VLC/Videolan: Huske siste fil/playlist
Finnes det en måte å få VLC til å huske siste fil eller helst siste spilleliste med fil? Det er litt plagsomt å måtte åpne en spilleliste hver gang man starter VLC...
Og før det kommenteres: Det er ikke mulighet for å bytte program, da det er streaming-mulighetene til VLC jeg i hovedsak er ute etter. ;)
Dette har blitt forespurt før.
http://trac.videolan.org/vlc/ticket/433
EDIT:
16. August:
The playlist will start featuring a Media Library, which will be automatically saved and restored. There will still be the old "playlist" that gets forgotten at each restart of VLC. Sorting, filtering and searching capabilities will also be enhanced for the new playlist, and Shoutcast support will be enhanced.
Streaming is inherently complex, and our earlier efforts to simplify this, via GUIs and wizards have not been very successful. The main problems of the wizard were that it didn't show all the power of VLC, and that it still required the user to make some complex decisions about what muxer to use, for example.
Streaming profiles should be implemented in 0.8.6, and we hope that they will provide an efficient solution to this problem. You'll be able to choose from one of the shipped profiles, depending on what you want to do, like "Save what I'm watching on TV", "Stream to my LAN", "Stream to friends on Internet", "Transcode this video for my iPod", ... and you'll only have to make a few final choices, like "Video quality", "Bandwidth", ... The system should make it easy to write new profiles, thus easily expanding the capabilities.
Endret av DemoniZer
Du kan få default stream da.
Settings > Preferences > Playlist > Default Stream
8571293[/snapback]
Hmm... Interessant!
Er det mulig å sende ut samme fil på forskjellige streamer? Gjerne med forskjellige instillinger for transcoding i tillegg?
Tja... da får jeg vel bare prøve å finne det ut. ;)
Hadde vært hendig å kunne streame ut samme videoen med både mp3 og wma som audio-codec. Det er bare WMA som fungerer med min D-Link boks, men WMA feiler mye oftere enn MP3...
