Mad Esc Skrevet 18. mai 2007 Del Skrevet 18. mai 2007 µTorrent is an efficient and feature rich BitTorrent client for Windows sporting a very small footprint. It was designed to use as little cpu, memory and space as possible while offering all the functionality expected from advanced clients. Main Features: - Multiple simultaneous downloads - Smart bandwidth usage - File level priorities - Configurable bandwidth scheduling - Global and per-torrent speed limiting - Quickly resumes interrupted transfers - UPnP support (WinXP only) - Supports popular protocol extensions - Localized to different languages - Typical memory use less than 4 MB - Incredibly small Changes in µTorrent Version 1.7 (build 1825), 2007-05-17: - Feature: option to auto update to betas - Feature: reselect categories on start that were selected on the previous run of the program - Change: Feed information is included in RSS history - Change: rss.start_matches controls start behavior for RSS filter matches - Change: Ability to show piece priority in pieces tab - Change: Disconnect immediately from connected peers that are added to block lists - Change: RSS filter queries will not match entries already in history - Change: Feed column in RSS history - Change: Formatting for torrent status strings - Change: RSS title parsing - Change: RSS filter by episode with just starting point - Change: more even distribution of random listening port on startup - Fix: Size of horizontal scrollbar in addtorrent dialog treeview - Fix: Some rare scrollbar bugs in the addtorrent dialog treeview - Fix: Header updating in the addtorrent dialog treeview - Fix: Size of horizontal scrollbar in addtorrent dialog treeview when expanding items - Fix: Display of bullets in bandwidth setting right-click menus on wine - Fix: Handle HTTP errors without attached messages Download: µTorrent 1.7 Build 1875 beta Lenke til kommentar
