Hefalompen Skrevet 20. april 2007 Rapporter Del Skrevet 20. april 2007 (endret) Som sysadmin så har jeg ikke så mye peiling på programering. Siden min findfilefast.com har en opplastingsfunksjon som jeg bruker litt selv. Derimot så trenger jeg å vite hva som må inn i scriptet for at jeg skal kunne gå automatisk videre til Opplastningssiden når skriptet er kjørt. Hva og hvor plasserer jeg det. Her er skriptet: Klikk for å se/fjerne innholdet nedenfor <?php/* The following file enables the uploading of each image from the java applet. PLEASE NOTE, THIS FILES IN ITS PRESENT FORM IS A MASSIVE SECURITY RISK, AND SHOULD NOT BE USED WITHOUT DOING EITHER OF THE FOLLOWING: - PROTECTING THE ACCESS OF THE FILE BY THE USE OF SESSION VARIABLES (DO NOT PROTECT IT BY USING HTTP PASSWORDS) - ENSURING THAT UPLOADED FILES ARE NOT ACCESSIBLE TO THE WEB (UPLOAD FILES TO A DIRECTORY ABOVE THE DOCUMENT ROOT) */ /* AS OF POSTLET 0.11, POSTLET READS THE MESSAGES SENT BACK TO IT, AND NOW IS AWARE OF WHETHER OR NOT AN UPLOAD HAS BEEN SUCCESSFUL. MORE INFORMATION ABOUT THE FORMAT OF REPLY MESSAGES CAN BE FOUND ON THE POSTLET WEBSITE http://www.postlet.com/install/ */ // Configuration --------------------------------------------------------------- // Change the below path to the folder where you would like files uploading. // e.g. "/home/yourname/myuploads/" // or "c:\php\uploads\" // Note, this MUST have the trailing slash. $uploaddir = "/hsphere/local/home/findfile/share.findfilefast.com/"; // Whether or not to allow the upload of specific files $allow_or_deny = true; // If the above is true, then this states whether the array of files is a list of // extensions to ALLOW, or DENY $allow_or_deny_method = "deny"; // "allow" or "deny" $file_extension_list = array("php","asp","pl"); // ----------------------------------------------------------------------------- if ($allow_or_deny){ if (($allow_or_deny_method == "allow" && !in_array(strtolower(array_pop(explode('.', $_FILES['userfile']['name']))), $file_extension_list)) || ($allow_or_deny_method == "deny" && in_array(strtolower(array_pop(explode('.', $_FILES['userfile']['name']))), $file_extension_list))){ // Atempt to upload a file with a specific extension when NOT allowed. // 403 error header("HTTP/1.1 403 Forbidden"); echo "POSTLET REPLY\r\n"; echo "POSTLET:NO\r\n"; echo "POSTLET:FILE TYPE NOT ALLOWED\r\n"; echo "POSTLET:ABORT THIS\r\n"; // Postlet should NOT send this file again. echo "END POSTLET REPLY\r\n"; exit; } } if (move_uploaded_file($_FILES['userfile']['tmp_name'], $uploaddir .$_FILES['userfile']['name'])) { // All replies MUST start with "POSTLET REPLY", if they don't, then Postlet will // not read the reply and will assume the file uploaded successfully. echo "POSTLET REPLY\r\n"; // "YES" tells Postlet that this file was successfully uploaded. echo "POSTLET:YES\r\n"; // End the Postlet reply echo "END POSTLET REPLY\r\n"; exit; } else { // If the file can not be uploaded (most likely due to size), then output the // correct error code // If $_FILES is EMPTY, or $_FILES['userfile']['error']==1 then TOO LARGE if (count($_FILES)==0 || $_FILES['userfile']['error']==1){ // All replies MUST start with "POSTLET REPLY", if they don't, then Postlet will // not read the reply and will assume the file uploaded successfully. header("HTTP/1.1 413 Request Entity Too Large"); echo "POSTLET REPLY\r\n"; echo "POSTLET:NO\r\n"; echo "POSTLET:TOO LARGE\r\n"; echo "POSTLET:ABORT THIS\r\n"; // Postlet should NOT send this file again. echo "END POSTLET REPLY\r\n"; exit; } // Unable to write the file to the server ALL WILL FAIL else if ($_FILES['userfile']['error']==6 || $_FILES['userfile']['error']==7){ // All replies MUST start with "POSTLET REPLY", if they don't, then Postlet will // not read the reply and will assume the file uploaded successfully. header("HTTP/1.1 500 Internal Server Error"); echo "POSTLET REPLY\r\n"; echo "POSTLET:NO\r\n"; echo "POSTLET:SERVER ERROR\r\n"; echo "POSTLET:ABORT ALL\r\n"; // Postlet should NOT send any more files echo "END POSTLET REPLY\r\n"; exit; } // Unsure of the error here (leaves 2,3,4, which means try again) else { // All replies MUST start with "POSTLET REPLY", if they don't, then Postlet will // not read the reply and will assume the file uploaded successfully. header("HTTP/1.1 500 Internal Server Error"); echo "POSTLET REPLY\r\n"; echo "POSTLET:NO\r\n"; echo "POSTLET:UNKNOWN ERROR\r\n"; echo "POSTLET:RETRY\r\n"; print_r($_REQUEST); // Possible usefull for debugging echo "END POSTLET REPLY\r\n"; exit; } } ?> Bør vel kanskje legge inn en tidsforsinkelse slik at man ser om det ble ok eller ikke. Endret 20. april 2007 av Hefalompen Lenke til kommentar
Rinox Skrevet 20. april 2007 Rapporter Del Skrevet 20. april 2007 Er ikke sikker på om jeg forsto spørsmålet ditt, men vil du at scriptet ditt skal kjøres og når det er ferdig så skal nettleseren oppdateres til en ny side? I så fall kan du bruke header("Location: http://www.example.com/"); Lenke til kommentar
grimjoey Skrevet 20. april 2007 Rapporter Del Skrevet 20. april 2007 (endret) eller <meta http-equiv="refresh" content="antall_sekunder,'URL_til_side'"> innen for <head></head> Endret 20. april 2007 av grimjoey Lenke til kommentar
Hefalompen Skrevet 22. april 2007 Forfatter Rapporter Del Skrevet 22. april 2007 Takk begge. Jeg skal prøve scriptet og evnt. sjekke den siden. Lenke til kommentar
