AlecTBM Skrevet 8. mai 2007 Del Skrevet 8. mai 2007 (endret) Jeg trenger litt hjelp til å få høyere oppløsning på skjermen min. Har en Acer TravelMate 4222WLMi med et Intel Graphics Media Accelerator 950. jeg kjører for øyeblikket sabayon. Maks oppløsning er 1024x768 nå, men har lyst på 1280x800 (trur jeg det var) Har redigert i xorg.conf med hjelp av en kamerat Klikk for å se/fjerne innholdet nedenfor Section "Files" #FontPath "/usr/share/fonts/local/" FontPath "/usr/share/fonts/misc/" FontPath "/usr/share/fonts/Type1/" FontPath "/usr/share/fonts/TTF/" FontPath "/usr/share/fonts/75dpi/" FontPath "/usr/share/fonts/100dpi/" FontPath "/usr/share/fonts/corefonts" EndSection # ********************************************************************** # Module section -- this is an optional section which is used to specify # which run-time loadable modules to load when the X server starts up. # ********************************************************************** Section "Module" Load "dbe" Load "i2c" Load "glx" Load "ddc" Load "type1" Load "freetype" Load "extmod" Load "synaptics" Load "vbe" Load "dri" EndSection # ********************************************************************** # Server flags section. This contains various server-wide Options. # ********************************************************************** Section "ServerFlags" Option "AllowMouseOpenFail" "true" EndSection # ********************************************************************** # Input devices # ********************************************************************** # ********************************************************************** # Core keyboard's InputDevice section # ********************************************************************** Section "InputDevice" Identifier "Synaptics1" Driver "synaptics" Option "SendCoreEvents" "true" Option "Device" "/dev/psaux" Option "Protocol" "auto-dev" Option "HorizScrollDelta" "0" Option "SHMConfig" "on" # For ALPS TouchPads #Option "MaxSpeed" "0.7" #Option "MinSpeed" "0.18" #Option "AccelFactor" "0.08" #Option "TopEdge" "120" #Option "LeftEdge" "120" #Option "BottomEdge" "830" #Option "RightEdge" "650" #Option "FingerLow" "25" #Option "FingerHigh" "30" # Do you keep moving the mouse while typing? Try this trick. #synclient TouchpadOff=1 disable your synaptics touchpad #synclient TouchpadOff=0 enable your synaptics touchpad EndSection Section "InputDevice" Identifier "Keyboard1" Driver "kbd" Option "AutoRepeat" "500 5" Option "XkbModel" "pc105" Option "XkbLayout" "no" Option "XkbRules" "xorg" EndSection Section "InputDevice" Driver "wacom" Identifier "wacom1" Option "Device" "/dev/wacom" # Change to # /dev/input/event # for USB Option "Type" "stylus" Option "ForceDevice" "ISDV4" # Tablet PC ONLY EndSection Section "InputDevice" Driver "wacom" Identifier "wacom2" Option "Device" "/dev/wacom" # Change to # /dev/input/event # for USB Option "Type" "eraser" Option "ForceDevice" "ISDV4" # Tablet PC ONLY EndSection Section "InputDevice" Driver "wacom" Identifier "wacom3" Option "Device" "/dev/wacom" # Change to # /dev/input/event # for USB Option "Type" "cursor" Option "ForceDevice" "ISDV4" # Tablet PC ONLY EndSection # ********************************************************************** # Core Pointer's InputDevice section # ********************************************************************** Section "InputDevice" # Identifier and driver Identifier "Mouse1" Driver "mouse" Option "Device" "/dev/psaux" Option "Protocol" "ImPS/2" Option "ZAxisMapping" "4 5" EndSection Section "InputDevice" Identifier "Mouse2" Driver "mouse" Option "Protocol" "ImPS/2" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5" EndSection # ********************************************************************** # Monitor section # ********************************************************************** # Any number of monitor sections may be present Section "Monitor" Identifier "Generic Monitor" #Option "DPMS" VertRefresh 43 - 60 HorizSync 28 - 80 EndSection # ********************************************************************** # Graphics device section # ********************************************************************** # Any number of graphics device sections may be present Section "Device" Identifier "VESA" Driver "i810" # do not remove vesa #Option "RenderAccel" "on" #Option "XAANoOffscreenPixmaps" #Option "BusType" "PCI" #Option "ColorTiling" "on" #Option "EnablePageFlip" "on" EndSection # ********************************************************************** # Screen sections. # ********************************************************************** Section "Screen" # The Identifier, Device and Monitor lines must be present Identifier "Screen 1" Device "VESA" Monitor "Generic Monitor" #Option "AddARGBGLXVisuals" "true" # The favoured Depth and/or Bpp may be specified here DefaultDepth 24 SubSection "Display" Depth 8 ViewPort 0 0 Modes "1280x800" "1024x768" "800x600" "640x480" EndSubsection SubSection "Display" Depth 16 ViewPort 0 0 Modes "1280x800" "1024x768" "800x600" "640x480" EndSubsection SubSection "Display" Depth 24 ViewPort 0 0 Modes "1280x800" "1024x768" "800x600" "640x480" EndSubsection EndSection Section "ServerLayout" # The Identifier line must be present Identifier "Main Layout" Screen 0 "Screen 1" InputDevice "Mouse1" "CorePointer" InputDevice "Mouse2" "SendCoreEvents" InputDevice "Synaptics1" "SendCoreEvents" #InputDevice "wacom1" "SendCoreEvents" #InputDevice "wacom2" "SendCoreEvents" #InputDevice "wacom3" "SendCoreEvents" InputDevice "Keyboard1" "CoreKeyboard" EndSection Section "DRI" Mode 0666 EndSection Section "Extensions" #Option "Composite" "Enable" EndSection Trenger også hjelp til å koble til en ekstra skjerm. Den finner ikke skjerm 2 eller noe. Takker for svar EDIT: Ogja, jeg restarta X etter hver redigering Endret 8. mai 2007 av AlecTBM Lenke til kommentar
olear Skrevet 8. mai 2007 Del Skrevet 8. mai 2007 Du trenger 915resolution for å få widescreen med Intelkort. Lenke til kommentar
AlecTBM Skrevet 8. mai 2007 Forfatter Del Skrevet 8. mai 2007 etter det jeg vet så er den innstalert skal sjekke den opp Lenke til kommentar
gnom1 Skrevet 8. mai 2007 Del Skrevet 8. mai 2007 The new xf86-video-intel-2.0.0 driver no longer uses the video BIOS, it does native mode setting. In other words, the 855resolution/915resolution utilities are no longer needed. For Gentoo users: xf86-video-intel is named xf86-video-i810-2.0.0 in the portage tree http://www.reactivated.net/weblog/ Mao skal du kunne oppdatere drivern og editere /etc/X11/xorg.conf , men drivern har sikkert en del bugs foreløpig... Lenke til kommentar
AlecTBM Skrevet 9. mai 2007 Forfatter Del Skrevet 9. mai 2007 (endret) Hmm ska prøve den gnom1 Endret 9. mai 2007 av AlecTBM Lenke til kommentar
AlecTBM Skrevet 11. mai 2007 Forfatter Del Skrevet 11. mai 2007 Der funka det med 1280x800 Er veldig fornøyd med det Takker Men så er det den andre skjermen da. Skulle gjerne fått til den Lenke til kommentar
