kewell79 Skrevet 2. mai 2007 Rapporter Del Skrevet 2. mai 2007 (endret) LINK kernel-ps3-2.6.16-20070425.ydl.3.ppc64.rpm Endret 2. mai 2007 av kewell79 Lenke til kommentar
Bebeluv Skrevet 2. mai 2007 Rapporter Del Skrevet 2. mai 2007 Kan noen plz gi meg link step by step åsn installere Linux Lenke til kommentar
Enigma123 Skrevet 2. mai 2007 Rapporter Del Skrevet 2. mai 2007 Kanskje jeg skal teste ut Linux Lenke til kommentar
Luc1fer- Skrevet 2. mai 2007 Rapporter Del Skrevet 2. mai 2007 God nyhet for meg som har tenkt til å legge inn Linux i dag! Da slapp jeg å trekke kabel Lenke til kommentar
kewell79 Skrevet 2. mai 2007 Forfatter Rapporter Del Skrevet 2. mai 2007 (endret) 1. Update the firmware on your PS3 This can be achieved from GameOS with the Software Update function in settings. 2. Download the new PS3 wifi enabled kernel: kernel-ps3-2.6.16-20070425.ydl.3.ppc64.rpm 3. Install the new kernel rpm -ivh /path/to/kernel-ps3-2.6.16-20070425.ydl.3.ppc64.rpm 4. Edit /etc/kboot.conf Take your default kernel line, and make a copy of it and then modify the original line to point to the new kernel. For example, if your default kernel line is: ydl='/dev/sda1:/vmlinux-2.6.16-20061110.ydl.2ps3 initrd=/dev/sda1:/initrd-2.6.16-20061110.ydl.2ps3.img root=/dev/sda2 video=ps3fb:mode:3 rhgb' The new section would like this: ydl='/dev/sda1:/vmlinux-2.6.16-20070425.ydl.3ps3 initrd=/dev/sda1:/initrd-2.6.16-20070425.ydl.3ps3.img root=/dev/sda2 init=/sbin/init video=ps3fb:mode:3 rhgb' oldydl='/dev/sda1:/vmlinux-2.6.16-20061110.ydl.2ps3 initrd=/dev/sda1:/initrd-2.6.16-20061110.ydl.2ps3.img root=/dev/sda2 video=ps3fb:mode:3 rhgb' Where oldydl is your original kernel. 5. Reboot 6. Configuring Wireless a) Unplug the ethernet cable, eth0 is both the wired and wireless Ethernet port on PS3s. b) Launch system-config-network (Network in the Settings menu) c) Delete the eth0 (gelic_net) interface. d) Create a Wireless connection. e) You may now configure that wireless connection as you would with other YDL versions. One note here that confused me when I did this was that the ESSID specified as "Auto", when I actually needed to remove that and select the Auto radio button. f) You can now activate the interface. 7. Enjoy your new wireless enabled PS3. Endret 2. mai 2007 av kewell79 Lenke til kommentar
Sunndal1 Skrevet 2. mai 2007 Rapporter Del Skrevet 2. mai 2007 LINK kernel-ps3-2.6.16-20070425.ydl.3.ppc64.rpm 8517505[/snapback] Toppers! Bare så synd jeg kjører Ubuntu som jeg finner mye bedre, men er vel mulig å få det til der også. Må bare få litt tid til å teste. Ekstremt positivt å se at Linux-støtten for PS3 blir bedre og bedre på kort tid. Dette lover bra. Lenke til kommentar
tidus2k4 Skrevet 3. mai 2007 Rapporter Del Skrevet 3. mai 2007 Noen som vet om man bare kan kjøre updatern i YDL for å få denne, eller må man installere alt på nytt? Lenke til kommentar
kewell79 Skrevet 5. mai 2007 Forfatter Rapporter Del Skrevet 5. mai 2007 (endret) Fikk til trådløst etter litt knotning når jeg brukte WEP koden måtte jeg begynne skrive 0x og så WEP koden....merkelig Endret 5. mai 2007 av kewell79 Lenke til kommentar
