Login virker ikke!
Hei! Nå har jeg enda et problem i PHP som må fikses. På en av mine nettsider har jeg muølighet for registrering og innlogging, men innloggingen funker ikke, selv om registreringen legger inn alt i databasen. Hvorfor det?
Registrering:
Klikk for å se/fjerne innholdet nedenfor
<?php
ob_start();
include_once "config.php";
if (isset($_POST['register'])) {
$username = $_POST['username'];
$password = $_POST['pass'];
$cpassword = $_POST['cpass'];
$email = $_POST['emai1'];
if( empty($username) || empty($password) || empty($cpassword) || empty($email) ) {
 $output = 'Some fields were left empty.';
} elseif($password != $cpassword) {
 $output = 'Passwords do not match';
} elseif (mysql_num_rows(mysql_query("SELECT username FROM users WHERE username = " . Quote_Smart($username))) > 0) {
 $output = 'The email-address is already in use';
} elseif (mysql_num_rows(mysql_query("SELECT email FROM users WHERE email = " . Quote_Smart($email))) > 0) {
 $output = 'The username is already in use';
} else {
 $password = sha1($password);
 $query = mysql_query("INSERT INTO users (username, password, email) VALUES(" . Quote_Smart($username) . ", " . Quote_Smart($password) . "," . Quote_Smart($email) . ")");
 	$output = 'Registreringen var vellykket! Du kan trykke <a href="login.php">her</a> for å logge inn.';
} else {
$output = '<form method="POST">
 Brukernavn: <input type="text" size="15" maxlength="25" name="username"><br />
 Passord: <input type="password" size="15" maxlength="25" name="pass"><br />
 Gjenta passord: <input type="password" size="15" maxlength="25" name="cpass"><br />
 E-Post: <input type="text" size="15" maxlength="25" name="emai1"><br />
 <input name="register" type="submit" value="Bli medlem!">
</form>';
echo $output;
Login:
<?php
oB_start();
// allows you to use cookies.
include("config.php");
if (!$logged[username])
if (!$_POST[login])
echo("
<center><form method='POST'>
<table>
<tr>
<td align='right'>
Brukernavn: <input type='text' size='15' maxlength='25' name='username'>
</td>
</tr>
<tr>
<td align='right'>
Passord: <input type='password' size='15' maxlength='25' name='password'>
</td></tr><tr>
<td align='center'>
<input type='submit' name='login' value='Login'>
</td></tr><tr>
<td align='center'>
<a href='register.php'>Registrer her!</a>
</td></tr></table></form></center>");
if ($_POST[login]) {
// the form has been submitted.  We continue...
$username=$_POST['username'];
$password = md5($_POST[password]);
// the above lines set variables with the submitted information.
$info = mysql_query("SELECT * FROM users WHERE username = '$username'") or die(mysql_error());
$data = mysql_fetch_array($info);
if($data[password] != $password) {
// the password was not the user's password!
echo "Incorrect username or password!";
}else{
// the password was right!
$query = mysql_query("SELECT * FROM users WHERE username = '$username'") or die(mysql_error());
$user = mysql_fetch_array($query);
// gets the user's information
setcookie("id", $user[id],time()+(60*30), "/", "");
setcookie("pass", $user[password],time()+(60*30), "/", "");
// the above lines set 2 cookies. 1 with the user's id and another with his/her password.
echo ("<meta http-equiv='Refresh' content='0; URL=http://localhost'>");
// modify the above line...add in your site url instead of yoursite.com
else
// we now display the user controls.
$new = mysql_query("select * from pmessages where unread = 'unread' and touser = '$logged[username]'");
$new = mysql_num_rows($new);
echo ("<meta http-equiv='Refresh' content='0; URL=http://localhost/mafia'/>");
switch($_GET[act]) {
case 'logout':
 echo("Du er nå logget ut");
break;
Du får ingen feil melding? Bare at login er ugyldig, selv om du bruker rett brukernavn og passord? Er du sikker på at det er plass til hash'en i databasen, så den ikke blir kuttet? Har gjort denne feilen selv :blush:
Endret av mhbakke
