Hvordan lagre i annen mappe?
Heisann,
Jeg bruker dette her opplastingsskriptet, samt visningskriptet:
<?php
//vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
//   You may change maxsize, and allowable upload file types.
//Mmaximum file size. You may increase or decrease.
$MAX_SIZE = 2000000;
//Allowable file Mime Types. Add more mime types if you want
$FILE_MIMES = array('image/jpeg','image/jpg','image/gif'
                  ,'image/png','application/msword');
//Allowable file ext. names. you may add more extension names.
$FILE_EXTS  = array('.zip','.jpg','.png','.gif');
//Allow file delete? no, if only allow upload only
$DELETABLE  = false;
//   Do not touch the below if you are not confident.
*     Setup variables
$site_name = $_SERVER['HTTP_HOST'];
$url_dir = "http://".$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF']);
$url_this =  "http://".$_SERVER['HTTP_HOST'].$_SERVER['PHP_SELF'];
$upload_dir = "";
$upload_url = $url_dir."filer";
$message ="";
*     Create Upload Directory
if (!is_dir("files")) {
 if (!mkdir($upload_dir))
 	die ("upload_files directory doesn't exist and creation failed");
 if (!chmod($upload_dir,0755))
 	die ("change permission to 755 failed.");
*     Process User's Request
if ($_REQUEST[del] && $DELETABLE)  {
 $resource = fopen("log.txt","a");
 fwrite($resource,date("Ymd h:i:s")."DELETE - $_SERVER[REMOTE_ADDR]"."$_REQUEST[del]\n");
 fclose($resource);
 if (strpos($_REQUEST[del],"/.")>0);                  //possible hacking
 else if (strpos($_REQUEST[del],$upload_dir) === false); //possible hacking
 else if (substr($_REQUEST[del],0,6)==$upload_dir) {
   unlink($_REQUEST[del]);
   print "<script>window.location.href='$url_this?message=deleted successfully'</script>";
else if ($_FILES['userfile']) {
 fwrite($resource,date("Ymd h:i:s")."UPLOAD - $_SERVER[REMOTE_ADDR]"
           .$_FILES['userfile']['name']." "
           .$_FILES['userfile']['type']."\n");
 fclose($resource);
$file_type = $_FILES['userfile']['type'];
 $file_name = $_FILES['userfile']['name'];
 $file_ext = strtolower(substr($file_name,strrpos($file_name,".")));
 //File Size Check
 if ( $_FILES['userfile']['size'] > $MAX_SIZE)
    $message = "The file size is over 2MB.";
 //File Type/Extension Check
 else if (!in_array($file_type, $FILE_MIMES)
         && !in_array($file_ext, $FILE_EXTS) )
    $message = "Sorry, $file_name($file_type) is not allowed to be uploaded.";
 else
    $message = do_upload($upload_dir, $upload_url);
 print "<script>window.location.href='$url_this?message=$message'</script>";
else if (!$_FILES['userfile']);
else
$message = "Invalid File Specified.";
*     List Files
$handle=opendir($upload_dir);
$filelist = "";
while ($file = readdir($handle)) {
  if(!is_dir($file) && !is_link($file)) {
     $filelist .= "<a href='$upload_dir$file'>".$file."</a>";
     if ($DELETABLE)
       $filelist .= " <a href='?del=$upload_dir".urlencode($file)."' title='delete'>x</a>";
     $filelist .= "<sub><small><small><font color=grey>  ".date("d-m H:i", filemtime($upload_dir.$file))
                  ."</font></small></small></sub>";
     $filelist .="<br>";
function do_upload($upload_dir, $upload_url) {
$temp_name = $_FILES['userfile']['tmp_name'];
 $file_name = str_replace("\\","",$file_name);
 $file_name = str_replace("'","",$file_name);
$file_path = $upload_dir.$file_name;
//File Name Check
 if ( $file_name =="") {
 	$message = "Invalid File Name Specified";
 	return $message;
 $result  =  move_uploaded_file($temp_name, $file_path);
 if (!chmod($file_path,0777))
   $message = "change permission to 777 failed.";
 else
   $message = ($result)?"$file_name uploaded successfully." :
           "Somthing is wrong with uploading a file.";
 return $message;
<body bgcolor="#FFFFFF">
<center>
<center>
  <font face="Arial"><b>Filer</b> ... </font>
  <hr width=70%>
  <?=$filelist?>
  <hr width=70%>
  <font size="1">Steffen N. Martinsen </font><font size="-2">©2006</font></center>
 <form name="upload" id="upload" ENCTYPE="multipart/form-data" method="post">
    <font face="Arial">Last opp ett bilde!</font> <input type="file" id="userfile" name="userfile">
    <input type="submit" name="upload" value="Last opp">
  </form>
  <br> </center>
Men, det har seg sånn at alle filene bare lagres i samme mappe som skriptet uten at jeg kan fatte å begripe hvorfor.. Så, hvorfor?
Kan noe endre skriptet sånn at filene lagres i en mappe som heter "Bilder" ?
Og forresten, filene vises ikke heller i den listen sånn som de skal, hvorfor ikke? Kan noe ordne det for meg?
Takk!
Endret av steffenz
Bare ett lite tips, ser at det $_REQUEST er brukt, jeg ville ha erstatet det med $_POST i stedet.
Edit: Fikk det til å fungere på min server hjemme. Mr.Bakke hadde rett, $upload_dir = "Bilder/"; er korrekt.
Har gjordt noen små endringer på scriptet, bl.a byttet ut $_REQUEST med $_POST og lagt in Bilder som upload_dir:
Klikk for å se/fjerne innholdet nedenfor
<?php
$DELETABLE = false;
* Setup variables
$message ="";
if (!is_dir($upload_dir)) {
if (isset($_POST['del']) AND $_POST['del'] && $DELETABLE) {
fwrite($resource,date("Ymd h:i:s")." DELETE - ".$_SERVER['REMOTE_ADDR'].".".$_POST['del']."\n");
fclose($resource);
if (strpos($_POST['del'],"/.")>0); //possible hacking
else if (strpos($_POST['del'],$upload_dir) === false); //possible hacking
else if (substr($_POST['del'],0,6)==$upload_dir) {
unlink($_POST['del']);
print "<script>window.location.href='$url_this?message=deleted successfully.'</script>";
fwrite($resource,date("Ymd h:i:s")." UPLOAD - ".$_SERVER['REMOTE_ADDR']." "
fclose($resource);
//File Size Check
$message = "Sorry, ".$file_name($file_type)." is not allowed to be uploaded.";
else
//print "<script>window.location.href='$url_this?message=$message'</script>";
else
* List Files
$filelist = "";
$filelist .= "<a href='".$upload_dir."".$file."'>".$file."</a>";
if ($DELETABLE)
$filelist .= " <a href='?del=".$upload_dir." ".urlencode($file)."' title='delete'>x</a>";
$filelist .="<br>";
//File Name Check
return $message;
echo $result;
else
$message = ($result)?$file_name." uploaded successfully." :
return $message;
<center>
<center>
<hr width=70%>
<?=$filelist?>
<hr width=70%>
</form>
<br> </center>
Endret av crowly
