Antec P190 er på vei... Snart i Norge?
Jepp jepp da ser jeg at "thetechloung.com" har lagt ut bilder an antec sitt nye P190 kabinett ..
Det ser jo ganske lekker ut, men er litt "skeptisk" til måten dem har plassert de 2 stk viftene på toppen av kabinettet...
Dette vil bety at den dagen man skrur av viftene/Pc vil støv i rommet falle ned i maskinen.. men hvem skrur av data maskinen da :hmm:
http://www.thetechlounge.com/article/355/A...Product+Lineup/
quote
P190: The Big Boy
The last case is the P190, this is the big bad granddaddy of them all. It is similar to the P180/182, but it is longer with a couple interesting differences. It has a 200mm fan on the side of the unit. Yea, 200mm, that’s about 8” in diameter. It also supports a dual power supply setup, so you can have one power supply for your motherboard and hard drives and another one for your video cards. It supports EATX motherboards, so you can even put a dual socket motherboard in the case. And the copious amount of fans (200mm, two 140mm fans on top, and front and rear 120mm) will certainly keep it cool.
