Har problemer med at TVersity får time out med feilmelding "The media could not be played." etter x (20-30 sekunder pleier å være nok, har bare testet med .avi format) antall minutter med pause i avspilling av video, dette er utrolig plagsomt ettersom jeg må være utrolig rask om jeg skal gå fra avspillingen for å gjøre småting. Er det noen grunn til at dette skjer, er det en generell feil i TVersity eller noe med mitt oppsett? Under "Settings" har jeg satt "Maximum Timeshift" til 120 minutter, så dette skal da i teorien ikke skje før det har gått 120 minutter. Kjører med Windows XP Professional 32bit SP3, seneste versjon av TVersity og CCCP codec-pakke om dette spiller noen rolle. Jeg bruker også "Eset Smart Security" versjon 3.0 som både brannmur og antivirus, men det er åpnet for både "Mediaplayer.exe" og "TVersity.exe" i regelsettet til brannmuren, har overvåket trafikken mellom PC-en og enheter som streamer og pakker går både frem og tilbake. På forhånd takk." Edit I: Nettverk til både PC og PS3 er via kabel, kjører gjennom en D-Link DI-524 trådløs router, har også åpnet port for TVersity mot IP-en til PS3 selvom dette strengt tatt ikke bør være nødvendig. Edit II: Spurte før jeg brukte Google, dumt av meg, om andre har samme problem kaster det jo et lite lys over saken, om ikke mindre. Endret 13. mai 2008 av Sheel Lenke til kommentar
Fenixen Skrevet 14. mai 2008 Del Skrevet 14. mai 2008 Har hatt litt samme problemet som deg sheel når jeg streamet 4gb store filer feks, så nå laster jeg dem bare inn på ps3en, tar litt tid men er verdt det Lenke til kommentar
herzeleid Skrevet 18. juni 2008 Del Skrevet 18. juni 2008 Pcen og PS3en min finner ikke hverandre. Noen som har noen gode råd? Lenke til kommentar
Fenixen Skrevet 18. juni 2008 Del Skrevet 18. juni 2008 1. slå av alle anti virus program.. 2. Slå av ALT du har av brannvegger Dersom de fortsatt ikke finner hverandre er det routeren som sperrer, og må rekonfigureres. Dersom mine første forslag løser problemet så får du åpne for tversity i brannveggenee... Lenke til kommentar
Henry9 Skrevet 6. juli 2008 Del Skrevet 6. juli 2008 Hvilket program kan jeg bruke til deling for mac?? Har brukt noe OBi greier, men husker ikke hva det heter. Er noe med Obi trur jeg Lenke til kommentar
trjoh Skrevet 22. juli 2008 Del Skrevet 22. juli 2008 Jeg får streama over og alt er forsåvidt greit.... Det eneste er at jeg synes "utforsker" funksjonen på PS3en er litt dårlig... Kan man ikke bla igjennom filene som er indexert, etter mapper slik som de ligger på pceen??? ellers er PS3en helt genial, det må jo nesten nevnes Lenke til kommentar
Fenixen Skrevet 22. juli 2008 Del Skrevet 22. juli 2008 medialink er visst tingen for mac.. linker automatisk opp mot itunes osv.. Lenke til kommentar
Psyy Skrevet 22. juli 2008 Del Skrevet 22. juli 2008 Medialink er absolutt tingen, veldig verdt de $15 eller hva det nå var det kostet Lenke til kommentar
ketilkn Skrevet 22. juli 2008 Del Skrevet 22. juli 2008 Hvilket program for mac? Jeg bruker TwonkyMedia for Mac og Linux. Finnes en Windows-utgave også. Fungerer fint. Støtter iTunes-bibliotek og Adobe-taging av bilder. iPhoto støtten er nok ikke like god. http://www.twonkyvision.de/ Lenke til kommentar
Jon-H Skrevet 30. juli 2008 Del Skrevet 30. juli 2008 Finnes det noen programmer som putter tags på videofiler, så jeg kan skille ut TV serier fra filmer, osv? Lenke til kommentar
BadFurDay Skrevet 3. august 2008 Del Skrevet 3. august 2008 Jeg har nå lagt inn en avi fil på ps3, men får opp feilmeldingen "Datatypen er ikke understøttet". Jeg prøvde da med en annen avi fil, og denne fungerte da utmerket... Hvorfor virker den ene men ikke den andre? Lenke til kommentar
InToRv Skrevet 16. september 2008 Del Skrevet 16. september 2008 Sorry for å bumpe denne tråden, men jeg lurte bare på hvordan dette fungerer med HD filmer som er rippet over på pcen? Er det nok båndbredde til å få spillt dem av? Pcen min er for svak til å kjøre disse over VGA til lcd tven... Og da lurte jeg på om PS3 er veien å gå, eller xbox 360? Lenke til kommentar
-Tommy Skrevet 16. september 2008 Del Skrevet 16. september 2008 Er ingen problemer å spille av 1080P filmer. Eller hvertfall ikke vis du kobler direkte fra pc'en til PS3. Når jeg koblet den inni switchen min så klarte den det ikke, men det går nok fint med en litt raskere switch enn den jeg har Billigste jeg fant på clas ohlson Lenke til kommentar
Jo Are Skrevet 16. september 2008 Del Skrevet 16. september 2008 (endret) Er ingen problemer å spille av 1080P filmer. Eller hvertfall ikke vis du kobler direkte fra pc'en til PS3. Når jeg koblet den inni switchen min så klarte den det ikke, men det går nok fint med en litt raskere switch enn den jeg har Billigste jeg fant på clas ohlson Vil bare si til alle dere som sliter med hakking ved trådløst nett, hvis du har mulighet gå over til kablet nett da slipper du all hakking. Jeg har pcen koblet til modemet md kabel og samme med ps3 funker utmerket. Endret 16. september 2008 av Jo Are Lenke til kommentar
