LarryDik Skrevet 27. april 2007 Del Skrevet 27. april 2007 (endret) Video fra Major Nelson med nyttig informasjon om hvordan man flytter data fra 20 GB til 120 GB HD'en. Samt vi får en gjennomgang på hva som er i esken for de som bestemmer seg for å kjøpe en svart Xbox 360 EDIT: Hmm..ser ut som nedlasting av filen funker dårlig. Streaming av videoen ser ut til å funke, evt. gå til Major Nelson sin bloggpost om emnet. Endret 27. april 2007 av LarryDik Lenke til kommentar
Mala Skrevet 27. april 2007 Del Skrevet 27. april 2007 Liten sammenligning i mellom Elite og Premim for de som måtte ønske det; Kilde Lenke til kommentar
Torrevieja Skrevet 27. april 2007 Del Skrevet 27. april 2007 Det er noe dritt ! Well, we've had a few hours with our Xbox 360 Elite wherein we've done nothing but test it against the most rigorous (unscientific) means at our disposal. But finally we are able to answer the question: is an HDMI-enabled Xbox 360 capable of outputting noticeably higher quality gameplay and movies? We compared our classic Xbox 360 (manufactured 12/08/2005) with our spankin' new 360 Elite (manufactured 3/4/2007). Ready for the face-off? Check out the gallery, and read on for our conclusions. We tested the consoles with a Sharp 1080p LCD and a 5.1 surround system -- we went HDMI vs component, since it's safe to assume the majority of people don't have VGA inputs on their HDTVs (including us). We played the first stage of Gears of War (on casual, so what?), and then plugged in our HD DVD drive and watched a few scenes from Batman Begins. Console noise We know how much you all wanted your Xbox 360 Elite to quiet down a bit, but we have some bad news for ya. As we heard from our sources who supplied us with much of our info about the Elite, unfortunately it's about the same as before. It doesn't use the new 65nm chips, so it seems to require the same number of case fans. The same is true of the disc drives. They do sound different and it's obvious they're not the same make or model. However, unfortunately, they're equally loud. Sorry guys, you're still going to have to put up with the same level of noise as before. Heat As we said before, these are using the old round of 90nm chips, not the 65nm. So it goes without saying that using the same chips as before, these things are going to produce the same amount of heat. We didn't run an 18 hour stress test or anything (obviously), but they did feel about the same after an hour of play, and they both felt like they were outputting about the same amount of heat. HDMI 1080p vs component 1080p/i We're going to be totally honest here. We hardly noticed a damn difference at all. We figured the best visual test would be playing in 1080p on both HDMI and component video, and we were right. What little difference we did notice, we noticed it here. In a couple of darker scenes in Gears there seemed to be a little more depth to the blacks (and a bit more distance detail because of it). But we didn't even notice it until we literally started flipping back and forth as fast as we could. Fast motion, spinning, all the rest -- it looks almost identical on both consoles. When watching an HD DVD in 1080p on HDMI and 1080i on component, we definitely didn't really notice anything different. The age old question though, right? Is 1080p noticeably different? Not to us, and probably not if you're viewing on anything less than a massive, massive display. By the way, before you make any judgments about perceived visual quality based on our screen caps, please remember that those were taken with a regular camera, not pro screen capturing tools -- so what you may think is a big difference may actually just be a small change in light metering or exposure. In other words, you'll kind of have to take our word for it. Audio We can now definitely confirm that despite its HDMI output, the Xbox 360 Elite still doesn't enable advanced codec support, like Dolby TrueHD. You still have the same three options as you had before: digital stereo, Dolby Digital 5.1, and DD with WMA Pro. When we played back an HD DVD with TrueHD audio (Batman Begins), it just stayed on DD5.1, nothing changed. Bummer, but again, that's what we were expecting. Other minor bits We did notice that the front power button on the Elite console is much clickier than the squishy power button on our classic 360. Probably not enough to justify the purchase, we'd imagine. Also, the black controller is entirely matte, whereas the white controller is matte everywhere but the silver strip on the bottom. Since that's where a couple of your fingers rest when holding the controller, we found the entirely matte black controller slightly preferable. Final thoughts Basically, unless you are seriously eagle-eyed and have a massive friggin screen, or for whatever reason need to use HDMI because you're all out of component inputs, your investment is probably safe. Do yourself a favor, just buy that 120GB drive if you need the space, the HDMI just doesn't justify replacing your whole console for a new $480 unit. Then again, if you're truly "elite" then all the stuff we just said really doesn't matter, and you're probably gonna buy this thing anyway. Cheers, enjoy! http://www.engadget.com/2007/04/26/x...ssic-the-test/ Lenke til kommentar
Dragoncrest Skrevet 27. april 2007 Del Skrevet 27. april 2007 Ser nok ikke den helt store grunnen til å kjøpe Elite med det første nei. På en måte synes jeg det er bra, dvs at dem av oss som har kjøpt en X360 allerede ikke sitter med en "mindreverdig" maskin pga Elite. Den dagen MS implementerer 65nm og en enda mer stille DVD drev så kanskje et nyinnkjøp kan være aktuelt for min del. Lenke til kommentar
Nimrad Skrevet 27. april 2007 Del Skrevet 27. april 2007 Ser så utrolig mye finere ut enn den hvite Lenke til kommentar
Dragoncrest Skrevet 27. april 2007 Del Skrevet 27. april 2007 Ser så utrolig mye finere ut enn den hvite 8484545[/snapback] Kan nå egentlig si meg enig der, men det er vel en smakssak. Lenke til kommentar
Darth MToffy Skrevet 27. april 2007 Del Skrevet 27. april 2007 Final thoughtsBasically, unless you are seriously eagle-eyed and have a massive friggin screen, or for whatever reason need to use HDMI because you're all out of component inputs, your investment is probably safe. Do yourself a favor, just buy that 120GB drive if you need the space, the HDMI just doesn't justify replacing your whole console for a new $480 unit. Then again, if you're truly "elite" then all the stuff we just said really doesn't matter, and you're probably gonna buy this thing anyway. Cheers, enjoy! http://www.engadget.com/2007/04/26/x...ssic-the-test/ 8484384[/snapback] Hehe her nevner de akkurat grunnen for at en slik box ender opp i stua mi på ett eller annet tispunkt. Jeg har 2meter bred skjerm så den pittelille forskjellen mellom komponent og hdmi er viktig. Komponent er 3 kabler, hdmi er 1kabel. Ergo kan jeg fjerne 2kabler av 10meter i stua. Deeeet er viktig det. Kabelrot suger. Kan dette forsvares økonomisk? Neppe Bryr jeg meg? Nei Men blir nok venting til høsten uansett og da er kanskje ny cpu på vei slik at det blir mer forsvarlig. Lenke til kommentar
tidus2k4 Skrevet 27. april 2007 Del Skrevet 27. april 2007 Synes faktisk den hvite er finere jeg.. blir nok en premium på meg når elite har presset ned prisen litt Lenke til kommentar
Lakus Skrevet 27. april 2007 Del Skrevet 27. april 2007 Synes faktisk den hvite er finere jeg.. Samme her.. 360 passer ikke i sort. Akkurat som PS3 ikke passer i hvit. Lenke til kommentar
lektroluv Skrevet 27. april 2007 Del Skrevet 27. april 2007 Jeg kikka gjennom sammenlikningsbildene mellom component og HDMI og la merke til at HDMI bildene ikke er noe lysere enn component bildene. Dvs at det som gjør PS3 spillene så lyse ikke har noe med HDMI å gjøre iallefall (Husker det ble dratt frem da disse multiplassform sammenlikningsfilmene ble diskutert og folk mente at 360'en også ville bli så lys når den sende signalene via HDMI). Det at man ikke ser særlig forskjell mellom 1080p og 1080i kom ikke akkurat som noe bombe, siden Gears ikke er 1080p native. Man ser nok ikke resultater før man sammenlikner f.eks HD film (som er 1080p native) i 1080i og 1080p output. Og ikke minst på en STOR tv eller projektor. Lenke til kommentar
Alex ws Skrevet 27. april 2007 Del Skrevet 27. april 2007 Final thoughtsBasically, unless you are seriously eagle-eyed and have a massive friggin screen, or for whatever reason need to use HDMI because you're all out of component inputs, your investment is probably safe. Do yourself a favor, just buy that 120GB drive if you need the space, the HDMI just doesn't justify replacing your whole console for a new $480 unit. Then again, if you're truly "elite" then all the stuff we just said really doesn't matter, and you're probably gonna buy this thing anyway. Cheers, enjoy! http://www.engadget.com/2007/04/26/x...ssic-the-test/ 8484384[/snapback] Hehe her nevner de akkurat grunnen for at en slik box ender opp i stua mi på ett eller annet tispunkt. Jeg har 2meter bred skjerm så den pittelille forskjellen mellom komponent og hdmi er viktig. Komponent er 3 kabler, hdmi er 1kabel. Ergo kan jeg fjerne 2kabler av 10meter i stua. Deeeet er viktig det. Kabelrot suger. Kan dette forsvares økonomisk? Neppe Bryr jeg meg? Nei Men blir nok venting til høsten uansett og da er kanskje ny cpu på vei slik at det blir mer forsvarlig. 8484821[/snapback] Hørt om VGA? Blir ikke mer digitalt enn det (eller HDMI for den saks skyld). Lenke til kommentar
KayAU Skrevet 27. april 2007 Del Skrevet 27. april 2007 Hørt om VGA? Blir ikke mer digitalt enn det (eller HDMI for den saks skyld). 8488053[/snapback] No er vel VGA strengt teke analogt, so litt meir digitalt blir det nok... Kay Lenke til kommentar
Dr.Peedee Skrevet 27. april 2007 Del Skrevet 27. april 2007 Man ser nok ikke resultater før man sammenlikner f.eks HD film (som er 1080p native) i 1080i og 1080p output. Og ikke minst på en STOR tv eller projektor. 8484897[/snapback] Fra posten lenger opp i tråden : When watching an HD DVD in 1080p on HDMI and 1080i on component, we definitely didn't really notice anything different. 1080p eller 1080i output - forskjellen vil ligge i hvordan billedbehandlingen i de enkelte 1080p TV'er og projektorer er. (Hvis vi da ser bort fra evt. forringelse via komponentsignalgangen da). Så de folka der hadde nok en projektor som de-interlacet rimelig perfekt tilbake til 1080p igjen uten tap av vertikal oppløsning. Og da er det ikke rart at de ikke så forskjell. Gjør det samme på projektoren hjemme her og (1080p) - er ikke forskjell å se på 1080i og 1080p inn. Ellers - ser ingen grunn til å oppgradere til Elite jeg heller. Sparer heller penga til en PS3 evt. Premium xbox360'n min duger bra nok. Men hadde jeg stått uten 360 så hadde jeg selvsagt kjøpt elite. Lenke til kommentar
Alex ws Skrevet 27. april 2007 Del Skrevet 27. april 2007 Hørt om VGA? Blir ikke mer digitalt enn det (eller HDMI for den saks skyld). 8488053[/snapback] No er vel VGA strengt teke analogt, so litt meir digitalt blir det nok... Kay 8488275[/snapback] Uansett får man ikke bedre bilde med HDMI kontra VGA. Begge gir deg 1080p, digitalt. Lenke til kommentar
Rikky Skrevet 27. april 2007 Del Skrevet 27. april 2007 Uansett får man ikke bedre bilde med HDMI kontra VGA. Begge gir deg 1080p, digitalt. 8488588[/snapback] Vi får prøve en gang til: VGA er analogt. Lenke til kommentar
KongRudi Skrevet 27. april 2007 Del Skrevet 27. april 2007 (endret) Jeg kikka gjennom sammenlikningsbildene mellom component og HDMI og la merke til at HDMI bildene ikke er noe lysere enn component bildene. Dvs at det som gjør PS3 spillene så lyse ikke har noe med HDMI å gjøre iallefall (Husker det ble dratt frem da disse multiplassform sammenlikningsfilmene ble diskutert og folk mente at 360'en også ville bli så lys når den sende signalene via HDMI). 8484897[/snapback] Det kan faktisk også være HDMI'en fordi 360 Elite har gammelversjonen HDMI 1.2 som ikke er like mye bedre enn VGA-porten sammenlignet med PS3 sin nye HDMI 1.3. 1.3 har mye høyere fargekrav enn den gamle 1.2-standarden. :-/ Synes det var dumt at ikke MS også brukte den nyeste standarden, en av grunnene til at jeg mener hele Elite-boksen er bare ett PR-jippo. :-/ Menmen, hvis folk må skifte mellom ledningene bak på TV'n er det jo ett greit alternativ. Men tipper at det er Nvidia, og Ati sin forskjellige billedbehandling som gjør at fargene og kontrastene på multikonsoll-spill, blir annerledes. Endret 27. april 2007 av KongRudi Lenke til kommentar
Dr.Peedee Skrevet 27. april 2007 Del Skrevet 27. april 2007 Hvis noen kan si om hvilke kilder som per i dag benytter seg av den økte båndbredden for fargemuligheter som v.1.3 av HDMI tillater og hvilke display som kan fremvise det i dag og uoverskuerlig framtid, SÅ vil jeg også være med å diskutere HDMI 1.3 kontra 1.2. Forslag til HD DVD filmer eller BD filmer som utnytter dette?? El Venter spent Og tar en pause i stund mens forslagene strømmer på Lenke til kommentar
dan1el Skrevet 27. april 2007 Del Skrevet 27. april 2007 DANIELS HANDS-ON: It's black! The old version is... WHITE! And... It's the SAME machine, only it's BLACK! Lenke til kommentar
E-wok Skrevet 27. april 2007 Del Skrevet 27. april 2007 Ingen redusering av lydnivået altså? Smart move må jeg si... Mista nettopp en kjøper. Lenke til kommentar
Torrevieja Skrevet 28. april 2007 Del Skrevet 28. april 2007 Hvis noen kan si om hvilke kilder som per i dag benytter seg av den økte båndbredden for fargemuligheter som v.1.3 av HDMI tillater og hvilke display som kan fremvise det i dag og uoverskuerlig framtid,SÅ vil jeg også være med å diskutere HDMI 1.3 kontra 1.2. Forslag til HD DVD filmer eller BD filmer som utnytter dette?? El Venter spent Og tar en pause i stund mens forslagene strømmer på 8489079[/snapback] Det her med økt fargedybde og båndbredde er nå greit nok, da det er få displayer som støtter 1.3 . Vet at de nye samsung lcdene støtter det. Men det jeg er opptatt av er True HD lyd.. Da jeg skal gå til innkjøp av en av de kommende denon recieverne eller onkyo med nettopp støtte for dette. Skal importere en ps3 nå, men får da bare kjørt over optisk foreløbig i 2.0 pcm Lenke til kommentar
