Ny nVidia ForceWare Beta for Vista (DX10 SLI)
HKS
Litt nyheter til dere GeForce 8800-sere eiere...
nVidia har lagt ut nye BETA-drivere for Vista 32-bit og 64-bit. Disse er foreløpig ikke WHQL-serifiserte, men det kommer iløpet av månden, sammen med støtte for resten av 8-serien.
Hovednyheten i driveren er støtte for DirectX 10 i SLI
Vista 32-bit:
http://www.nvidia.com/object/winvista_x86_158.42.html
Vista 64-bit:
http://www.nvidia.com/object/winvista_x64_158.42.html
- Please note this driver only supports the GeForce 8800 series GPUs
- Improved 3D performance for single GPU and NVIDIA SLI
- Add support for NVIDIA SLI on DirectX 10
- Numerous game and application compatibility fixes
- Updated NVIDIA Control Panel with improved user interface
- Numerous game and application compatibility fixes.
- This driver supports the following 3D features:
Single GPU support
DirectX 9 support for GeForce 6/7/8 series GPUs
DirectX 10 support for GeForce 8 series GPUs
OpenGL support for GeForce 6/7/8 series GPUs
NVIDIA SLI support
DirectX 9 support for 6/7/8 series GPUs
DirectX 10 support for 8800 series GPUs
OpenGL support for 6/7/8 series GPUs
Dokumentasjon:
http://us.download.nvidia.com/Windows/158....lease_Notes.pdf
