tommern7 Skrevet 21. april 2007 Del Skrevet 21. april 2007 Får denne erroren nesten hele tiden når jeg spiller wow World of WarCraft (build 6546) Exe: C:\Programfiler\World of Warcraft\WoW.exe Time: Apr 20, 2007 1:21:52.765 PM User: **** Computer: **** ------------------------------------------------------------------------------ This application has encountered a critical error: ERROR #132 (0x85100084) Fatal Exception Program: C:\Programfiler\World of Warcraft\WoW.exe Exception: 0xC0000005 (ACCESS_VIOLATION) at 001B:007613F6 The instruction at "0x007613F6" referenced memory at "0xEB965835". The memory could not be "read". WoWBuild: 6546 Håper det er noen her som vet hvordan man kan løse dette problemet. mvh, Tommern7 Lenke til kommentar
Skarstard Skrevet 21. april 2007 Del Skrevet 21. april 2007 (endret) Har du prøvd repair.exe? Endret 21. april 2007 av Skarstad Lenke til kommentar
tommern7 Skrevet 21. april 2007 Forfatter Del Skrevet 21. april 2007 Har du prøvd repair.exe? 8439985[/snapback] ja, har også prøvd å slette interface mappen osv. har også prøvd med forskjellige minnebrikker. Lenke til kommentar
Skarstard Skrevet 21. april 2007 Del Skrevet 21. april 2007 The 132 error message you are experiencing can be caused by many things. If you haven’t yet, please try the following steps first. Remove Any Temporary Files Navigate to your World of Warcraft/Burning Crusade installation directory on your hard drive (the default locatation is C:\Program Files\World of Warcraft\). If you have an Interface folder, rename it or delete it completely, then remove all the files in your Cache and WTF folders. These files will be recreated with default values the next time you run the game. Please note that if you haven't successfully gotten into the game yet, these folders may not exist. If that is the case, please move on to the next step. Lenke til kommentar
Defo Skrevet 22. april 2007 Del Skrevet 22. april 2007 (endret) Siden vi er inne på temaet. Kan noen hjelpe med denne? WoWBuild: 6546 Local Zone: Ironforge Local Player: Unknown, 0000000000ADB87F, (-4621.61,-922.25,502.812) Add Ons: Ace2 Arcanum Bartender3 Buffalo !BugGrabber Cartographer cyCircled DeuceCommander DHUD FuBar_FuXPFu FuBar_MoneyFu FuBar JIM_CooldownPulse CEnemyCastBar oCB Prat simpleMinimap Skinner ========================================================= Exception Raised! App: /Users/petterl/Gamle lekser/World of Warcraft.app Exception: SIGBUS Error Code: 0x85100086 Time: 2007-04-22 13.45.53 CEST Error: signo: 10, Fault address: 0x0000000e, code(1): Invalid address alignment. --------------------------------------------------------- Bruker mac og ikke Windows btw. Anyone? Endret 22. april 2007 av defo Lenke til kommentar
cashstillrules Skrevet 22. april 2007 Del Skrevet 22. april 2007 slett cache mappen i wow foldern. Lenke til kommentar
JohndoeMAKT Skrevet 22. april 2007 Del Skrevet 22. april 2007 Emnetittelen i denne tråden er lite beskrivende for trådens innhold og det er derfor ingen god emnetittel. Jo bedre og mer beskrivende emnetittelen er, jo lettere er det for andre å skjønne trådens innhold og det vil være lettere å treffe den riktige forumbrukeren med det rette svaret. Ber deg derfor om å endre emnetittel slik at du unngår at en moderator stenger tråden. Vennligst forsøk å tenk på dette neste gang du starter en tråd, og orienter deg om hva vår nettikette sier om dårlig bruk av emnetitler. Bruk -knappen i første post for å endre emnetittelen. Tråden bryter også med tre-ords-regelen. (Dette innlegget vil bli fjernet ved endring av emnetittel. Ikke kommenter dette innlegget, men ta gjerne og dette innlegget når tittelen er endret, så vil det bli fjernet.) Lenke til kommentar
John Keats Skrevet 22. april 2007 Del Skrevet 22. april 2007 Siden vi er inne på temaet. Kan noen hjelpe med denne? WoWBuild: 6546 Local Zone: Ironforge Local Player: Unknown, 0000000000ADB87F, (-4621.61,-922.25,502.812) Add Ons: Ace2 Arcanum Bartender3 Buffalo !BugGrabber Cartographer cyCircled DeuceCommander DHUD FuBar_FuXPFu FuBar_MoneyFu FuBar JIM_CooldownPulse CEnemyCastBar oCB Prat simpleMinimap Skinner ========================================================= Exception Raised! App: /Users/petterl/Gamle lekser/World of Warcraft.app Exception: SIGBUS Error Code: 0x85100086 Time: 2007-04-22 13.45.53 CEST Error: signo: 10, Fault address: 0x0000000e, code(1): Invalid address alignment. --------------------------------------------------------- Bruker mac og ikke Windows btw. Anyone? 8443031[/snapback] Noen som ikke egentlig får lov å spille wow? Lenke til kommentar
øl_i_tastaturet Skrevet 22. april 2007 Del Skrevet 22. april 2007 (endret) Noen som ikke egentlig får lov å spille wow? 8443764[/snapback] hahaha Dagens. Quote forminsket av moderator Endret 23. april 2007 av JohndoeMAKT Lenke til kommentar
Defo Skrevet 22. april 2007 Del Skrevet 22. april 2007 (endret) hahaha Dagens. 8443844[/snapback] Haha, tenkte ikke over den der :!: Er skole-mac så best å være på den trygge siden. Quote forminsket av moderator Endret 23. april 2007 av JohndoeMAKT Lenke til kommentar
brillan Skrevet 23. april 2007 Del Skrevet 23. april 2007 Noen som ikke egentlig får lov å spille wow? tongue.gif Tenkte det samme ^^ Lenke til kommentar
Phyx Skrevet 23. april 2007 Del Skrevet 23. april 2007 (endret) Tilbake til trådstarter. Jeg har hatt det samme problemet og det , for min del var en minne feil. For noen så holder det med og rengöre maskinen for stöv. om ikke test en memtest og se om det kan väre noen problemer med minnet ditt. Jeg löste min feil ved og kjöpe nytt minne Noen har löst problemet med og slette /cache mappen. EDIT: Måtte bare sjekke etterpå att ttt ikke hade bumpet denne posten også Endret 23. april 2007 av Phyx Lenke til kommentar
JohndoeMAKT Skrevet 24. april 2007 Del Skrevet 24. april 2007 Stenges grunnet brudd på tre-ords-regelen. Lenke til kommentar
