no screen når jeg starter opp.
hei.
dette har skjedd de 2 siste dagene.
jeg starter opp pcen min og hører 3 bip. biiip bip bip . første lengre enn de to andre.
skjermen er helt svart men wiondows booter(hører melodien)
dette skjedde også for et par dager siden men da gikk det tilslutt.
jeg har en HP bærbar, husker ikke helt modellen den er temmelig ny . halvt år gammel.
noen ideer?
takker for svar på forhånd
• 1 Long, then 3 Short Beeps: Video error
Explanation: The BIOS is unable to access the video system in order to write any error messages to the screen.
Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. It can also be a motherboard issue.
• Continuous Beeping: Memory or video problem
Explanation: The system is producing constant beeping in no specific pattern, or a fast "ringing" sound.
Diagnosis: This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem.
http://acronymsonline.com/lists/beep_chart.asp
