Feil under compiling.
Hei, jeg har nettopp satt meg ned med Dev C++ og C++ For Dummies. Men jeg klarer ikke compile....jeg får en del errorer i Compile-prosessen:
Code:
22 C:Documents and SettingsAdministratorSkrivebordConversion.cpp:8
iostream.h: No such file or directory.
[Warning] In function:
13 C:Documents and SettingsAdministratorSkrivebordConversion.cpp
`cout'
(Each
14 C:Documents and SettingsAdministratorSkrivebordConversion.cpp
`cin'
2 C:Documents and SettingsAdministratorSkrivebordConversion.cpp:31
[Warning] no newline at end of file
Dette er errorene jeg får.
Her er kildekoden, hentet direkte fra Dummies CD'en:
Code:
// Conversion - convert temperature from Celsius
// degree units into Fahrenheit degree
// units:
// Fahrenheit = Celsius * (212 - 32)/100 + 32
#include <stdio.h>
#include <iostream.h>
int main(int nNumberofArgs, char* pszArgs[])
// enter the temperature in Celsius
int nCelsius;
cout << "Enter the temperature in Celsius:";
cin >> nCelsius;
// calculate conversion factor for Celsius
// to Fahrenheit
int nFactor;
nFactor = 212 - 32;
// use conversion factor to convert Celsius
// into Fahrenheit values
int nFahrenheit;
nFahrenheit = nFactor * nCelsius/100 + 32;
// output the results
cout << "Fahrenheit value is:";
cout << nFahrenheit;
return 0;
