Annbefaling til moderators: Skjema for kjøpshjelp
Er selv på utkikk etter ny laptop for tiden og da blir det til at man bruker flere medium for å finne de rette erfaringene og tipsene. Etter å ha surfet innom www.notebookreview.com sitt forum ble jeg meget positivt overrasket over krav for deres "hva laptop skal jeg kjøpe"-maler som man måtte ha skrevet posten som.
Siden jeg ser topic etter topic anngående kjøp av laptops få førstesvar som "hva skal du bruke den til", "hvor mye vil du betale", etc. så annbefaler jeg at vi bruker et lignende form som nbrw.com bruker.
With all rights reserved:
General Questions
1) What is your budget?
2) What size notebook would you prefer?
a. Ultraportable; 12" screen or less
b. Thin and Light; 13" - 14" screen
c. Mainstream; 15" - 16" screen
d. Desktop Replacement; 17"+ screen
3) Please select your country's flag as a post icon and tell us what country are you buying this in.
4) Are there any brands that you prefer or any you really don't like?
5) What tasks will you be performing with the notebook?
6) Will you be taking the notebook with you to different places or leaving it on your desk?
7) Will you be playing games on it; if so, which games?
8) How many hours of battery life do you need?
9) Do you mind buying online without seeing the notebook in person?
10) What OS do you prefer? Windows (XP or Vista), Mac OS, Linux, etc.
Screen Specifics
11) Would you prefer standard or widescreen?
12) From the choices below, what screen resolutions would you prefer?
Standard
a. XGA -1024x768 - Large and easy to read text + graphics icons, but you fit less stuff on the screen.
b. SXGA - 1400x1050 - Compromise resolution between XGA and UXGA.
c. UXGA - 1600x1200 - Very small text and graphics icons, you can fit lots of stuff on the screen.
Widescreen
d. WXGA or WXGA+ - 1280x768/800 or 1440x900; Wider viewing version of XGA, good for movie viewing or spreadsheets.
e. WSXGA+ - 1680x1050; Wider viewing version of SXGA, good for movie viewing or spreadsheets.
f. WUXGA - 1920x1200; Wider viewing version of UXGA, good for movie viewing or spreadsheets.
13) Do you want a glossy/reflective screen or a matte/non-glossy screen?
Build Quality and Design
14) Are the notebook's looks and stylishness important to you?
15) When are you buying this laptop and how long do you want this laptop to last?
Notebook Components
16) How much hard drive space do you want; 40GB to 200GB?
17) Do you need an optical drive? If yes, a DVD-ROM, DVD-CD/RW or DVD-RW drive?
