Installere VMware Tools i ubuntu...
Jeg kjører feisty via VMware i Vista, og da skulle jeg ha fått installert WMware Tools, men jeg klarer ikke å kjøre de to filene som dukker opp i ubuntu..
Jeg kan bruke terminalen, men jeg aner ikke hva jeg skal gjøre her :hmm:
Noe i denne stilen:
tar xvzf vmware-tools-distrib.tar.gz
cd vmware-tools-distrib
sudo -s
apt-get install linux-headers-`uname -r` build-essential
./vmware-install.pl
...ja, jeg fant noe jeg hadde skrevet før, så her er resten av regla:
You will be prompted to accept the installation path, normally /usr/bin. If you prefer, you
may give /usr/local/bin as installation path instead – this will have the installer assume
/usr/local/ as the prefix. /usr/local was given as prefix during the this installation.
Next we need have the X server restarted in order to have it take advantage of the new
drivers installed by vmware­tools.
  # /etc/init.d/gdm restart
If you want to make sure everything is restarted, you may give the server a reboot instead:
  # reboot
That's it – vmware tools is now installed. You may run through the configuration again with
  # vmware­config.pl
To administer vmware­tools, run
  # vmware­toolbox
