mrhaugland Skrevet 11. mai 2007 Del Skrevet 11. mai 2007 Trenger å kjøpe nytt pci sata kort til min pc, som er kompatibelt med Hitachi 78. Hører at det kun er visse chipset som funker. Noen som har erfaringer å komme med? Lenke til kommentar
trydis Skrevet 11. mai 2007 Del Skrevet 11. mai 2007 Hitachi 0078FKThese drives can be flashed by most SATA chipsets that support ATAPI devices (optical drives). There are some that will not though. Silicon Image SATA chipsets will not work; they corrupt the data and will give you an error. Attempting to flash this drive with a SIL chipset could brick your drive. Also, in rare cases, there are reports that VIA chipsets have problems with some version 78 drives, but with other version 78 drives they can flash them fine. Personally, my VIA 8237 has problems with all 78 drives, I have to use the short black SATA cable in the Xbox 360 to flash. If the cable is any longer, it doesn’t even go into ModeB. Not really sure why, just reporting my experience. SIL will not work, VIA will usually work, but in some cases has problems. Many other chipsets should work fine. Lenke til kommentar
mrhaugland Skrevet 11. mai 2007 Forfatter Del Skrevet 11. mai 2007 Hitachi 0078FKThese drives can be flashed by most SATA chipsets that support ATAPI devices (optical drives). There are some that will not though. Silicon Image SATA chipsets will not work; they corrupt the data and will give you an error. Attempting to flash this drive with a SIL chipset could brick your drive. Also, in rare cases, there are reports that VIA chipsets have problems with some version 78 drives, but with other version 78 drives they can flash them fine. Personally, my VIA 8237 has problems with all 78 drives, I have to use the short black SATA cable in the Xbox 360 to flash. If the cable is any longer, it doesn’t even go into ModeB. Not really sure why, just reporting my experience. SIL will not work, VIA will usually work, but in some cases has problems. Many other chipsets should work fine. 8590694[/snapback] Hmm...Lest litt rundt på 360mods.net og xbox-scene.com, og der anbefaler folk kort med VIA 6421 chipset. Men ettersom jeg ikke har sett noen forhandlere selge kort med denne typen har jeg lagt inn innlegg her. Fint med spesifikke tips om kort som folk vet virker. Takker... Lenke til kommentar
