TEST: Ubuntu 7.04
Heisann!
Dette er vel kanskje ikke rette tråden å spørre om dette i men, jeg kjører på..
Har lastet ned Ubuntu, det kjører fint fra cd.
MEn når jeg legger det inn på harddisk og starter på nytt uten plata så får jeg bare dette:
"Booting from local disk...
GRUB Loading Stage1.5.
GRUB loading, please wait...
Error 18"
Så skjer det ikke noe mer.. har prøvd å legge det inn på 2 forskjellige disker, har valgt å bruke hele disken begge gangene.
Noen forslag fra noen Ubuntu/Linux guruer her?
Hm, den var tricky. Prøv å reinstallere ubuntu, men sørg for å velge en /boot -partisjon som befinner seg så langt framme på disken som mulig.
Error 18
Error 18: Selected cylinder exceeds maximum supported by BIOS
This error is returned when a read is attempted at a linear block address beyond the end of the BIOS translated area. This generally happens if your disk is larger than the BIOS can handle (512MB for (E)IDE disks on older machines or larger than 8GB on others.). In more practical terms this means the BIOS is unable to start executing the kernel because the kernel is not located within the block it can access at boot up time.
This can be circumvented by creating a boot partition at the beginning of the disk that is completely within the first 1023 cylinders of the harddrive. This partition will contain the kernel.
The kernel it self does not suffer from the same limitations as the BIOS so after the BIOS has loaded the kernel the kernel will have no problem accessing the whole harddrive. Newer BIOSes will automatically translate the harddrives size in a way that it can be completely contained within the first 1023 cylinders and hence modern computers do not suffer from this problem.
The same error can happen when the BIOS detects a disk in a different way as Linux does. This can happen when changing motherboards or when moving a GRUB-bootable disk from one computer to another. If this happens, just boot with a GRUB floppy, read the C/H/S numbers from the existing partition table and manually edit the BIOS numbers to match. If using a SUSE linux and installing on VM Ware this problem is solved by creating a small partition at the very beginning of the harddisc, and mounting it as /boot.
http://wiki.linuxquestions.org/wiki/GRUB
Et annet alternativ, er å installere fra alternative-cden, og velge bootloaderen lilo istedet for grub
Takker for svar :)
Driver å booter fra plata igjen nå.. så skal jeg prøve å legge det inn på samme disken en gang til.. først prøvde jeg på en 120GB disk, å da jeg fikk feilen gikk jeg over på en 80Gb disk.. så jeg skal prøve denne igjen nå, og lese litt mer grundig :)
Har nå en delig fått installert ubuntu..
Jeg brukte auto partisjonering av disken dem 2 første gangene, men da ble det ikke laget noe boot partisjon.. så jeg tok å partisjonerte selv, sånn som jeg trodde det skulle være.. tok ca 100 mb til /boot, og ca 1500MB til swap og resten som en partisjon.
Pc'n restarta etter install, og ubuntu startet opp uten problemer =)
Endret av Drkangel
Gjest Slettet+6132
Har selv aldri brukt "Auto" ved installering av ulike versjoner av Ubuntu.
Bruker alltid "manual" for å resize, partisjonere og det funker alltid (og man har da kontroll over sine disker/partisjoner).
Dette funker hver gang.. :)
Har betandig bruk manuell partisjonering, jeg òg. Dette skyldes vel at jeg har en /home partisjon jeg vil ta vare på, i tillegg til at disken min allerede er delt opp slik den skal være. Drkangel; hvor gammel er maskina du sitter på (evt hvor gammel er biosen som er installert)? Problemet du hadde skal i teorien ikke forekomme på nyere maskiner, som jeg har forstått det.
hei sann jeg bare lurer på en liten ting...
jeg har hørt at X1xxx serien med ATI kort ikke støttes av den ufrie driveren.  :ermm:
må jo være helt på trynet viss det er sant. prøvde også å google litt rundt, men fant ikke noe relevant svar.  :ph34r:
8486005[/snapback]
Ser ut som de støtter den serien. Ta en titt på release notes for den nyeste linux driveren så ser du hvilke kort som er støtta.
Jeg tenker på å innstalere dette, men hører at det emd skjermkort driver er et stort problem. Jeg har ATi x800xl, kan dere hjelpe meg.
8486726[/snapback]
Det er vanligvis ikke noe problem lenger. Når du har installert ubuntu kjører du "Restricted Drivers Manager" som du finner gjennom menyene: System->Administration
Hvis du har behov for en ufri skjermkort-driver vil restricted drivers manager gi deg beskjed og du kan installere den der ved hjelp av ett klikk på knappen "install". Da vil den lastes ned fra nettet og installeres, så vil du få beskjed om å starte om, så var det gjort.
8486005[/snapback]
De er støttet av den ufrie driveren, men en bug i den frie vesa driveren har ført til at mange med dette kortet blir sendt rett til kommandolinjen. Dette kan løses ved at man installerer den ufrie driveren, noe som ikke er helt nybegynnervenlig, desverre, men absolutt ikke spesielt vanskelig.
Jeg skulle teste ut ubuntu i sta, men jeg fikk bare en svart skjer etter at jeg startet ubuntu fra den første menyen. Så prøvde jeg den tidligere versjonen som jeg har liggende, men den kom ikke lengere enn til etter at ubuntu hadde loada. Der fikk jeg en hvit skjerm og beskjed om at noen var galt med X graphic driver eller neo.
8489958[/snapback]
Prøv å bruke Safe Graphics eller å hente ned Alternate cden. Noen ganger fungerer det rett og slett ikke live med den vanlige cden.
