Tommy220 Skrevet 21. april 2007 Del Skrevet 21. april 2007 (endret) Fikk en gammel dell PC av broren min siden den gammle laptopen min tok dagen. Hvordan kan oppgradere denne pc best mulig uten å bruke alt for mye penger. her er det som er i pc nå. CPU-Z 1.39 report file Processor(s) Number of processors 1 Number of cores 1 per processor Number of threads 1 (max 1) per processor Name Intel Pentium 4 Code Name Northwood Specification Intel® Pentium® 4 CPU 2.66GHz Package Socket 478 mPGA Family/Model/Stepping F.2.9 Extended Family/Model F.2 Brand ID 9 Core Stepping D1 Technology 0.13 um Core Speed 2660.0 MHz Multiplier x Bus speed 20.0 x 133.0 MHz Rated Bus speed 532.0 MHz Stock frequency 2666 MHz Instruction sets MMX, SSE, SSE2 L1 Data cache 8 KBytes, 4-way set associative, 64-byte line size Trace cache 12 Kuops, 8-way set associative L2 cache 512 KBytes, 8-way set associative, 64-byte line size Chipset & Memory Northbridge Intel i865P/PE/G/i848P rev. A2 Southbridge Intel 82801EB (ICH5) rev. 02 Graphic Interface AGP AGP Revision 3.0 AGP Transfer Rate 8x AGP Side Band Addressing supported, enabled Memory Type DDR Memory Size 512 MBytes Memory Frequency 166.3 MHz (4:5) CAS# Latency (tCL) 2.5 clocks RAS# to CAS# (tRDC) 3 clocks RAS# Precharge (tRP) 3 clocks Cycle Time (tRAS) 7 clocks Performance Mode enabled System System Manufacturer Dell Computer Corporation System Name Dimension 4600 System S/N 6JQPW0J Mainboard Vendor Dell Computer Corp. Mainboard Model 02Y832 BIOS Vendor Dell Computer Corporation BIOS Version A03 BIOS Date 07/21/2003 Memory SPD Module 1 DDR, PC2700 (166 MHz), 256 MBytes, MOSEL Module 2 DDR, PC2700 (166 MHz), 256 MBytes, MOSEL Software Windows Version Microsoft Windows XP Home Edition Service Pack 2 (Build 2600) DirectX Version 9.0c Endret 21. april 2007 av Tommy220 Lenke til kommentar
pizzafordi Skrevet 21. april 2007 Del Skrevet 21. april 2007 (endret) du har 512mb ram, du må minst ha 1gb for at det skal være brukbart til gaming. Helst bør en ha 2b, fordi med windows og spill på full oppløsning så krever det over 1gb, opp til 1.5gb totalt inkludert spyware og windows rot. Derimot til den eldre maskinen der max 1gb, det svarer seg ikke å invistere i mer, dessuten så vill ikke den prosessor hastigheten der klare å benytte seg av særlig mer sammens med skjermkort. http://www.netshop.no/aspx/produkt/prdinfo...aspx?plid=37376 raskt agp 8x skjermkort, dagens standard er pci-express x16 (hastighet) http://www.netshop.no/aspx/produkt/prdinfo....aspx?plid=1042 pc2700 pc3200 denne nedklokkes til pc2700 i bios, det er normalt. regner med at ingenting skal tulle her. skjermkortet brukes også minimalt med strøm, så hvis du har en 300 watt så skal det kunne gå, men ikke mye mer. SUM: 1 240,- pluss frakt ca 90kr Endret 21. april 2007 av pizzafordi Lenke til kommentar
Tommy220 Skrevet 21. april 2007 Forfatter Del Skrevet 21. april 2007 du har 512mb ram, du må minst ha 1gb for at det skal være brukbart til gaming. Helst bør en ha 2b, fordi med windows og spill på full oppløsning så krever det over 1gb, opp til 1.5gb totalt inkludert spyware og windows rot. Derimot til den eldre maskinen der max 1gb, det svarer seg ikke å invistere i mer, dessuten så vill ikke den prosessor hastigheten der klare å benytte seg av særlig mer sammens med skjermkort. http://www.netshop.no/aspx/produkt/prdinfo...aspx?plid=37376 raskt agp 8x skjermkort, dagens standard er pci-express x16 (hastighet) http://www.netshop.no/aspx/produkt/prdinfo....aspx?plid=1042 pc2700 pc3200 denne nedklokkes til pc2700 i bios, det er normalt. regner med at ingenting skal tulle her. skjermkortet brukes også minimalt med strøm, så hvis du har en 300 watt så skal det kunne gå, men ikke mye mer. SUM: 1 240,- pluss frakt ca 90kr 8435368[/snapback] Takk for raskt svar tenke jeg kunne kjøpe noen delere som også kan bruke når jeg skal oppgradere senere. Hva er det som anbefals da? Lenke til kommentar
pizzafordi Skrevet 21. april 2007 Del Skrevet 21. april 2007 (endret) kabinett, strømforsyning, harddisk, dvd brenner. lcd skjerm, mus, matte, keyboard, lyd, mikrofon, battlefield. rammen er utgått 478 er utgått hovedkort,prosessor, ram 3000-3500kr for dagens top notch. 2300kr for dagens top notch skjermkort, og da trengs det strømforsyning til så det blir fort 6000kr. du kan leve på det du har en stund, med en lettere oppgradering. lag gjerne en pc-børse, penger som kun skal brukes til maskin og ikke øl. Endret 21. april 2007 av pizzafordi Lenke til kommentar
HilRam Skrevet 21. april 2007 Del Skrevet 21. april 2007 (endret) Og selv om du får tak i en billig, brukt S478 Pentium 4, så er det ikke sikkert du kan bytte den likevel. Det hender at Dell og HP limer prosessoren til sokkelen, slik at den går i stykker hvis du prøver å ta den ut. Dersom du vil beholde harddisk, optisk drev og kabinett, så kan du se på Denne oppgraderingspakken. Drøye to og et halvt tusen, så kan du spille spill på heltid. Endret 21. april 2007 av HilRam Lenke til kommentar
Tommy220 Skrevet 22. april 2007 Forfatter Del Skrevet 22. april 2007 takker for rakse svar her. Som dere sier så er det mye gammelt i denne maskinen. Sparer eller pengen mine til ny maskin en å oppgradere her. Takker igjen for alle svar og anbefalinger. Lenke til kommentar
pizzafordi Skrevet 22. april 2007 Del Skrevet 22. april 2007 takker for rakse svar her. Som dere sier så er det mye gammelt i denne maskinen. Sparer eller pengen mine til ny maskin en å oppgradere her. Takker igjen for alle svar og anbefalinger. 8441975[/snapback] SUM: 1 240,- pluss frakt ca 90kr du kan også kjøpe brukt ram, men 300kr for 500mb ram er lite. dessuten kan du skaffe deg et rimelig agp kort brukt. http://www.bruktmarked.no/annonse.php?a=86588 250kr er det verdt. ram 300kr. så har du noe å leve på. og kan selge igjen når du har spart opp. og får omtrent det samme igjen. Lenke til kommentar
