Koble Toshiba flat tv til pc.
HDMI™ (High-Definition Multimedia Interface) is for use
with a DVD, decoder or electrical equipment with digital
audio and video output. It is designed for best
performance with 1080i high-definition video signals but
will also accept and display 480i, 480p, 576i, 576p and
720p signals.
720p signals.
8550968[/snapback]
Men prøvde 1366x720p funka ikke det heller !! --->?
høres rart ut. men i følge manualen du har funnet støtter den uansett ikke 1080p.
fant noe annet interresant i manualen
Connect the PC cable from the computer to the PC
terminal on the back of the television.
Connect the audio cable to the PC/HDMI1 Audio
socket on the back of the television. Select PC from the
PC/HDMI1 audio options in the AV connection
menu located in the SET UP menu.
Press the Bto select PC mode.
The following signals can be displayed:
VGA: 640 x 480/60 Hz (VESA)
SVGA: 800 x 600/60 Hz (VESA)
XGA: 1024 x 768/60 Hz (VESA)
SXGA: 1280 x 1024/60 Hz (VESA)
IMPORTANT NOTE: SXGA will display but it will
not be to VESA standard.
PLEASE NOTE:
Some PC models cannot be connected to this
television.
An adaptor is not needed for computers with a DOS/V
compatible mini D-sub 15 pin terminal.
A band may appear at the edges of the screen or parts
of the picture may be obscured. This is due to the
scaling of the picture by the set, it is not a malfunction.
kan hende du kan få bilde med en dvi til hdmi kabel. men i følge manualen vil pc kun vises i 4:3 format
Endret av Dewil
PLEASE NOTE:
television.
8551023[/snapback]
ok, takker for svar, skal se hva jeg kan få gjort og finner ut av. Kan heller sende deg en melding dersom jeg får til wide. :)
