HD problemer, hjelp ^^
Er det noe håp for denne harddisken?
Den virker noenlunde stabil, men er MEGET treg for en 7200 RPM å være.
Kjørte en analyse på den via Speedfan SMART funksjon.
Almost every EIDE or SATA hard disk includes S.M.A.R.T. data. That information is collected by the drive itself and contains data that the manufacturer considered relevant to check reliability. The data is made up of several attributes that have a current value, a worst one, a threshold, some raw data, and some flags. Basically, when any attribute's current value is below its threshold, the hard disk is considered unreliable and likely to fail. By using several techniques, this report tries to give a wider range of info, basing its analysis on advanced comparisons with normal values based on real hard disks and on expert-like checks. The final results are not to be taken as an absolute truth, but they are a very good approach to what a professional would say about your hard disk status.
Your hard disk is a ST3160023AS with firmware 3.05.
The average temperature for this hard disk is 38C (MIN=26C MAX=50C) and yours is 32C.
Your hard disk's S.M.A.R.T. attributes are now being analyzed and a full report about the reliability, health and status of your hard disk is generated:
Your hard disk is not below any attribute threshold. This is good.
Your hard disk was never below any attribute threshold. This is good.
Your hard disk is now being compared to real data used to define normal values for your specific hard disk model. This way, the analysis can automatically use proper operating ranges. The images give you an idea of how each attribute is within such range. Current and raw values are shown for easier reference for experienced users. There are 1471 hard disk models in the current archive.
Attribute Current Raw Overall
Raw Read Error Rate 49 124636178 Watch
Warning: Raw Read Error Rate is below the average limits (54-69).
Spin Up Time 96 0 Normal
Start/Stop Count 100 293 Very good
Reallocated Sector Count 56 1797 Watch
Warning: Reallocated Sector Count is below the average limits (100-100).
Seek Error Rate 86 426664276 Very good
Power On Hours Count 86 12443 Normal
Spin Retry Count 100 0 Very good
Power Cycle Count 100 644 Very good
Hardware ECC Recovered 49 124636178 Watch
Warning: Hardware ECC Recovered is below the average limits (54-69).
Current Pending Sector 100 627 Very good
Offline Uncorrectable Sector Count 100 627 Very good
Ultra DMA CRC Error Rate 200 0 Very good
Write Error Rate 100 0 Very good
TA Increase Count 100 0 Very good
NOTE: not all warnings are reflected on fitness and performance overall values as relevancy is based upon the settings from the hard disk manufacturer who is the best entity deputed to define such relationships.
NOTE : your hard disk has 1797 reallocated sectors (this value is very large and your hard disk should be replaced). Hard disks do have spare sectors (usually from 256 up to 1024) used to replace bad ones. This remapping operation is transparent to the end user. Anyway, this can lead to degradated performances (because remapped sectors are in different places of the disk than the original ones and the head needs additional moving). If reallocated sectors grow over time, you might encounter some serious troubles. A backup of the most important data is suggested anyway.
NOTE : your hard disk has 627 pending sectors (this value is very large and your hard disk should be replaced). Those are sectors that couldn't be properly read and that the hard disk logic is waiting for a write operation to try to remap to a spare sector (if available). According to the Reallocated Sector Count attribute, your hard disk seems to have available spare sectors. A simple disk surface scan won't be enough to force the remap operation. You need a read/write surface scan to remap the sector. The best option should be a tool that knows about what should be read from that sector so that it has some option to apply the best fix to the missing data.
NOTE : your hard disk has 627 offline uncorrectable sectors (this value is very large and your hard disk should be replaced). Those are sectors that an offline scanning found as unreadable. Offline scanning is a process that can be automatically started by the hard disk logic when a long enough idle period is detected or that can be forced by some tool. Those unreadable sectors are identified and the hard disk logic is waiting for a write command that will overwrite them to try to remap them to spare sectors (if available). According to the Reallocated Sector Count attribute, your hard disk seems to have available spare sectors. A simple disk surface scan won't be enough to force the remap operation. You need a read/write surface scan to remap the sector. The best option should be a tool that knows about what should be read from that sector so that it has some option to apply the best fix to the missing data.
The overall fitness for this drive is 0%.
The overall performance for this drive is 81%.
På forhånd takk!
