larrylu Skrevet 23. mai 2007 Rapporter Del Skrevet 23. mai 2007 Vil dette her: WriteRegDWORD HKEY_LOCAL_MACHINE "SYSTEM\CurrentControlSet\Control\Print\Monitors\Standard TCP/IP Port\Ports\NP01-FAX1" "Protocol" 0x1 WriteRegDWORD HKEY_LOCAL_MACHINE "SYSTEM\CurrentControlSet\Control\Print\Monitors\Standard TCP/IP Port\Ports\NP01-FAX1" "Version" 0x1 WriteRegStr HKEY_LOCAL_MACHINE "SYSTEM\CurrentControlSet\Control\Print\Monitors\Standard TCP/IP Port\Ports\NP01-FAX1" "HostName" "" WriteRegStr HKEY_LOCAL_MACHINE "SYSTEM\CurrentControlSet\Control\Print\Monitors\Standard TCP/IP Port\Ports\NP01-FAX1" "IPAddress" "221.21.21.26" WriteRegStr HKEY_LOCAL_MACHINE "SYSTEM\CurrentControlSet\Control\Print\Monitors\Standard TCP/IP Port\Ports\NP01-FAX1" "HWAddress" "" WriteRegDWORD HKEY_LOCAL_MACHINE "SYSTEM\CurrentControlSet\Control\Print\Monitors\Standard TCP/IP Port\Ports\NP01-FAX1" "PortNumber" 0x238c WriteRegStr HKEY_LOCAL_MACHINE "SYSTEM\CurrentControlSet\Control\Print\Monitors\Standard TCP/IP Port\Ports\NP01-FAX1" "SNMP Community" "public" WriteRegDWORD HKEY_LOCAL_MACHINE "SYSTEM\CurrentControlSet\Control\Print\Monitors\Standard TCP/IP Port\Ports\NP01-FAX1" "SNMP Enabled" 0x1 WriteRegDWORD HKEY_LOCAL_MACHINE "SYSTEM\CurrentControlSet\Control\Print\Monitors\Standard TCP/IP Port\Ports\NP01-FAX1" "SNMP Index" 0x1 Blir samme resutat som scriptet neden for. Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE "SYSTEM\CurrentControlSet\Control\Print\Monitors\Standard TCP/IP Port\Ports\NP01-FAX1] "Protocol" 0x1 "Version" 0x1 "HostName" "" "IPAddress" "221.21.21.26" "HWAddress" "" "PortNumber" 0x238c "SNMP Community" "public" "SNMP Enabled" 0x1 "SNMP Index" 0x1 Lenke til kommentar
DemoniZer Skrevet 23. mai 2007 Rapporter Del Skrevet 23. mai 2007 Sett raskt over.. ja. Lenke til kommentar
larrylu Skrevet 4. juni 2007 Forfatter Rapporter Del Skrevet 4. juni 2007 Sett raskt over.. ja. 8678707[/snapback] Takk. Lenke til kommentar
DemoniZer Skrevet 4. juni 2007 Rapporter Del Skrevet 4. juni 2007 Bare hyggelig det Lenke til kommentar
larrylu Skrevet 4. juni 2007 Forfatter Rapporter Del Skrevet 4. juni 2007 Bare hyggelig det 8777853[/snapback] men kopierte reg fila på en måtte fordet. jeg la linn en tcp/ip skriver manualt. så gikk jeg inn i regedit og eksporterte nøkklen til fil. så kopierte jeg filen . da fikk jeg det til Lenke til kommentar
DemoniZer Skrevet 4. juni 2007 Rapporter Del Skrevet 4. juni 2007 Tenkte det var FAX det var snakk om, men godt det ordnet seg for deg uansett. Lenke til kommentar
