Ratleto Skrevet 19. april 2007 Del Skrevet 19. april 2007 Har en eldre maskin med Clarkconnect (Community v4 SP1, gatewaymodus) gående her. Den er bare på 350 Mhz med 320 MB RAM. HDen er på 5 GB, med bl.a. 512 MB swap. Ifølge monitoren er "Memory Utilization" som følger: Physical: 12.26 MB free / 313.37 MB total Virtual: 509.87 MB free / 509,87 MB total Likevel går harddisken hele tida, dvs den leser eller skriver noe ca. 1 gang i sekundet, og gir fra seg et typisk "tikk". Services: Klikk for å se/fjerne innholdet nedenfor auditd is stoppedbacula-dir is stopped bacula-fd is stopped bacula-mysqld is stopped bacula-sd is stopped crond (pid 1712) is running... ddclient dead but pid file exists dnsmasq (pid 21843) is running... Table: filter Chain INPUT (policy DROP 0 packets, 0 bytes) (... en lang liste med med brannmur-ting) httpd (pid 1707 1706 1705 1704 1703 1698) is running... IPsec stopped kolabd (pid 1786 1733) is running... slapd (pid 4502) is running... slurpd (pid 4509) is running... mdmpd is stopped mysqld is stopped netplugd is stopped Configured devices: lo eth0 eth1 ppp0 Currently active devices: lo eth0 eth1 ppp0 ntpd is stopped master is stopped pptpd is stopped proftpd is stopped saslauthd (pid 1728 1727 1726 1725 1721) is running... snort (pid 17638) is running... snortsam (pid 27354) is running... squid is stopped sshd (pid 914 1619) is running... Server Started Source Type ------ ------------------------------ ----------------------- ------ 1907 Apr 16 14:18:35 ( 3 02:32:16) N/A Master 1 Master server. syslogd (pid 1464) is running... klogd (pid 1468) is running... system-mysqld (pid 1667) is running... syswatch (pid 26881) is running... webconfig (pid 1960 1832 683 1937) is running... winbindd is stopped Noen som aner hva jeg kan gjøre for å få slutt på HD-bruken? Vet at mere minne kan hjelpe på, men det er begrensa hva jeg har liggende av SDRAM her. Lenke til kommentar
Ratleto Skrevet 20. april 2007 Forfatter Del Skrevet 20. april 2007 (endret) Liten bump siden ingen har svart... Tok tida istad. Det er faktisk ganske nøyaktig ett skrive/lese-tikk pr 0,5 sekunder. Top: Klikk for å se/fjerne innholdet nedenfor top - 13:59:34 up 3 days, 23:42, 1 user, load average: 1.03, 0.64, 0.56 Tasks: 58 total, 2 running, 56 sleeping, 0 stopped, 0 zombie Cpu(s): 8.4% us, 14.6% sy, 0.0% ni, 75.3% id, 0.6% wa, 1.0% hi, 0.0% si Mem: 320888k total, 310300k used, 10588k free, 49976k buffers Swap: 522104k total, 0k used, 522104k free, 84088k cached PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 16899 root 15 0 1488 516 448 S 13.0 0.2 516:47.49 pppoe 17638 root 15 0 72464 66m 924 S 7.2 21.3 285:46.01 snort 13335 root 16 0 7652 2224 1796 S 0.7 0.7 0:00.19 sshd 13363 root 17 0 3576 996 792 R 0.7 0.3 0:00.14 top 2 root 34 19 0 0 0 R 0.3 0.0 12:30.36 ksoftirqd/0 1 root 16 0 3556 588 504 S 0.0 0.2 0:01.10 init 3 root 5 -10 0 0 0 S 0.0 0.0 0:00.13 events/0 4 root 6 -10 0 0 0 S 0.0 0.0 0:00.05 khelper 5 root 5 -10 0 0 0 S 0.0 0.0 0:00.00 kblockd/0 6 root 15 0 0 0 0 S 0.0 0.0 0:00.00 khubd 37 root 20 0 0 0 0 S 0.0 0.0 0:00.00 pdflush 38 root 15 0 0 0 0 S 0.0 0.0 0:06.74 pdflush 40 root 7 -10 0 0 0 S 0.0 0.0 0:00.00 aio/0 34 root 15 0 0 0 0 S 0.0 0.0 0:00.77 kapmd 39 root 15 0 0 0 0 S 0.0 0.0 0:01.29 kswapd0 186 root 25 0 0 0 0 S 0.0 0.0 0:00.00 kseriod 297 root 15 0 0 0 0 S 0.0 0.0 6:34.75 kjournald Har registert at ledig minne varierer fra 10-20 MB. Ingen mistenkelige innlogginger e.l. Edit: Er det noen programmer som kan gi meg info om hva/hvilke programmer som skriver eller leser fra HD? Endret 20. april 2007 av Ratleto Lenke til kommentar
olefiver Skrevet 20. april 2007 Del Skrevet 20. april 2007 Lurer litt på hvorfor du er så keen på å kutte HD bruken, men greit nok. Hva er det du kjører på den serveren? Min umiddelbare tanke er en eller annen loggingsprosess som skriver til en loggfil. Du kan evt titte på hdparm kommandoen. Opsjon -S mener jeg setter spindown tid på disken, slik at disken stanser etter en viss tid med inaktivitet. Ikke alle gamle maskiner hvor slikt skjer automagisk fra BIOS... Lenke til kommentar
Ratleto Skrevet 20. april 2007 Forfatter Del Skrevet 20. april 2007 Lurer litt på hvorfor du er så keen på å kutte HD bruken, men greit nok.Hva er det du kjører på den serveren? Min umiddelbare tanke er en eller annen loggingsprosess som skriver til en loggfil. Du kan evt titte på hdparm kommandoen. Opsjon -S mener jeg setter spindown tid på disken, slik at disken stanser etter en viss tid med inaktivitet. Ikke alle gamle maskiner hvor slikt skjer automagisk fra BIOS... 8429135[/snapback] Grunnen til at jeg ønsker at HDen skal roe ned litt, er at den står i et felles rom, og HD-bruken høres ganske langt. Hva jeg kjører på serveren, kan du se av "services" i første posten. Lenke til kommentar
Ratleto Skrevet 20. april 2007 Forfatter Del Skrevet 20. april 2007 (endret) Loggfil var lurt å sjekke ja. "messages" er FULL av dnsmasq-linjer, og det er de samme to linjene 2 ganger pr sekund. Det er kun dette som går hele tida: Apr 20 15:08:14 Clark dnsmasq[21843]: DHCPDISCOVER(eth1) 00:05:5d:db:54:46 Apr 20 15:08:14 Clark dnsmasq[21843]: DHCPOFFER(eth1) 10.0.0.136 00:05:5d:db:54:46 Hva er det for noe...? Jeg må jo ha dnsmasq for å kjøre DHCP på serveren. 10.0.0.136 er forresten ikke en maskin på nettverket engang... DHCP deler dog ut IPer fra 10.0.0.100 til 10.0.0.150. Hjelp! Dette er forresten /etc/dnsmasq/dhcp.conf # cat dhcp.conf dhcp-option=eth1,1,255.255.255.0 dhcp-option=eth1,28,10.0.0.255 dhcp-option=eth1,3,10.0.0.1 dhcp-option=eth1,6,217.13.4.24,217.13.7.140 dhcp-range=eth1,10.0.0.100,10.0.0.150,12h read-ethers Endret 20. april 2007 av Ratleto Lenke til kommentar
Ratleto Skrevet 20. april 2007 Forfatter Del Skrevet 20. april 2007 Starter en ny tråd, jeg, siden årsaken er funnet (dnsmasq), men ingen løsning. Lenke til kommentar
