Er det noen som har lagd et prog for å lese dallas temp sensor (DS18B20) el?
Hadde vært veldig takknemlig hvis noen hadde en enkel kode og vise det med.
Trenger dette fordi jeg synes det er lettere å lære hvis jeg har noen eksempler som jeg synes er interesant å kikke på.
Hilsen Nybegynner.
Prøver meg forresten på vb2005 exp. :hmm:
Har prøvd, men dette eksemplet får jeg ikke til å virke.
vb er ikke helt fornøyd med linja
Dim adapter
Kan ikke dette eksemplet brukes i vb2005exp, eller er det en feil?
Nybegynneren
'Copyright © 2004 Dallas Semiconductor MAXIM Corporation, All Rights Reserved.
'Permission is hereby granted, free of charge, to any person obtaining a
'copy of this software and associated documentation files (the "Software"),
'to deal in the Software without restriction, including without limitation
'the rights to use, copy, modify, merge, publish, distribute, sublicense,
'and/or sell copies of the Software, and to permit persons to whom the
'Software is furnished to do so, subject to the following conditions:
'The above copyright notice and this permission notice shall be included
'in all copies or substantial portions of the Software.
'THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
'OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
'MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
'IN NO EVENT SHALL DALLAS SEMICONDUCTOR BE LIABLE FOR ANY CLAIM, DAMAGES
'OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
'ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
'OTHER DEALINGS IN THE SOFTWARE.
'Except as contained in this notice, the name of Dallas Semiconductor MAXIM
'shall not be used except as stated in the Dallas Semiconductor MAXIM
'Branding Policy.
Public Class Form1
Inherits System.Windows.Forms.Form
Public CRLF = New String(Chr(13) & Chr(10), 0, 2) ' makes a carriage-return-linefeed string to begin a new line in a text box
Dim adapter
#Region " Windows Form Designer generated code "
Public Sub New()
MyBase.New()
'This call is required by the Windows Form Designer.
InitializeComponent()
'Add any initialization after the InitializeComponent() call
End Sub
'Form overrides dispose to clean up the component list.
Protected Overloads Overrides Sub Dispose(ByVal disposing As Boolean)
If disposing Then
If Not (components Is Nothing) Then
components.Dispose()
End If
End If
MyBase.Dispose(disposing)
End Sub
'Required by the Windows Form Designer
Private components As System.ComponentModel.IContainer
'NOTE: The following procedure is required by the Windows Form Designer
'It can be modified using the Windows Form Designer.
'Do not modify it using the code editor.
Friend WithEvents ResultsTextBox As System.Windows.Forms.TextBox
Friend WithEvents SearchButton As System.Windows.Forms.Button
<System.Diagnostics.DebuggerStepThrough()> Private Sub InitializeComponent()
Me.SearchButton = New System.Windows.Forms.Button
Me.ResultsTextBox = New System.Windows.Forms.TextBox
Me.SuspendLayout()
'SearchButton
Me.SearchButton.BackColor = System.Drawing.SystemColors.Control
Me.SearchButton.Location = New System.Drawing.Point(336, 112)
Me.SearchButton.Name = "SearchButton"
Me.SearchButton.TabIndex = 0
Me.SearchButton.Text = "&Search"
'ResultsTextBox
Me.ResultsTextBox.Location = New System.Drawing.Point(24, 24)
Me.ResultsTextBox.Multiline = True
Me.ResultsTextBox.Name = "ResultsTextBox"
Me.ResultsTextBox.ScrollBars = System.Windows.Forms.ScrollBars.Vertical
Me.ResultsTextBox.Size = New System.Drawing.Size(296, 200)
Me.ResultsTextBox.TabIndex = 1
Me.ResultsTextBox.Text = ""
'Form1
Me.AutoScaleBaseSize = New System.Drawing.Size(5, 13)
Me.ClientSize = New System.Drawing.Size(424, 266)
Me.Controls.Add(Me.ResultsTextBox)
Me.Controls.Add(Me.SearchButton)
Me.Name = "Form1"
Me.Text = "Get 1-Wire Addresses VB.NET"
Me.ResumeLayout(False)
End Sub
#End Region
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles SearchButton.Click
Dim owd_enum As java.util.Enumeration
Dim owd As com.dalsemi.onewire.container.OneWireContainer
Try
' get exclusive use of 1-Wire network
adapter.beginExclusive(True)
' clear any previous search restrictions
adapter.setSearchAllDevices()
adapter.targetAllFamilies()
adapter.setSpeed(adapter.SPEED_REGULAR)
' enumerate through all the 1-Wire devices found (with Java-style enumeration)
owd_enum = adapter.getAllDeviceContainers
ResultsTextBox.AppendText(CRLF & "1-Wire List:" & CRLF)
ResultsTextBox.AppendText("==========================" & CRLF)
While owd_enum.hasMoreElements()
' retrieve OneWireContainer
owd = owd_enum.nextElement()
' retrieve OneWireAddress
ResultsTextBox.AppendText(CRLF)
ResultsTextBox.AppendText("Address = " & owd.getAddressAsString & CRLF)
ResultsTextBox.AppendText("Description = " & owd.getDescription & CRLF)
End While
' end exclusive use of 1-Wire net adapter
adapter.endExclusive()
Catch ex As Exception
ResultsTextBox.AppendText(CRLF & CRLF & "Error: " & ex.ToString)
End Try
End Sub
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Try
' get the default adapter
adapter = com.dalsemi.onewire.OneWireAccessProvider.getDefaultAdapter
' initialize adapter to proper settings
' print that we got an adapter
ResultsTextBox.AppendText(CRLF & "Adapter: " & adapter.getAdapterName & " Port: " & adapter.getPortName & CRLF & CRLF)
End Try
End Sub
End Class
Jaja det gjør den.
Warning 1 Variable declaration without an 'As' clause; type of Object assumed.
Samme feil på linja over forresten. (publi crlf ..... )
Så starter programmet med denne feil mld i vinduet der jeg regner med den skal liste opp enhetene den finner
Error: System.TypeInitializationException: Typeinitialiseringen for com.dalsemi.onewire.OneWireAccessProvider forårsaket et unntak. ---> System.IO.FileNotFoundException: Kan ikke laste inn filen eller samlingen vjslib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a eller en av avhengighetene. Systemet finner ikke angitt fil.
Filnavn: vjslib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a ---> System.IO.FileNotFoundException: Kan ikke laste inn filen eller samlingen vjslib, Version=1.0.5000.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a eller en av avhengighetene. Systemet finner ikke angitt fil.
Filnavn: vjslib, Version=1.0.5000.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
=== Tilstandsinformasjon før binding===
LOG: Bruker = STEFFENPB\Steff
LOG: DisplayName = vjslib, Version=1.0.5000.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
(Fully-specified)
LOG: Progbase = file:///C:/Documents and Settings/Steff/Skrivebord/dallas/dotnet_get1wire_addresses/Get1WireAddresses/bin/
LOG: Opprinnelig PrivatePath = NULL
Kallende samling : OneWireAPI.NET, Version=1.0.1418.40207, Culture=neutral, PublicKeyToken=9d3abe1382c69a37.
LOG: Denne bindingen begynner i innlastingskonteksten default.
LOG: Fant ingen programkonfigurasjonsfil.
LOG: Bruker maskinkonfigurasjonsfil fra C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\config\machine.config.
LOG: Fant omadressert versjon i "framework"-konfigurasjonen: 1.0.5000.0 omadressert til 2.0.0.0.
LOG: Etter-policy-referanse: vjslib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
LOG: Samme binding ble sett tidligere og mislyktes med hr = 0x80070002.
ved com.dalsemi.onewire.OneWireAccessProvider..cctor()
--- Slutten på sporingen av intern unntaksstakk ---
ved com.dalsemi.onewire.OneWireAccessProvider.getDefaultAdapter()
ved WindowsApplication1.Form1.Form1_Load(Object sender, EventArgs e) i C:\Documents and Settings\Steff\Skrivebord\dallas\dotnet_get1wire_addresses\Get1WireAddresses\GetAddresses.vb:linje 144
Nybegynneren
Høyreklikk på funksjonen i bold på linjen, og velg go to definition (du skal også få opp en litet popup om du holder musen over):
Og se hvilken type den returnerer.
Så legger du til dette i linjen som feilet:
Dim adapter AS typen_som_ble_returnert
Hvis jeg høyreklikker og go to definition ender jeg på adapter i Dim adapter linja.
Ved å holde musa over står det
Nybegynneren
Høyreklikk på funksjonen i bold på linjen, og velg go to definition:
Tror ikke jeg klarer å få ordet du skal trykke på klarer frem....
Endret av jorn79
Ja det var klart det :D
Dim adapter As com.dalsemi.onewire.adapter.DSPortAdapter :D
og ett problem mindre
Tusen takk.
Så neste feil?
linje 117
Warning 1 Access of shared member, constant member, enum member or nested type through an instance; qualifying expression will not be evaluated.
Prog starter og viser
(Fully-specified)
ved WindowsApplication1.Form1.Form1_Load(Object sender, EventArgs e) i C:\Documents and Settings\Steff\Skrivebord\dallas\dotnet_get1wire_addresses\Get1WireAddresses\GetAddresses.vb:linje 145
Nybegynneren.
Genialt igjen :D
Ingen feilmld under debugg nå. Kun i vindu til prog
Noen gode råd igjen?
(Fully-specified)
ved WindowsApplication1.Form1.Form1_Load(Object sender, EventArgs e) i C:\Documents and Settings\Steff\Skrivebord\dallas\dotnet_get1wire_addresses\Get1WireAddresses\GetAddresses.vb:linje 147
Ja litt sløvt av meg å ikke se det.
Må jeg den fordi DLLen er bygd på j# ?
Men hadde den før jeg leste svaret ditt. (Og litt stolt av det)
Tusen takk igjen for god hjelp.
Nå virker det.
Så er det bare å begynne å kikke litt mer på koden og prøve å endre litt på ting for å lære mer.
Nybegynneren
Ok
Noen gode forslag?
Har lyst til å lære mer om å styre/lese Dallas 1wire devices, som temp sensor og switcher ++
Nybegynneren
8584174[/snapback]
Hvordan du bruker den kan du jo lære derfra. Bare husk at koden ikke er noe bra skrevet. Når du lærer deg VB.Net godt, vil du se det :)
