Acer Travelmate fungerar ikkje med batteri.
Min Acer Travelmate 803LMi slutta brått å fungere med batteri.
I følge service manual skal ein kjøre diagnose diskett dersom spenninga er OK.
Spenninga på batteriet er 10.5 Volt og skulle difor vere OK.
Er det nokon som veit kvar eg kan få tak i diagnose program?
Er det nokon som har hatt liknande problem?
Side 67.
Check the Battery Pack
To check the battery pack, do the following:
From Software:
1. Check out the Power Options in control Panel
2. In Power Meter, confirm that if the parameters shown in the screen for Current Power Source and Total
Battery Power Remaining are correct.
3. Repeat the steps 1 and 2, for both battery and adapter.
4. This helps you identify first the problem is on recharging or discharging.
From Hardware:
1. Power off the computer.
2. Remove the battery pack and measure the voltage between battery terminals 1(+) and 6(ground).
3. If the voltage is still less than 7.5 Vdc after recharging, replace the battery.
4. If the voltage is within the normal range, run the diagnostic program.
To check the battery charge operation, use a discharged battery pack or a battery pack that has less than 50%
of the total power remaining when installed in the computer.
If the battery status indicator does not light up, remove the battery pack and let it return to room temperature.
Re-install the battery pack.
If the charge indicator still does not emit, replace the battery pack. If the charge indicator still does not light up,
replace the DC/DC charger board.
Side 45
System Diagnostic Diskette
This diagnostic diskette is for the Acer TravelMate 800 series notebook machine. You can find the utility in
Service CD kit. To use the diagnostic programs, first create a bootable diskette. Extract the diagnostic utility to
the bootable diskette. Then boot the system from the bootable (with diagnostic utility) diskette you create.
This program contains a readme.txt file. This readme.txt file will introduce each test utility and its functions.
New added description. Please pay attention to it. The diagnostics program we use for TravelMate 800 series
is not exactly the same as PQA (Product Quality Assurance), the diagnostic program we used to employ in
other model. The system diagnostic utilities is provided by Acer Headquarters. You can utilize it as a basic
diagnostic tool. To get this program, find it in the TravelMate 800 series service CD kit. To better fit local
service requirements, your regional office MAY have other diagnostic program. Please contact your regional
offices or the responsible personnel/channel to provide you with further technical details.
