litt kode testing
Rasks
<?php
$var = "thing";
if (isset($tvar)) {
echo "var is set";
} else {
echo "var is not set";
$num = 5;
if (is_numeric($num)) {
   echo "num is a number";
} else {
   echo "num is not a number";
echo "script executed";
PHP
<?php
$num = 5;
} else {
echo "php??";
$num = 5;
} else {
PHP
<?php
$num 5;
} else {
echo "php??";
Endret av Rasks
CODE
function rot13( $text )
$codec_text = '';
$len = strlen($text);
for ( $i=0; $i < $len; $i++ )
$k = ord($text[$i]);
// 65-77 to 78-90 and 97-109 to 110-122
if ( ($k >= 65 && $k <= 77) || ($k >= 97 && $k <= 109) )
$codec_text .= chr($k+13);
// 78-90 to 65-77 and 110-122 to 97-109
elseif ( ($k >= 78 && $k <= 90) || ($k >= 110 && $k <= 122) )
$codec_text .= chr($k-13);
else
$codec_text .= chr($k);
return $codec_text;
$codec_text = '';
 else
return $codec_text;
CODE
$codec_text = '';
$codec_text = '';
Gjest
