Ubuntu restarter av seg selv
Hei,
Noe som kan forklare meg hva grunnen til dette er?
Apr 16 01:40:01 server /USR/SBIN/CRON[8322]: (www-data) CMD ([ -x /usr/lib/cgi-bin/awstats.pl -a -f /etc/awstats/awstats.conf -a -r /var/log/apache/access.log ] && /usr/lib/cgi-bin/awstats.pl -config=awstats -update >/dev/nul$
Apr 16 00:54:10 server syslogd 1.4.1#18ubuntu6: restart.
Apr 16 00:54:10 server kernel: Inspecting /boot/System.map-2.6.17-11-server
Apr 16 00:54:11 server kernel: Loaded 22862 symbols from /boot/System.map-2.6.17-11-server.
Apr 16 00:54:11 server kernel: Symbols match kernel version 2.6.17.
Det er ikke første gang det skjer, men det har gått en lengre periode siden sist. Sist gang ble det kjørt dist-upgrade, og alt fungerte tilsynelatende fint, til i natt..
Leste noen tråder på ubuntuforums.org om at det hadde skjedd flere, men fant ingen god forklaring der.
http://ubuntuforums.org/showthread.php?t=6...m+daily+restart
Veldig takknemlig for alle svar som kan bidra til å løse dette!
Endret av Crewer
Klikk for å se/fjerne innholdet nedenfor
Apr 16 00:54:11 server kernel: No module symbols loaded - kernel modules not enabled.
Apr 16 00:54:11 server kernel: [42949372.960000] Linux version 2.6.17-11-server (root@terranova) (gcc version 4.1.2 20060928 (prerelease) (Ubuntu 4.1.1-13ubuntu5)) #2 SMP Thu Feb 1 19:53:33 UTC 2007 (Ubuntu 2.6.17-11.35-server)
Apr 16 00:54:11 server kernel: [42949372.960000] BIOS-provided physical RAM map:
Apr 16 00:54:11 server kernel: [42949372.960000] BIOS-e820: 0000000000000000 - 000000000009f400 (usable)
Apr 16 00:54:11 server kernel: [42949372.960000] BIOS-e820: 000000000009f400 - 00000000000a0000 (reserved)
Apr 16 00:54:11 server kernel: [42949372.960000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Apr 16 00:54:11 server kernel: [42949372.960000] BIOS-e820: 0000000000100000 - 000000007f6e0000 (usable)
Apr 16 00:54:11 server kernel: [42949372.960000] BIOS-e820: 000000007f6e0000 - 000000007f6e3000 (ACPI NVS)
Apr 16 00:54:11 server kernel: [42949372.960000] BIOS-e820: 000000007f6e3000 - 000000007f6f0000 (ACPI data)
Apr 16 00:54:11 server kernel: [42949372.960000] BIOS-e820: 000000007f6f0000 - 000000007f700000 (reserved)
Apr 16 00:54:11 server kernel: [42949372.960000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
Apr 16 00:54:11 server kernel: [42949372.960000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
Apr 16 00:54:11 server kernel: [42949372.960000] 1142MB HIGHMEM available.
Apr 16 00:54:11 server kernel: [42949372.960000] 896MB LOWMEM available.
Apr 16 00:54:11 server kernel: [42949372.960000] found SMP MP-table at 000f3a60
Apr 16 00:54:11 server kernel: [42949372.960000] NX (Execute Disable) protection: active
Apr 16 00:54:11 server kernel: [42949372.960000] On node 0 totalpages: 521952
Apr 16 00:54:11 server kernel: [42949372.960000] DMA zone: 4096 pages, LIFO batch:0
Apr 16 00:54:11 server kernel: [42949372.960000] Normal zone: 225280 pages, LIFO batch:31
Apr 16 00:54:11 server kernel: [42949372.960000] HighMem zone: 292576 pages, LIFO batch:31
Apr 16 00:54:11 server kernel: [42949372.960000] DMI 2.3 present.
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: RSDP (v000 IntelR ) @ 0x000f7bc0
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: RSDT (v001 IntelR AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x7f6e3040
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: FADT (v001 IntelR AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x7f6e30c0
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: MCFG (v001 IntelR AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x7f6e7540
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: MADT (v001 IntelR AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x7f6e7440
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: SSDT (v001 PmRef Cpu0Ist 0x00003000 INTL 0x20041203) @ 0x7f6e75c0
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: SSDT (v001 PmRef CpuPm 0x00003000 INTL 0x20041203) @ 0x7f6e7a50
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: DSDT (v001 INTELR AWRDACPI 0x00001000 MSFT 0x0100000e) @ 0x00000000
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: PM-Timer IO Port: 0x408
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: Local APIC address 0xfee00000
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Apr 16 00:54:11 server kernel: [42949372.960000] Processor #0 15:4 APIC version 20
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
Apr 16 00:54:11 server kernel: [42949372.960000] Processor #1 15:4 APIC version 20
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] disabled)
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] disabled)
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
Apr 16 00:54:11 server kernel: [42949372.960000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: IOAPIC (id[0x05] address[0xfec84400] gsi_base[24])
Apr 16 00:54:11 server kernel: [42949372.960000] IOAPIC[1]: apic_id 5, version 32, address 0xfec84400, GSI 24-47
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: IRQ0 used by override.
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: IRQ2 used by override.
Apr 16 00:54:11 server kernel: [42949372.960000] ACPI: IRQ9 used by override.
Apr 16 00:54:11 server kernel: [42949372.960000] Enabling APIC mode: Flat. Using 2 I/O APICs
Apr 16 00:54:11 server kernel: [42949372.960000] Using ACPI (MADT) for SMP configuration information
Apr 16 00:54:11 server kernel: [42949372.960000] Allocating PCI resources starting at 80000000 (gap: 7f700000:60900000)
Apr 16 00:54:11 server kernel: [42949372.960000] Built 1 zonelists
Apr 16 00:54:11 server kernel: [42949372.960000] Kernel command line: root=/dev/sda1 ro quiet splash
Apr 16 00:54:11 server kernel: [42949372.960000] mapped APIC to ffffd000 (fee00000)
Apr 16 00:54:11 server kernel: [42949372.960000] mapped IOAPIC to ffffc000 (fec00000)
Apr 16 00:54:11 server kernel: [42949372.960000] mapped IOAPIC to ffffb000 (fec84400)
Apr 16 00:54:11 server kernel: [42949372.960000] Enabling fast FPU save and restore... done.
Apr 16 00:54:11 server kernel: [42949372.960000] Enabling unmasked SIMD FPU exception support... done.
Apr 16 00:54:11 server kernel: [42949372.960000] Initializing CPU#0
Apr 16 00:54:11 server kernel: [42949372.960000] PID hash table entries: 4096 (order: 12, 16384 bytes)
Apr 16 00:54:11 server kernel: [42949372.960000] Detected 3200.262 MHz processor.
Apr 16 00:54:11 server kernel: [42949372.960000] Using pmtmr for high-res timesource
Apr 16 00:54:11 server kernel: [42949372.960000] Console: colour VGA+ 80x25
Apr 16 00:54:11 server kernel: [42949373.260000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Apr 16 00:54:11 server kernel: [42949373.260000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Apr 16 00:54:11 server kernel: [42949373.330000] Memory: 2060424k/2087808k available (1904k kernel code, 26128k reserved, 1072k data, 312k init, 1170304k highmem)
Apr 16 00:54:11 server kernel: [42949373.330000] Checking if this processor honours the WP bit even in supervisor mode... Ok.
Apr 16 00:54:11 server kernel: [42949373.480000] Calibrating delay using timer specific routine.. 6406.54 BogoMIPS (lpj=32032747)
Apr 16 00:54:11 server kernel: [42949373.480000] Security Framework v1.0.0 initialized
Apr 16 00:54:11 server kernel: [42949373.480000] SELinux: Disabled at boot.
Apr 16 00:54:11 server kernel: [42949373.480000] Mount-cache hash table entries: 512
Apr 16 00:54:11 server kernel: [42949373.480000] CPU: After generic identify, caps: bfebfbff 20100000 00000000 00000000 0000649d 00000000 00000000
Apr 16 00:54:11 server kernel: [42949373.480000] CPU: After vendor identify, caps: bfebfbff 20100000 00000000 00000000 0000649d 00000000 00000000
Apr 16 00:54:11 server kernel: [42949373.480000] monitor/mwait feature present.
Apr 16 00:54:11 server kernel: [42949373.480000] using mwait in idle threads.
Apr 16 00:54:11 server kernel: [42949373.480000] CPU: Trace cache: 12K uops, L1 D cache: 16K
Apr 16 00:54:11 server kernel: [42949373.480000] CPU: L2 cache: 2048K
Apr 16 00:54:11 server kernel: [42949373.480000] CPU: Hyper-Threading is disabled
Apr 16 00:54:11 server kernel: [42949373.480000] CPU: After all inits, caps: bfebfbff 20100000 00000000 00000180 0000649d 00000000 00000000
Apr 16 00:54:11 server kernel: [42949373.480000] Checking 'hlt' instruction... OK.
Apr 16 00:54:11 server kernel: [42949373.520000] SMP alternatives: switching to UP code
Apr 16 00:54:11 server kernel: [42949373.520000] checking if image is initramfs... it is
Apr 16 00:54:11 server kernel: [42949373.890000] Freeing initrd memory: 5175k freed
Apr 16 00:54:11 server kernel: [42949373.890000] ACPI: Core revision 20060707
Apr 16 00:54:11 server kernel: [42949373.890000] ACPI: Looking for DSDT ... not found!
Apr 16 00:54:11 server kernel: [42949373.890000] CPU0: Intel® Pentium® 4 CPU 3.20GHz stepping 03
Apr 16 00:54:11 server kernel: [42949373.890000] SMP alternatives: switching to SMP code
Apr 16 00:54:11 server kernel: [42949373.890000] Booting processor 1/1 eip 3000
Apr 16 00:54:11 server kernel: [42949373.900000] Initializing CPU#1
Apr 16 00:54:11 server kernel: [42949374.050000] Calibrating delay using timer specific routine.. 6400.40 BogoMIPS (lpj=32002038)
Apr 16 00:54:11 server kernel: [42949374.050000] CPU: After generic identify, caps: bfebfbff 20100000 00000000 00000000 0000649d 00000000 00000000
Apr 16 00:54:11 server kernel: [42949374.050000] CPU: After vendor identify, caps: bfebfbff 20100000 00000000 00000000 0000649d 00000000 00000000
Apr 16 00:54:11 server kernel: [42949374.050000] monitor/mwait feature present.
Apr 16 00:54:11 server kernel: [42949374.050000] CPU: Trace cache: 12K uops, L1 D cache: 16K
Apr 16 00:54:11 server kernel: [42949374.050000] CPU: L2 cache: 2048K
Apr 16 00:54:11 server kernel: [42949374.050000] CPU: Hyper-Threading is disabled
Apr 16 00:54:11 server kernel: [42949374.050000] CPU: After all inits, caps: bfebfbff 20100000 00000000 00000180 0000649d 00000000 00000000
Apr 16 00:54:11 server kernel: [42949374.050000] CPU1: Intel® Pentium® 4 CPU 3.20GHz stepping 03
Apr 16 00:54:11 server kernel: [42949374.050000] Total of 2 processors activated (12806.95 BogoMIPS).
Apr 16 00:54:11 server kernel: [42949374.050000] ENABLING IO-APIC IRQs
Apr 16 00:54:11 server kernel: [42949374.050000] ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Apr 16 00:54:11 server kernel: [42949374.260000] checking TSC synchronization across 2 CPUs: passed.
Apr 16 00:54:11 server kernel: [42949374.270000] Brought up 2 CPUs
Apr 16 00:54:11 server kernel: [42949374.350000] migration_cost=10000
Apr 16 00:54:11 server kernel: [42949374.350000] NET: Registered protocol family 16
Apr 16 00:54:11 server kernel: [42949374.350000] EISA bus registered
Apr 16 00:54:11 server kernel: [42949374.350000] ACPI: bus type pci registered
Apr 16 00:54:11 server kernel: [42949374.350000] PCI: Using MMCONFIG
Apr 16 00:54:11 server kernel: [42949374.360000] Setting up standard PCI resources
Apr 16 00:54:11 server kernel: [42949374.360000] ACPI: Interpreter enabled
Apr 16 00:54:11 server kernel: [42949374.360000] ACPI: Using IOAPIC for interrupt routing
Apr 16 00:54:11 server kernel: [42949374.370000] ACPI: PCI Root Bridge [PCI0] (0000:00)
Apr 16 00:54:11 server kernel: [42949374.370000] PCI: Probing PCI hardware (bus 00)
Apr 16 00:54:11 server kernel: [42949374.370000] Boot video device is 0000:00:02.0
Apr 16 00:54:11 server kernel: [42949374.370000] PCI quirk: region 0400-047f claimed by ICH6 ACPI/GPIO/TCO
Apr 16 00:54:11 server kernel: [42949374.370000] PCI quirk: region 0480-04bf claimed by ICH6 GPIO
Apr 16 00:54:11 server kernel: [42949374.370000] PCI: Ignoring BAR0-3 of IDE controller 0000:00:1f.1
Apr 16 00:54:11 server kernel: [42949374.370000] PCI: PXH quirk detected, disabling MSI for SHPC device
Apr 16 00:54:11 server kernel: [42949374.370000] PCI: Transparent bridge - 0000:00:1e.0
Apr 16 00:54:11 server kernel: [42949374.370000] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
Apr 16 00:54:11 server kernel: [42949374.380000] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
Apr 16 00:54:11 server kernel: [42949374.380000] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX1._PRT]
Apr 16 00:54:11 server kernel: [42949374.380000] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
Apr 16 00:54:11 server kernel: [42949374.380000] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P1AB.PXHA._PRT]
Apr 16 00:54:11 server kernel: [42949374.380000] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 7 9 10 12 14 15)
Apr 16 00:54:11 server kernel: [42949374.380000] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 *12 14 15)
Apr 16 00:54:11 server kernel: [42949374.380000] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 9 *10 12 14 15)
Apr 16 00:54:11 server kernel: [42949374.380000] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 *10 12 14 15)
Apr 16 00:54:11 server kernel: [42949374.380000] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 12 14 15) *0, disabled.
Apr 16 00:54:11 server kernel: [42949374.380000] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 12 14 15) *0, disabled.
Apr 16 00:54:11 server kernel: [42949374.380000] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 7 9 10 12 14 15) *0, disabled.
Apr 16 00:54:11 server kernel: [42949374.380000] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 7 *9 10 12 14 15)
Apr 16 00:54:11 server kernel: [42949374.380000] Linux Plug and Play Support v0.97 © Adam Belay
Apr 16 00:54:11 server kernel: [42949374.380000] pnp: PnP ACPI init
Apr 16 00:54:11 server kernel: [42949374.390000] pnp: PnP ACPI: found 14 devices
Apr 16 00:54:11 server kernel: [42949374.390000] PnPBIOS: Disabled by ACPI PNP
Apr 16 00:54:11 server kernel: [42949374.390000] PCI: Using ACPI for IRQ routing
Apr 16 00:54:11 server kernel: [42949374.390000] PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
Apr 16 00:54:11 server kernel: [42949374.390000] pnp: 00:0a: ioport range 0x400-0x4bf could not be reserved
Apr 16 00:54:11 server kernel: [42949374.390000] PCI: Ignore bogus resource 6 [0:0] of 0000:00:02.0
Apr 16 00:54:11 server kernel: [42949374.390000] PCI: Bridge: 0000:01:00.0
Apr 16 00:54:11 server kernel: [42949374.390000] IO window: disabled.
Apr 16 00:54:11 server kernel: [42949374.390000] MEM window: disabled.
Apr 16 00:54:11 server kernel: [42949374.390000] PREFETCH window: disabled.
Apr 16 00:54:11 server kernel: [42949374.390000] PCI: Bridge: 0000:00:01.0
Apr 16 00:54:11 server kernel: [42949374.390000] MEM window: d0000000-d00fffff
Apr 16 00:54:11 server kernel: [42949374.390000] PCI: Bridge: 0000:00:1c.0
Apr 16 00:54:11 server kernel: [42949374.390000] MEM window: d0100000-d01fffff
Apr 16 00:54:11 server kernel: [42949374.390000] PCI: Bridge: 0000:00:1c.1
Apr 16 00:54:11 server kernel: [42949374.390000] MEM window: d0200000-d02fffff
Apr 16 00:54:11 server kernel: [42949374.390000] PCI: Bridge: 0000:00:1e.0
Apr 16 00:54:11 server kernel: [42949374.390000] ACPI: PCI Interrupt 0000:00:01.0[A] -> GSI 16 (level, low) -> IRQ 169
Apr 16 00:54:11 server kernel: [42949374.390000] PCI: Setting latency timer of device 0000:00:01.0 to 64
Apr 16 00:54:11 server kernel: [42949374.390000] PCI: Setting latency timer of device 0000:01:00.0 to 64
Apr 16 00:54:11 server kernel: [42949374.390000] ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 16 (level, low) -> IRQ 169
Apr 16 00:54:11 server kernel: [42949374.390000] PCI: Setting latency timer of device 0000:00:1c.0 to 64
Apr 16 00:54:11 server kernel: [42949374.390000] ACPI: PCI Interrupt 0000:00:1c.1 -> GSI 17 (level, low) -> IRQ 177
Apr 16 00:54:11 server kernel: [42949374.390000] PCI: Setting latency timer of device 0000:00:1c.1 to 64
Apr 16 00:54:11 server kernel: [42949374.390000] PCI: Setting latency timer of device 0000:00:1e.0 to 64
Apr 16 00:54:11 server kernel: [42949374.390000] NET: Registered protocol family 2
Apr 16 00:54:11 server kernel: [42949374.490000] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
Apr 16 00:54:11 server kernel: [42949374.490000] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
Apr 16 00:54:11 server kernel: [42949374.490000] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
Apr 16 00:54:11 server kernel: [42949374.490000] TCP: Hash tables configured (established 262144 bind 65536)
Apr 16 00:54:11 server kernel: [42949374.490000] TCP reno registered
Apr 16 00:54:11 server kernel: [42949374.490000] audit: initializing netlink socket (disabled)
Apr 16 00:54:11 server kernel: [42949374.490000] audit(1176684830.490:1): initialized
Apr 16 00:54:11 server kernel: [42949374.490000] highmem bounce pool size: 64 pages
Apr 16 00:54:11 server kernel: [42949374.490000] VFS: Disk quotas dquot_6.5.1
Apr 16 00:54:11 server kernel: [42949374.490000] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Apr 16 00:54:11 server kernel: [42949374.490000] Initializing Cryptographic API
Apr 16 00:54:11 server kernel: [42949374.490000] io scheduler noop registered
Apr 16 00:54:11 server kernel: [42949374.490000] io scheduler anticipatory registered
Apr 16 00:54:11 server kernel: [42949374.490000] io scheduler deadline registered (default)
Apr 16 00:54:11 server kernel: [42949374.490000] io scheduler cfq registered
Apr 16 00:54:11 server kernel: [42949374.490000] ACPI: PCI Interrupt 0000:00:01.0[A] -> GSI 16 (level, low) -> IRQ 169
Apr 16 00:54:11 server kernel: [42949374.490000] PCI: Setting latency timer of device 0000:00:01.0 to 64
Apr 16 00:54:11 server kernel: [42949374.490000] assign_interrupt_mode Found MSI capability
Apr 16 00:54:11 server kernel: [42949374.490000] Allocate Port Service[0000:00:01.0:pcie00]
Apr 16 00:54:11 server kernel: [42949374.490000] Allocate Port Service[0000:00:01.0:pcie03]
Apr 16 00:54:11 server kernel: [42949374.490000] ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 16 (level, low) -> IRQ 169
Apr 16 00:54:11 server kernel: [42949374.490000] PCI: Setting latency timer of device 0000:00:1c.0 to 64
Apr 16 00:54:11 server kernel: [42949374.490000] Allocate Port Service[0000:00:1c.0:pcie00]
Apr 16 00:54:11 server kernel: [42949374.490000] Allocate Port Service[0000:00:1c.0:pcie02]
Apr 16 00:54:11 server kernel: [42949374.490000] Allocate Port Service[0000:00:1c.0:pcie03]
Apr 16 00:54:11 server kernel: [42949374.490000] ACPI: PCI Interrupt 0000:00:1c.1 -> GSI 17 (level, low) -> IRQ 177
Apr 16 00:54:11 server kernel: [42949374.490000] PCI: Setting latency timer of device 0000:00:1c.1 to 64
Apr 16 00:54:11 server kernel: [42949374.490000] Allocate Port Service[0000:00:1c.1:pcie00]
Apr 16 00:54:11 server kernel: [42949374.490000] Allocate Port Service[0000:00:1c.1:pcie02]
Apr 16 00:54:11 server kernel: [42949374.490000] Allocate Port Service[0000:00:1c.1:pcie03]
Apr 16 00:54:11 server kernel: [42949374.490000] isapnp: Scanning for PnP cards...
Apr 16 00:54:11 server kernel: [42949374.840000] isapnp: No Plug & Play device found
Apr 16 00:54:11 server kernel: [42949374.870000] Real Time Clock Driver v1.12ac
Apr 16 00:54:11 server kernel: [42949374.870000] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Apr 16 00:54:11 server kernel: [42949374.870000] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Apr 16 00:54:11 server kernel: [42949374.870000] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Apr 16 00:54:11 server kernel: [42949374.870000] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Apr 16 00:54:11 server kernel: [42949374.870000] 00:08: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Apr 16 00:54:11 server kernel: [42949374.870000] mice: PS/2 mouse device common for all mice
Apr 16 00:54:11 server kernel: [42949374.870000] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
Apr 16 00:54:11 server kernel: [42949374.870000] Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Apr 16 00:54:11 server kernel: [42949374.870000] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Apr 16 00:54:11 server kernel: [42949374.870000] PNP: No PS/2 controller found. Probing ports directly.
Apr 16 00:54:11 server kernel: [42949374.870000] serio: i8042 AUX port at 0x60,0x64 irq 12
Apr 16 00:54:11 server kernel: [42949374.870000] serio: i8042 KBD port at 0x60,0x64 irq 1
Apr 16 00:54:11 server kernel: [42949374.870000] EISA: Probing bus 0 at eisa.0
Apr 16 00:54:11 server kernel: [42949374.870000] EISA: Detected 0 cards.
Apr 16 00:54:11 server kernel: [42949374.870000] TCP bic registered
Apr 16 00:54:11 server kernel: [42949374.870000] NET: Registered protocol family 1
Apr 16 00:54:11 server kernel: [42949374.870000] NET: Registered protocol family 8
Apr 16 00:54:11 server kernel: [42949374.870000] NET: Registered protocol family 20
Apr 16 00:54:11 server kernel: [42949374.870000] Starting balanced_irq
Apr 16 00:54:11 server kernel: [42949374.870000] Using IPI No-Shortcut mode
Apr 16 00:54:11 server kernel: [42949374.870000] ACPI: (supports S0 S1 S4 S5)
Apr 16 00:54:11 server kernel: [42949374.870000] Freeing unused kernel memory: 312k freed
Apr 16 00:54:11 server kernel: [42949374.910000] Capability LSM initialized
Apr 16 00:54:11 server kernel: [42949374.940000] ACPI (exconfig-0455): Dynamic SSDT Load - OemId [ PmRef] OemTableId [ Cpu1Ist] [20060707]
Apr 16 00:54:11 server kernel: [42949374.940000] ACPI Exception (acpi_processor-0693): AE_NOT_FOUND, Processor Device is not present [20060707]
Apr 16 00:54:11 server kernel: [42949374.940000] ACPI: Getting cpuindex for acpiid 0x2
Apr 16 00:54:11 server kernel: [42949374.940000] ACPI: Getting cpuindex for acpiid 0x3
Apr 16 00:54:11 server kernel: [42949375.300000] ICH6: IDE controller at PCI slot 0000:00:1f.1
Apr 16 00:54:11 server kernel: [42949375.300000] ACPI: PCI Interrupt 0000:00:1f.1[A] -> GSI 18 (level, low) -> IRQ 217
Apr 16 00:54:11 server kernel: [42949375.300000] ICH6: chipset revision 3
Apr 16 00:54:11 server kernel: [42949375.300000] ICH6: not 100%% native mode: will probe irqs later
Apr 16 00:54:11 server kernel: [42949375.300000] ide0: BM-DMA at 0xf000-0xf007, BIOS settings: hda:DMA, hdb:pio
Apr 16 00:54:11 server kernel: [42949375.300000] ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:pio, hdd:pio
Apr 16 00:54:11 server kernel: [42949375.300000] Probing IDE interface ide0...
Apr 16 00:54:11 server kernel: [42949376.090000] hda: CD-224E-N, ATAPI CD/DVD-ROM drive
Apr 16 00:54:11 server kernel: [42949376.810000] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Apr 16 00:54:11 server kernel: [42949376.810000] Probing IDE interface ide1...
Apr 16 00:54:11 server kernel: [42949377.420000] hda: ATAPI 24X CD-ROM drive, 256kB Cache, UDMA(33)
Apr 16 00:54:11 server kernel: [42949377.420000] Uniform CD-ROM driver Revision: 3.20
Apr 16 00:54:11 server kernel: [42949377.480000] SCSI subsystem initialized
Apr 16 00:54:11 server kernel: [42949377.480000] libata version 1.20 loaded.
Apr 16 00:54:11 server kernel: [42949377.480000] ahci 0000:00:1f.2: version 1.2
Apr 16 00:54:11 server kernel: [42949377.480000] ACPI: PCI Interrupt 0000:00:1f.2 -> GSI 19 (level, low) -> IRQ 225
Apr 16 00:54:11 server kernel: [42949384.510000] PCI: Setting latency timer of device 0000:00:1f.2 to 64
Apr 16 00:54:11 server kernel: [42949384.510000] ahci 0000:00:1f.2: AHCI 0001.0000 32 slots 4 ports 1.5 Gbps 0xf impl IDE mode
Apr 16 00:54:11 server kernel: [42949384.510000] ahci 0000:00:1f.2: flags: 64bit ncq pm led slum part
Apr 16 00:54:11 server kernel: [42949384.510000] ata1: SATA max UDMA/133 cmd 0xF883C100 ctl 0x0 bmdma 0x0 irq 225
Apr 16 00:54:11 server kernel: [42949384.510000] ata2: SATA max UDMA/133 cmd 0xF883C180 ctl 0x0 bmdma 0x0 irq 225
Apr 16 00:54:11 server kernel: [42949384.510000] ata3: SATA max UDMA/133 cmd 0xF883C200 ctl 0x0 bmdma 0x0 irq 225
Apr 16 00:54:11 server kernel: [42949384.510000] ata4: SATA max UDMA/133 cmd 0xF883C280 ctl 0x0 bmdma 0x0 irq 225
Apr 16 00:54:11 server kernel: [42949384.920000] ata1: SATA link up 1.5 Gbps (SStatus 113)
Apr 16 00:54:11 server kernel: [42949384.920000] ata1: dev 0 cfg 49:2f00 82:346b 83:7fe9 84:4773 85:3468 86:3c01 87:4763 88:207f
Apr 16 00:54:11 server kernel: [42949384.920000] ata1: dev 0 ATA-7, max UDMA/133, 321672960 sectors: LBA48
Apr 16 00:54:11 server kernel: [42949384.920000] ata1: dev 0 configured for UDMA/133
Apr 16 00:54:11 server kernel: [42949384.920000] scsi0 : ahci
Apr 16 00:54:11 server kernel: [42949385.130000] ata2: SATA link down (SStatus 0)
Apr 16 00:54:11 server kernel: [42949385.130000] scsi1 : ahci
Apr 16 00:54:11 server kernel: [42949385.340000] ata3: SATA link down (SStatus 0)
Apr 16 00:54:11 server kernel: [42949385.340000] scsi2 : ahci
Apr 16 00:54:11 server kernel: [42949385.550000] ata4: SATA link down (SStatus 0)
Apr 16 00:54:11 server kernel: [42949385.550000] scsi3 : ahci
Apr 16 00:54:11 server kernel: [42949385.550000] Vendor: ATA Model: HDT722516DLA380 Rev: V43O
Apr 16 00:54:11 server kernel: [42949385.550000] Type: Direct-Access ANSI SCSI revision: 05
Apr 16 00:54:11 server kernel: [42949385.550000] SCSI device sda: 321672960 512-byte hdwr sectors (164697 MB)
Apr 16 00:54:11 server kernel: [42949385.550000] sda: Write Protect is off
Apr 16 00:54:11 server kernel: [42949385.550000] sda: Mode Sense: 00 3a 00 00
Apr 16 00:54:11 server kernel: [42949385.550000] SCSI device sda: drive cache: write back
Apr 16 00:54:11 server kernel: [42949385.550000] sda: sda1 sda2 < sda5 >
Apr 16 00:54:11 server kernel: [42949385.580000] sd 0:0:0:0: Attached scsi disk sda
Apr 16 00:54:11 server kernel: [42949385.750000] Probing IDE interface ide1...
Apr 16 00:54:11 server kernel: [42949385.790000] usbcore: registered new driver usbfs
Apr 16 00:54:11 server kernel: [42949385.790000] usbcore: registered new driver hub
Apr 16 00:54:11 server kernel: [42949385.790000] ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 233
Apr 16 00:54:11 server kernel: [42949385.790000] PCI: Setting latency timer of device 0000:00:1d.7 to 64
Apr 16 00:54:11 server kernel: [42949385.790000] ehci_hcd 0000:00:1d.7: EHCI Host Controller
Apr 16 00:54:11 server kernel: [42949385.790000] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
Apr 16 00:54:11 server kernel: [42949385.790000] PCI: cache line size of 128 is not supported by device 0000:00:1d.7
Apr 16 00:54:11 server kernel: [42949385.790000] ehci_hcd 0000:00:1d.7: irq 233, io mem 0xd03c0000
Apr 16 00:54:11 server kernel: [42949385.800000] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Apr 16 00:54:11 server kernel: [42949385.800000] usb usb1: configuration #1 chosen from 1 choice
Apr 16 00:54:11 server kernel: [42949385.800000] hub 1-0:1.0: USB hub found
Apr 16 00:54:11 server kernel: [42949385.800000] hub 1-0:1.0: 8 ports detected
Apr 16 00:54:11 server kernel: [42949385.820000] USB Universal Host Controller Interface driver v3.0
Apr 16 00:54:11 server kernel: [42949385.910000] ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 233
Apr 16 00:54:11 server kernel: [42949385.910000] PCI: Setting latency timer of device 0000:00:1d.0 to 64
Apr 16 00:54:11 server kernel: [42949385.910000] uhci_hcd 0000:00:1d.0: UHCI Host Controller
Apr 16 00:54:11 server kernel: [42949385.910000] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
Apr 16 00:54:11 server kernel: [42949385.910000] uhci_hcd 0000:00:1d.0: irq 233, io base 0x0000e100
Apr 16 00:54:11 server kernel: [42949385.910000] usb usb2: configuration #1 chosen from 1 choice
Apr 16 00:54:11 server kernel: [42949385.910000] hub 2-0:1.0: USB hub found
Apr 16 00:54:11 server kernel: [42949385.910000] hub 2-0:1.0: 2 ports detected
Apr 16 00:54:11 server kernel: [42949386.020000] ACPI: PCI Interrupt 0000:00:1d.1 -> GSI 19 (level, low) -> IRQ 225
Apr 16 00:54:11 server kernel: [42949386.020000] PCI: Setting latency timer of device 0000:00:1d.1 to 64
Apr 16 00:54:11 server kernel: [42949386.020000] uhci_hcd 0000:00:1d.1: UHCI Host Controller
Apr 16 00:54:11 server kernel: [42949386.020000] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
Apr 16 00:54:11 server kernel: [42949386.020000] uhci_hcd 0000:00:1d.1: irq 225, io base 0x0000e200
Apr 16 00:54:11 server kernel: [42949386.020000] usb usb3: configuration #1 chosen from 1 choice
Apr 16 00:54:11 server kernel: [42949386.020000] hub 3-0:1.0: USB hub found
Apr 16 00:54:11 server kernel: [42949386.020000] hub 3-0:1.0: 2 ports detected
Apr 16 00:54:11 server kernel: [42949386.130000] ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 217
Apr 16 00:54:11 server kernel: [42949386.130000] PCI: Setting latency timer of device 0000:00:1d.2 to 64
Apr 16 00:54:11 server kernel: [42949386.130000] uhci_hcd 0000:00:1d.2: UHCI Host Controller
Apr 16 00:54:11 server kernel: [42949386.130000] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
Apr 16 00:54:11 server kernel: [42949386.130000] uhci_hcd 0000:00:1d.2: irq 217, io base 0x0000e300
Apr 16 00:54:11 server kernel: [42949386.130000] usb usb4: configuration #1 chosen from 1 choice
Apr 16 00:54:11 server kernel: [42949386.130000] hub 4-0:1.0: USB hub found
Apr 16 00:54:11 server kernel: [42949386.130000] hub 4-0:1.0: 2 ports detected
Apr 16 00:54:11 server kernel: [42949386.240000] ACPI: PCI Interrupt 0000:00:1d.3[D] -> GSI 16 (level, low) -> IRQ 169
Apr 16 00:54:11 server kernel: [42949386.240000] PCI: Setting latency timer of device 0000:00:1d.3 to 64
Apr 16 00:54:11 server kernel: [42949386.240000] uhci_hcd 0000:00:1d.3: UHCI Host Controller
Apr 16 00:54:11 server kernel: [42949386.240000] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
Apr 16 00:54:11 server kernel: [42949386.240000] uhci_hcd 0000:00:1d.3: irq 169, io base 0x0000e400
Apr 16 00:54:11 server kernel: [42949386.240000] usb usb5: configuration #1 chosen from 1 choice
Apr 16 00:54:11 server kernel: [42949386.240000] hub 5-0:1.0: USB hub found
Apr 16 00:54:11 server kernel: [42949386.240000] hub 5-0:1.0: 2 ports detected
Apr 16 00:54:11 server kernel: [42949386.420000] Attempting manual resume
Apr 16 00:54:11 server kernel: [42949386.430000] EXT3-fs: INFO: recovery required on readonly filesystem.
Apr 16 00:54:11 server kernel: [42949386.430000] EXT3-fs: write access will be enabled during recovery.
Apr 16 00:54:11 server kernel: [42949389.010000] kjournald starting. Commit interval 5 seconds
Apr 16 00:54:11 server kernel: [42949389.010000] EXT3-fs: sda1: orphan cleanup on readonly fs
Apr 16 00:54:11 server kernel: [42949389.050000] ext3_orphan_cleanup: deleting unreferenced inode 16416776
Apr 16 00:54:11 server kernel: [42949389.050000] ext3_orphan_cleanup: deleting unreferenced inode 16416775
Apr 16 00:54:11 server kernel: [42949389.050000] ext3_orphan_cleanup: deleting unreferenced inode 16416774
Apr 16 00:54:11 server kernel: [42949389.050000] ext3_orphan_cleanup: deleting unreferenced inode 16416773
Apr 16 00:54:11 server kernel: [42949389.050000] ext3_orphan_cleanup: deleting unreferenced inode 16416772
Apr 16 00:54:11 server kernel: [42949389.050000] EXT3-fs: sda1: 5 orphan inodes deleted
Apr 16 00:54:11 server kernel: [42949389.050000] EXT3-fs: recovery complete.
Apr 16 00:54:11 server kernel: [42949389.070000] EXT3-fs: mounted filesystem with ordered data mode.
Apr 16 00:54:11 server kernel: [42949392.600000] hw_random: RNG not detected
Apr 16 00:54:11 server kernel: [42949392.790000] parport: PnPBIOS parport detected.
Apr 16 00:54:11 server kernel: [42949392.790000] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
Apr 16 00:54:11 server kernel: [42949392.850000] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Apr 16 00:54:11 server kernel: [42949392.920000] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Apr 16 00:54:11 server kernel: [42949392.970000] input: PC Speaker as /class/input/input0
Apr 16 00:54:11 server kernel: [42949393.050000] FDC 0 is a post-1991 82077
Apr 16 00:54:11 server kernel: [42949393.280000] tg3.c:v3.59.1 (August 25, 2006)
Apr 16 00:54:11 server kernel: [42949393.280000] ACPI: PCI Interrupt 0000:03:00.0[A] -> GSI 16 (level, low) -> IRQ 169
Apr 16 00:54:11 server kernel: [42949393.280000] PCI: Setting latency timer of device 0000:03:00.0 to 64
Apr 16 00:54:11 server kernel: [42949393.310000] eth0: Tigon3 [partno(BCM95721) rev 4101 PHY(5750)] (PCI Express) 10/100/1000BaseT Ethernet 00:30:48:88:82:54
Apr 16 00:54:11 server kernel: [42949393.310000] eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[1] Split[0] WireSpeed[1] TSOcap[1]
Apr 16 00:54:11 server kernel: [42949393.310000] eth0: dma_rwctrl[76180000] dma_mask[64-bit]
Apr 16 00:54:11 server kernel: [42949393.310000] ACPI: PCI Interrupt 0000:04:00.0[A] -> GSI 17 (level, low) -> IRQ 177
Apr 16 00:54:11 server kernel: [42949393.310000] PCI: Setting latency timer of device 0000:04:00.0 to 64
Apr 16 00:54:11 server kernel: [42949393.310000] sd 0:0:0:0: Attached scsi generic sg0 type 0
Apr 16 00:54:11 server kernel: [42949393.340000] eth1: Tigon3 [partno(BCM95721) rev 4101 PHY(5750)] (PCI Express) 10/100/1000BaseT Ethernet 00:30:48:88:82:55
Apr 16 00:54:11 server kernel: [42949393.340000] eth1: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[1] Split[0] WireSpeed[1] TSOcap[1]
Apr 16 00:54:11 server kernel: [42949393.340000] eth1: dma_rwctrl[76180000] dma_mask[64-bit]
Apr 16 00:54:11 server kernel: [42949393.670000] lp0: using parport0 (interrupt-driven).
Apr 16 00:54:11 server kernel: [42949393.860000] Adding 6056464k swap on /dev/disk/by-uuid/1dd9a76c-5e03-4607-b968-9cdfbc68e335. Priority:-1 extents:1 across:6056464k
Apr 16 00:54:11 server kernel: [42949393.940000] EXT3 FS on sda1, internal journal
Apr 16 00:54:11 server kernel: [42949395.080000] tg3: eth0: Link is up at 100 Mbps, full duplex.
Apr 16 00:54:11 server kernel: [42949395.080000] tg3: eth0: Flow control is off for TX and off for RX.
Apr 16 00:54:15 server kernel: [42949400.300000] NET: Registered protocol family 10
Apr 16 00:54:15 server kernel: [42949400.300000] lo: Disabled Privacy Extensions
Apr 16 00:54:15 server kernel: [42949400.300000] IPv6 over IPv4 tunneling driver
Apr 16 00:54:26 server kernel: [42949410.600000] eth0: no IPv6 routers present
Dette er det som ligger i kern.log. Ble du noe klokere? :)
Der sto det ikke så mye gitt, jeg ser at systemet "renser" disken, noe som tilsier at boksen dør "hardt og brutalt". Og siden det heller ikke står mer i loggen, (f.eks at den fant døde sektorer, o.l) kan det tilsi at det er noe ustabli maskinvare i boksen. Linux pleier å være veldig grei sånt sett, så når noe dør pleier det å skyldes ustabilitet.
Mine 2 øre er PSU/Minne/Hk som kan være problemet.
8419097[/snapback]
Ok. Takk for tips. Boksen er ett år gammel. Supermicro. Får reklamere på den om det skjer igjen.
Det står ingenting som jeg kan se er vesentlig i de loggene. Det er noen linjer med:
Apr 5 17:07:22 server kernel: [44165683.830000] TCP: Treason uncloaked! Peer 84.133.127.86:3313/80 shrinks window 2116467960:2116481028. Repaired.
i .0 loggen.
