CfChrismo Skrevet 9. mai 2007 Rapporter Del Skrevet 9. mai 2007 Hei.. Får følgende feilmelding i Battlefield 2, og det hindrer meg i å spiller på samtlige servere. (Utenom de som ikke benytter seg av Punkbuster da). "Punkbuster Error Message: You have been kicked vi PunkBuster (for 0 minutes) ... RESTRICTION: Inadequate O/S Privileges" Det sier meg faktisk veldig lite. Noen som vet hva jeg må gjøre for å rette opp i feilen? Har Windows Vista om det har betydning. Lenke til kommentar
BigJackW Skrevet 9. mai 2007 Rapporter Del Skrevet 9. mai 2007 (endret) Her kan du kanskje få hjelp: http://www.punksbusted.com/forums/index.php?showtopic=153 og her: http://www.google.no/search?hl=no&q=Inadeq...%2FS+Privileges Edit: Om du spiller under vista på du spille som administrator. To run PunkBuster under Windows Vista you will need to run the game as an administrator. To do this, right click the icon you use to launch the game. Select "Properties", then the "Compatability" tab. From that tab, check the box labled "Run this program as an Administrator" and click ok.We are currently exploring methods to extend PunkBuster to work with Vista without requiring users to run as admin." Prøv også dette om du ikke fikser det: "Download and run this file from any location, it will check for adware that stops you from being able to play on PB servers. The VX2 adware edits your user rights when it infects your computer, and many programs do not repair this when they remove it. http://www.greyknight17.com/spy/VX2Finder(126).exe Click the "Find VX2.betterinternet info" button to make sure that you don't have this adware. If there are no files listed, go on to the last step. If you find the adware files, (it is usually 3 random named dll files) Select all the files found. Press 'Delete These Files'. The program will delete all files but one that will be deleted on reboot. Allow program to reboot. Once Restarted: Press 'Guardian.reg'. Press 'User Agent'. Press 'Restore Policy'. Clicking on "find vx2.BetterInternet info" again should show all fields blank. If you have no adware files, just click on the "Restore Policy" Button." Endret 9. mai 2007 av BigJackW Lenke til kommentar
CfChrismo Skrevet 9. mai 2007 Forfatter Rapporter Del Skrevet 9. mai 2007 Takk for svar. Skal prøve det du sier. Lenke til kommentar
kosara21 Skrevet 26. mai 2007 Rapporter Del Skrevet 26. mai 2007 Må man spille som administrator når man IKKE har Vista? Har nyeste xp, sliter med BF 2142 Lenke til kommentar
binko Skrevet 26. mai 2007 Rapporter Del Skrevet 26. mai 2007 Sjekk signaturen min, så funker det fint... Lenke til kommentar
kosara21 Skrevet 27. mai 2007 Rapporter Del Skrevet 27. mai 2007 Sjekk signaturen min, så funker det fint... 8709381[/snapback] har ikke Vista.... Lenke til kommentar
