_norse_ Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 (endret) EvilAvatar forum tråd I følge denne tråden på Evil Avatar er PS3 FW1.7 tilgjengelig. Noen som har lastet den ned her?? 1. The ability to play PS1 games on your PS3 (you can download from the PS store and play the games on the PS3 as opposed to having to play on the PSP). 2. You can plug in any PS1/PS2 accessory and it will work and work with rumble. This means that you can plug in a PS2 controller if you happen to have a PS2 USB adapter, and it will rumble in PS2 games. You also can use steering wheels and any other vibrating accessory. 3. You can transfer your PS1 data to a PSP memory stick, and play on there. So you can copy your PS1 data to your PS3 through the memory card adapter, and then copy it onto a memory stick so you can have your PS1 saves for the PSP games you have. 4. PAL backwards compatibility has been greatly improved (according to NeoGAF). One user reports GT4, Devil May Cry 3, MGS2 works, Gradius V, Jak 3, Soul Calibur 3, Ratchet and Clank 1 and 2, all are outputting at 576p as well. 5. If you press triangle on your login (if you have multiple logins) you can set which one you want to auto-login. Endret 19. april 2007 av Norse360 Lenke til kommentar
Bebeluv Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Driver og updater nå.. FW 1.70 ser ut som den er tilgjengelig ja =) Lenke til kommentar
vict0r Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Mye bra her! Ps1 spill! :!: Lenke til kommentar
Nimrad Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Herlig oppdatering! Håper BC-lista blir oppdatert snart. Lenke til kommentar
Rottenspacehead Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 (endret) Lastet ned jeg også nå = ) Endret 19. april 2007 av RockyIII Lenke til kommentar
Ghaundan Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 You also can use steering wheels and any other vibrating accessory. O.o ehm...jaja. Godt å se Sony tar oppdatering av PS3'n alvorlig, er nesten mål løs over hvor mye de har fått gjort den korte tiden PS3 har vært ute (med tanke på alt som har blitt fikset). Rett og slett toppers, Sony har iallefall fått løftet sin status i mine øyne, og jeg må nok svelge ett par ord angående oppdattering og Sony generelt Håper de kommer med ett par god biter som kanskje MS implementerer også Lenke til kommentar
Enigma123 Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Nice liste, skal laste ned snart:) Lenke til kommentar
Belzebob Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Nr. 5 på den lista (autologin) var no tilgjegeleg på 1.60 og. Lenke til kommentar
Tor Anders Berven Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Yes! Håper virkelig GT4 virker, dette er bra! Lenke til kommentar
tidus2k4 Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Nydelig update .. og casino royale i posten i dag toppers Lenke til kommentar
Tharos. Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Downloading! Men det gikk litt tregt. Noen som vet hvor stor den er? Lenke til kommentar
Ravn Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Synes God of War 2 flyter mye bedre på denne firmwaren enn den forrige Lenke til kommentar
BlastyTrasty Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Kva med skaleringsproblema? Playlists? Moglegheita til å høyre musikk medan eg surfar og er i butikken? Har dei tatt hånd om nokre av dei virkelege problema? Lenke til kommentar
Pastor Lorentzen Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Med unntak av bedre bakoverkompatibilitet er det i mine øyne ingenting å rope hurra for her. Ting tar vel tid. Lenke til kommentar
tidus2k4 Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Litt OT, men er ps store blitt oppdatert i dag også eller? Lenke til kommentar
Bertelsen Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Med unntak av bedre bakoverkompatibilitet er det i mine øyne ingenting å rope hurra for her. Ting tar vel tid. 8420119[/snapback] Helt enig, men det skal sies at Sony er flinke til å gi ut masse updates. Virker som det lurer forbrukeren til å tro at de bryr seg om oss. MS gir ut kun to store updates i året, og da virker det mer som at de gir fanden i oss. Litt vanskelig å forklare så tidlig om morgenen. Lenke til kommentar
Bromlexl Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Med unntak av bedre bakoverkompatibilitet er det i mine øyne ingenting å rope hurra for her. Ting tar vel tid. 8420119[/snapback] Enig. Dette er som en av de små oppdateringene på PSP som ingen egentlig bryr seg noe om. Å de har vel i likhet med Microsoft bare et par store oppdateringer i året. Så tror at viss vi skal ha skalering osv så vil det komme til høsten sammen med den store home updaten. Eller kanskje en litt større update i sommer. Lenke til kommentar
Belzebob Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Kva med skaleringsproblema?Playlists? Moglegheita til å høyre musikk medan eg surfar og er i butikken? Har dei tatt hånd om nokre av dei virkelege problema? 8420110[/snapback] Musikk medan du surfer fungerte no fint på 1.60 og. Trykk ps knappen på kontrolleren for å "løyse" deg ut av musikkspelaren (trykk den igjen for å hente den tilbake). Mister desverre musikken om du går på ps-store tho. Men surfing og litt andre ting funker fint. Lenke til kommentar
Wooho Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Nice ny update allerede. Hva slags PS1 spill kan lastes ned fra PS-store og games på PS3 da? Er ikke hjemem akkurat nå så får ikke testet. Lenke til kommentar
Ravn Skrevet 19. april 2007 Rapporter Del Skrevet 19. april 2007 Ingen spill enda, visstnok kun i Japan atm. Men det kommer nok Håper på mange kjekke gjensyn Lenke til kommentar
