Impreza_wrcsti Skrevet 19. april 2007 Del Skrevet 19. april 2007 (endret) Hi all. Due to me being a plonka and ruining my hard drive while drunk last night I am in need of a replacement. So Im hoping perhaps someone has a hard drive laying around that is damaged or not needed rather than buying a brand new one. I am planning on taking the circuit board out and replacing it with the working one. So if anyone has one I would be very grateful. Maxtor DiamondMax 10 200GB SATA 8MB 7200RPM https://www.diskusjon.no/index.php?showtopi...5entry8421475 Endret 24. april 2007 av Impreza_wrcsti Lenke til kommentar
cdr Skrevet 20. april 2007 Del Skrevet 20. april 2007 Wow, dude, is that really worth the time and effort? Those disks are really cheap at the moment. Anyway, good luck in finding a replacement Lenke til kommentar
Impreza_wrcsti Skrevet 20. april 2007 Forfatter Del Skrevet 20. april 2007 Wow, dude, is that really worth the time and effort? Those disks are really cheap at the moment.Anyway, good luck in finding a replacement 8429288[/snapback] Yeah I have ordered one just now. Alot of the information on the disk is important so I have to try. Rather buy a new one for 900kr than send it in to be profesionally recovered costing alot more. Just hoped someone had one laying around. Lenke til kommentar
Impreza_wrcsti Skrevet 24. april 2007 Forfatter Del Skrevet 24. april 2007 Hi all. Turns out made anothe mistake.... Lots at the moment. I need a 200gb hard drive and cant buy it in norway anymore..... model number is 6B200MO (6B200MO4601A) So if you have one please..... please let me know if you want to sell it. Thanks in advance.... Lenke til kommentar
netphreak Skrevet 24. april 2007 Del Skrevet 24. april 2007 I think I have one... Maybe 2 years old? I can check the modelnumber tomorrow. Lenke til kommentar
Impreza_wrcsti Skrevet 25. april 2007 Forfatter Del Skrevet 25. april 2007 I think I have one... Maybe 2 years old? I can check the modelnumber tomorrow. 8465123[/snapback] Seriously... Thats excellent. Fingers crossed that its the correct model number. Lenke til kommentar
Impreza_wrcsti Skrevet 26. april 2007 Forfatter Del Skrevet 26. april 2007 I think I have one... Maybe 2 years old? I can check the modelnumber tomorrow. 8465123[/snapback] Unfortunatly wrong number. So anyone else out there with one they want to sell to me? Thanks. Lenke til kommentar
AndArne Skrevet 26. april 2007 Del Skrevet 26. april 2007 Hi Ive got a 6B200MO running back home, I think. I'll verify it later this evening and let you know. ArneAnd Lenke til kommentar
Impreza_wrcsti Skrevet 26. april 2007 Forfatter Del Skrevet 26. april 2007 Hi Ive got a 6B200MO running back home, I think. I'll verify it later this evening and let you know. ArneAnd 8474696[/snapback] Excellent. If you do just let me know how much you want for it including postage to drammen! Thanks alot mate! Lenke til kommentar
AndArne Skrevet 26. april 2007 Del Skrevet 26. april 2007 Problem is that this is my Xp disk. I wont be able to free it up before my next reinstall, which is scheduled in the near future. I'll let you know later today. A Lenke til kommentar
Impreza_wrcsti Skrevet 26. april 2007 Forfatter Del Skrevet 26. april 2007 Problem is that this is my Xp disk. I wont be able to free it up before my next reinstall, which is scheduled in the near future. I'll let you know later today. A 8474797[/snapback] Ah ok then. Roughly how long are we talking about? Lenke til kommentar
osse-mon waits for alice Skrevet 26. april 2007 Del Skrevet 26. april 2007 I'll check my disks too... Might have a 200GB with that model-number. Lenke til kommentar
Zash Skrevet 26. april 2007 Del Skrevet 26. april 2007 Ill check home aswell, thing i have a 200gb maxtor somewhere;) Lenke til kommentar
Impreza_wrcsti Skrevet 26. april 2007 Forfatter Del Skrevet 26. april 2007 I'll check my disks too... Might have a 200GB with that model-number. 8475018[/snapback] Ill check home aswell, thing i have a 200gb maxtor somewhere;) 8475030[/snapback] Excellent guys, thanks! Lenke til kommentar
AndArne Skrevet 26. april 2007 Del Skrevet 26. april 2007 Hi Just confirmed the disc. Its the one. Why dont you get back to me if the other guys "fails". As I said previously I need to reinstall XP to free this disc, and that wont happen untill end of May (awaiting some new discs). I'll check back to this post after my reinstall to see whats your status. Best of luck to you! A Lenke til kommentar
Impreza_wrcsti Skrevet 26. april 2007 Forfatter Del Skrevet 26. april 2007 Hi Just confirmed the disc. Its the one. Why dont you get back to me if the other guys "fails". As I said previously I need to reinstall XP to free this disc, and that wont happen untill end of May (awaiting some new discs). I'll check back to this post after my reinstall to see whats your status. Best of luck to you! A 8478096[/snapback] Ah right, ok. Well good its the right one but bad that its not available to end of may. Have to forget about it then. Thanks anyway. Lenke til kommentar
AndArne Skrevet 27. april 2007 Del Skrevet 27. april 2007 (endret) Hi No luck from the other guys yet? Why dont you contact me on MSN later today, maybe we can work something out a bit faster :-) A Endret 27. april 2007 av AndArne Lenke til kommentar
AndArne Skrevet 27. april 2007 Del Skrevet 27. april 2007 (endret) Hi there Ive spent some time rearranging my discs today, preparing for the reinstall. I could probably free the disc by next friday. I'll sell it to you for 500 kroner. The price is quite "stiff" for a used disc, but I'll need to replace it with a new one. Let me know if this is of interest to you. A Endret 27. april 2007 av AndArne Lenke til kommentar
Impreza_wrcsti Skrevet 27. april 2007 Forfatter Del Skrevet 27. april 2007 Hi there Ive spent some time rearranging my discs today, preparing for the reinstall. I could probably free the disc by next friday. I'll sell it to you for 500 kroner. The price is quite "stiff" for a used disc, but I'll need to replace it with a new one. Let me know if this is of interest to you. A 8484533[/snapback] Hi there, thanks for the offer. I have one other option right now but to be honest, I really dont care where the disk comes from, as long as I can at least try and recover the data. Ill let you know in the next couple of days if you need to go to all the trouble. Thanks once again! Lenke til kommentar
AndArne Skrevet 27. april 2007 Del Skrevet 27. april 2007 Sure thing. I'll check back over the weekend. A Lenke til kommentar
